Northmount
Moderator
  1. Hi @Vugar Moved your post to hardware and accessories. Posts in "Help Wanted" require moderators approval for all posts in the thread. I think you'll get more answers here too. Are the pieces that appear to be like straps metal? If so these could be purse or bag frames that you press together at the ends to bow the sides of the bag outward, opening the bag. Tom
  2. Would be nice to post your findings hear so others can see without having to go research it too. Kind of helps fill out this thread. Tom
  3. Some guys swear that the link belt reduces vibration on their tablesaws. But that belt is really traveling compared to a sewing machine. They are quite handy when you're not sure of the belt size, or for a one size fits all in your shop. But as noted, they are expensive. Tom
  4. If you go to the top right of this thread, there is a button "Follow" with the number of people following this thread. Click on the button and set how often you want to be updated when additional posts are made on this thread. Tom
  5. @Toro Moved to business and estate sales rather than wanted! As in your other post, identify your location (street address and California is rather vague!) and whether you will ship, etc. Tom
  6. @Toro From your IP address it appears you are in the Los Angeles area. Confirm your location and whether you will ship or what. Tom
  7. @McLestergl Add your shipping info or restrictions. Tom
  8. Northmount
    Rein Rounder
    See Bruce Johnson https://brucejohnsonleather.com/leather-tools-sale/rein-rounders-and-lace-cutters-sale/ Tom
  9. @westernsaddler Moved your post to leather sewing machines. You'll get more responses here for sewing machine related issues. Tom
  10. @Skylark53 moved your post to leather sewing machines wher you will likely get more responses or information. Tom
  11. You will find a lot of info about bookbinding at this channel. https://www.youtube.com/user/alexogden49/videos Tom
  12. I only have easy access to Organ needles. There are many other recommendations elsewhere in this forum. Tom
  13. Conical point needles blow out the back of the leather. So yes the right move is leather point 135x16. Tom
  14. Please read the Marketplace Rules and abide by them http://leatherworker.net/forum/forum/70-announcements/ At the very least you should have photos. What type of motor, what have you been using it for, etc. Tom
  15. Use a leather point needle. Looks like yours is a standard conical point. They blow out the back instead of slicing through the leather. Hammer the seam flat after. It will help fix the blowout. Tom
  16. IP address is for Frohna, Missouri @MommaMiia it's a good idea to include your location in your profile so more relevant information can be given that fits your location in this global world we live in. Tom
  17. That sounds like it is more likely than my comment above. Good call. Tom
  18. @lyricsonwings moved your post to leather sewing machines. Tom
  19. It must be a brush type motor and the brushes are vibrating in the brush holder as the commutator turns. Check the brushes are not worn out (too short). If the motor is new, they may wear in and stop squealing. There will be two brushes, one on each side of the motor. Usually a black cap with a screwdriver slot. Don't over tighten or you may break the external part of the brush holder. Tom
  20. When you measure pulley size, use the outside diameter of the pulley. There are 3 parts to pulley size. Width at the top of the groove determines belt width. the other 2 are OD and ID. When calculating pulley ratios, always use the OD of the pulleys. Belts are meant to ride at the top, not down in the bottom. If the pulley is too wide, the belt rides in the bottom and it slips. Comments about clutch motors: They are fine for people that are well experienced using a clutch motor. You have to be able to slip the clutch (like slipping the clutch in a car/truck with a manual transmission when you are starting up from a stop). If you miscalculate, the machine will take off like a jack rabbit. If you want to crawl, you need lots of practice. For Servo motors: To be able to go really slow, like a stitch per second or slower, you need a system that will provide high torque at very slow speeds, especially if you are sewing thick or hard tempered leather. I have a servo with built in gear reduction 3:1. At the lowest speed setting, it didn't have the torque needed to punch through 10 oz. belts at a crawl so I could carefully go around the tip of the billet. I assembled a pulley speed reducer with 2" and 7.5" pulleys. That gives a 3.75:1 speed reduction. That gives me an 11.2:1 overall speed reduction. Actually when you count the servo pulley and the machine pulley as well, it is about 16:1. Only expensive servo motors have high torque at low speeds and can literally step. Typical sewing machine servos lose torque at low speeds. This is true of most all AC motors and even DC motors depending upon their winding configuration. So you need to have enough motor speed to develop the torque required for the job. Thus you need to have either a gear or pulley speed reduction system to do what you want to do. Tom
  21. @aroh99 Moved your post to leather sewing machines. Tom
  22. Hi @VeeBee. Moved your post to leather sewing machines. You'll get more answers here. Tom
  23. A capacitor start motor should have better starting torque. Check what you have versus capacitor start. Tom
  24. @Blackbird @Rohn Blackbird hasn't been on this site since March. So it looks like he may not be interested in following up on his posting. If there is no response from him, remind me in a couple days to move this to "old and sold" and to lock this thread. Tom
