Check out this FB page, join it. They have photos and a database for Craftaids. Tandy Craftaid Template Database https://www.facebook.com/groups/1373586829381487/ Tom
Lost & Looking for the road...from Toronto Canada
Northmount replied to Veej's topic in Getting Started
Just type tandyleather.ca into your browser. Tom -
Tanner's Bond Contact Cement - why isn't it working?
Northmount replied to teresamwong's topic in Sewing Leather
Use a coarse sandpaper to really roughen the surfaces that are being glued together. Gives a "tooth" for the glue/contact cement to get into. Smooth is an enemy in this case. Follow the directions. Apply cement to both surfaces. Let it dry to hardly tacky at all. Then press together. Roll it with a roller, or tap it with a smooth faced hammer to help bond it. Some have more success with heating it a little. Tom -
Thanks DQ. Here it is. Tom CHM 30.PDF
- 6 replies
- sewing machines
- needle and awl
(and 1 more)
Leather squeezing out from bottom side feed dogs
Northmount replied to SaltyKate's topic in Sewing Leather
Make sure the piece stays flat, don't accidentally lift the left side up higher than the right side where you are stitching. Causes the needle holes to be slanted so the back stitch is skewed compared to the top side. Also watch how it is feeding. If the feet don't sit squarely on the throat plate, it will drag the item to one side of the other. If you are using contact cement properly, it should not be able to skew the top and bottom pieces. Double sided tape is generally not as secure as contact cement. When sewing close to the edge like this, the leather is trapped between the outside foot and the throat plate on the left, but only trapped by the feet and the feed dog on the right side, so will tend to drive you off sewing in a straight line. Not sure if this is what you having trouble with, but hope it helps. You'll probably get some better answers from @Wizcrafts or others yet. Tom -
Class 4 machine bobbin not staying slot
Northmount replied to cody1200's topic in Leather Sewing Machines
Please share! Tom -
Reduce your picture size to about 800 x 600 and you'll have room for many photos. Please also follow the Marketplace rules. State condition of machines, price in US$, location, shipping, etc. Tom
Please read and follow the "market place" rules. http://leatherworker.net/forum/forum/70-announcements/ Tom
Cornstarch works too. Tom
Try this https://www.amazon.com/Leather-Secrets-F-Baird/dp/091828001X Tom
- 5 replies
- f.o. baird
- secrets
(and 1 more)
Help me choose a first sewing machine
Northmount replied to Gilbert's topic in Leather Sewing Machines
First off, have you done your research? There is lots of good advice available here in figuring out what you need for a sewing machine. Look for pinned threads in the sewing machine forum. Tom -
Heat depending on temperature will cause the leather to harden and shrivel up. Too much oil is a big problem. Try placing in a pan of cornstarch or kitty litter for a few days to absorb the oil. Stir it around every few hours to put dry media in contact with the oil. NFO usually darkens leather. Sometime much darker than you expect. Always do test pieces to see what works and doesn't work before hitting a project you have put a lot of time and effort into. Use leather from the same hide as they don't all behave the same. Tom
Genuine Monte Foreman Balance ride saddle
Northmount replied to CRTraining's topic in Feedback and Suggestions
Pictures might help Tom -
Lots of info about casing (wetting prior to tooling) your leather here in this thread. http://leatherworker.net/forum/topic/19121-casing-leather/ You need a finish that is resistant to water, some acrylic leather finishes work, but I prefer a lacquer based leather finish for this case. Tom
It's great to have your input. My stint in a wheelchair was only 3 weeks. Not years like many. We have a dear friend that was in a car accident and is now a high level quad with some use of her arms. Over 30 years now. Tom
Hi @Wizcrafts , could you comment on the GMarie's (the OP) question. Should have been under sewing machines and it would have been noticed sooner. Then it got hijacked by Colemckeon! He was whining about his post in help wanted. Tom
You have hijacked the OP's thread, completely off their topic. That is bad form or etiquette on any forum. You could have started a new thread yourself or sent a PM to a moderator. You posted your help wanted thread at 3:48PM. It was approved by a moderator at 6:07PM, less than 3 hours later. Since no moderator is sitting waiting for you to post, what do you expect? We have our own jobs, not affiliated with LW and just volunteer here as moderators. We like to support our group and to see and learn what others are doing. You should apologize to the OP. I've hidden your similar post in another thread, since it destroys the continuity of that thread as well. Tom
Generally, the wheelchair user is not using the tires to propel themselves. Usually grip a smaller diameter wheel, usually chromed, mounted outside the the tire. There is not a lot of distance between the tire and the 'drive' wheel, so could be some contamination, though not as serious. Gloves may need wrist support as shown in the photos. Tom
Atom Clicker using Rotary phase converter
Northmount replied to Ernie92's topic in How Do I Do That?
If wrong rotation, and this is a 3 phase motor, reversing any 2 leads will change the direction of rotation. Tom -
Laser engraving stained/painted leather
Northmount replied to Katlyn4jc's topic in How Do I Do That?
That sounds better. Couldn't see how you would be able to line up precisely to etch after paint or dye. Makes a lot of sense. Tom -
Take a look at Jim Linnell's website and his video on how to make feathers. https://elktracksstudio.com/collections/videos/products/3d-feather-workshop. You will learn what leather to use, how to make all sizes down to earring size. I think you will find it well worth the $30US. As soon as I get past a bunch of renovation work, I want to sit down and start making feather earrings too. Tom
Definitely. I like to tryout patterns or make new patterns using paper or light weight cardboard. I staple the edges together to check shape and fit. Adjust as necessary, then go for the leather. Sometimes will do a second prototype on cheap leather to see how it really turns out. Tom
Using Adobe's measure function, the widest part of the pattern is about 8.75 inches. Check your printout and see if it matches. Tom
