Northmount
Moderator
  1. Use right twist for the outside thread. I recall reading a couple threads on this subject if you want to search for more information. Tom
  2. Here are links to a few threads here on LW. http://leatherworker.net/forum/topic/74742-ever-seen-this-vacuum-setup/?tab=comments#comment-491611 http://leatherworker.net/forum/topic/27904-leather-holster-forming-vacuum-versus-press/?tab=comments#comment-175367 http://leatherworker.net/forum/topic/72326-wet-molding-pressing-in-hydraulic-press-etc-holsters/?tab=comments#comment-473131 http://leatherworker.net/forum/topic/22164-cheap-holster-press/ If you want to do a search here, you will find more threads with good information and photos. Tom
  3. As soon as you get a the gel antique on, you have to start scrubbing it off with a wet sponge. If you don't it stays on thick, darker, over the whole item. As an example, saddle tan turns the whole item a dark red. George Hurst has a short video showing how to use it. It would be really nice if Tandy would actually put some instructions on the bottle! Then I might have half a chance of not ruining my project. Don't use gel antique and antique paste on the same project. Tom
  4. Calgary, AB
  5. Moore Leather --- Can you update this thread with photos that have gone missing due to being linked to a sharing site? Seems they have been deleted, moved or otherwise changed permissions. Please add them to a new post here, or to a gallery here. If you need help to do so, PM me so I can help. I can even stuff them into the original posts if you make them available to me. Tom
  6. Good stuff! Sandpaper works for roughing up the grain side before gluing. Also, use a contact cement. Water based or solvent based. Tom
  7. For many machines, reverse after the needle has started to rise. So the hook has caught the loop. Tom
  8. To create a new Album, go to the Top menu bar, Browse, and click on Gallery. This will show a a number of gallery areas. Click the "Add Images" button. Then select a category. A couple of them are "More Leatherwork" and "Tutorials and Lessons" that might be what you are looking for. Select the category. On the left portion of the screen, there is an area to Create a new Album. (On the right side is an area to pick an existing album. You can access existing albums from there later, or from your profile.) Name the album ---- Add a description ----- Set the ownership (place your screen name here "RockyAussie"), privacy and album features you wish. Click the "Create New Album" button. Now you can drag and drop photos (files) from Windows Explorer (if you are using MS Windows, can't tell you for a Mac) or click the "Chose Files" button, which will open a dialog box where you navigate to the folder location and files you wish to load. There is a limit of 100 files. For each photo that is loaded, select the photo and add a name, tags if any, and comments.. Then click the "Save" button. I have just created a new album for test purposed so I could step through this procedure. I'm away from home so do not have access to my photos, so have loaded a few samples off the web. You can navigate to your photos through either the main Gallery, or through your Profile. Since you have created an album, you will now see the album in your profile where you can manage your photos and add more photos. Click on your photo so it displays larger. Right click on the photo and pick "Copy image location" and paste it into the post. It gives you two options. Display as a URL or embed. Pick embed to have the photo displayed rather than just the URL. (It worked!) Tom
  9. Northmount
    Toms Test
    For test and demo purposes, used to show how to create an album and copy photos into a post.
  10. Northmount
    From the album: Toms Test
    family brands from about 1920 until 1970 approximately.
  11. You can email Matt and arrange purchase and delivery through Houston TX if you wish. Both books are well worth while. If you have Australian connections, you will find them especially interesting. Tom
  12. Create an album, name it, load your photos into it. Then copy the URL of the photo you have in your album, and paste into your post. You may have to reduce photo size, but I have noticed that the system allows larger photos in your album than when you post in a thread. Tom
  13. Please read and abide by the market place rules http://leatherworker.net/forum/forum/70-announcements/ Tom
  14. " I usually round over the point at the top. I never cut with it and that is what has bit me when I have reached across. " See this thread http://leatherworker.net/forum/topic/38698-tips-on-how-to-use-a-draw-gauge/?do=findComment&comment=240356 I've never clipped myself, but figure Bruce's comment is quite wise. Voice of experience. I like to reduce risk where I can. I'm a little adverse to slashing my wrist. And you really don't use that top 1/4" as it's not accessible to cut with, other than your wrist! Tom
  15. Round off the top end of the blade, helps to avoid accidental injuries. The top end of the blade is of no use when cutting, so no harm to the functionality of your drawgauge. Tom
  16. have you done a search here? Take a look at this post http://leatherworker.net/forum/topic/36137-leather-lifts-up-with-needle-need-help-at-wits-end/#comment-223429 You can find more like this. Posts by Wizcrafts and Gottaknow have a lot of good information on thread lubrication as well as many other sewing machine helps and problems. Tom
  17. Looks like your casing is improving. Too wet and the leather is mushy. The swivel knife drags. Stamping gets sort of blob like instead of burnishing and turning a deeper brown. You need a hard surface behind your leather while you are stamping. When I started 55 years ago, I had no option of getting a piece of granite or marble. I used 1/4" Masonite hardboard on a solid table with pipe frame and legs. For up to 8/9 oz leather it worked okay. Wood itself, depending on species is not likely hard enough. Some proponents of sharpening your swivel knife will tell you that you should strop on a hard surface rather than the backside of leather, since the leather deforms and tends to round over the sharp edge you are trying for. I use a piece of 3/4" MDF. Have one for red rouge and one for white stropping compound. I use a diamond sharpening plate labeled as extra fine if I need to remove any scratches from rougher stones or whatever, then of course follow that with red, then white stropping. Whether you use paints or dyes, make sure you allow adequate time for drying between coats. Also before applying any finish or layers of finish. No less than 4 hours, some behave better at 8 hours. When using dye, I sometimes dampen the leather slightly first as it helps stop the dye from suddenly seeping beyond the brush. Tom
  18. Needle system size 135/16 is a leather point, 135/17 is a conical point. Both are the same size/length. Leather point doesn't blow out the back of the leather as badly as a conical point. This version of leather point is like a chisel. Anyone that is somewhat mechanically inclined should be able to help you switch motors. Get a servo with the smallest pulley you can so the machine can run slower. Tom
  19. If you drop out the music, you could add some instructions to turn it into a small tutorial. Tom
  20. Figure carving tools/stamps are a sub-set of all the stamps. What you are looking for is the main stamps used for most floral carving to do the moon and star. A medium to small beveller, might want to get both a smooth and checkered style. Looks like you need a swivel knife, or need to get yours sharpened and make sure you are casing the leather correctly. For floral carvings, add pear shader, (checkered, smooth, and vertical lines are all nice to have). A camouflage stamp, veiner, and a couple versions of background stamps. And the list just continues to go on and on. But you can do a lot with about 5 stamps. Tom
  21. Take a look at https://brandingirons.com/collections/custom-branding-heads Scroll down the page a bit. Bought a hand held brass stamp with a 100 watt heater a few years ago. Use it for both wood and leather. There are other similar suppliers around too. Tom
  22. Try Rona, Home Depot, Canadian Tire. They all have various metal stock in bars, rounds, angles, aluminum, brass, steel, etc. Tom
  23. A photo or two and the purse name and style might help us provide some more assistance. Do you have access to a photos of the finished purse from the vendor? Tom
  24. Available 1963 and earlier for both the log letter craftaid and the wallet interior. May have been available for a few years after as well. The log letters were one of my favourites. Tom
  25. Here is their FB page https://www.facebook.com/Oaksonauthentic/ Tom
