Some explanation might help. A box (container) in which to dye leather? A box of dye? A box shaped die for clicking? I'm not understanding your request, so gather a number of others may have the same problem. An example, or photo, or ... Tom
Jewlery related "What do I need, where do I get it?"
Northmount replied to CaptQuirk's topic in How Do I Do That?
Try searching for jewellery findings. Then narrow the search when you are finding the type you are looking for. Tom -
Aluminum foil, or tape, also metal screen will block RF signals. Easy to lay foil tape between layers without adding a lot of bulk. Needs to be on both sides of the cards. Tom
According to his IP address: Los Angeles, California, 90046 It would be very nice if members would include their location in their profile. Tom
The 2# Tandy anvil is a good paper weight and that's all. You need at least a 15# anvil. See Canadian Tire in Canada, or Harbor Freight in the USA. Tom
Moisten slightly and carefully go over the impressions with a spoon. Be careful or you can leave more impressions you don't want. Tom
No tools here to rotate that I have seen. The photo is likely from a smart phone or other camera that saves the orientation and lots of other info as EXIF data inside the digital photo. You might try another photo editor to rotate and save the photo. IrfanView might work for you if you also download and install the EXIF plugin. It's a free download. Many browsers do not support EXIF data so won't rotate the photo to its original orientation. Some info here about EXIF https://www.makeuseof.com/tag/exif-photo-data-find-understand/ You can use ExifTool https://sno.phy.queensu.ca/~phil/exiftool/ to remove the EXIF data. Install the software on your computer and run it at the command line example exiftool -all= SourceFile.jpg and substitute the photo's filename in place of "SourceFile". I see that Windows 10 File Explorer will allow you to edit the EXIF data. Right click on the file and select properties, Details. I haven't tried it so you are on your own to experiment with it. Play with a copy. Photoshop and LightRoom have a file menu item to "save file for web". It removes personal data. Haven't checked to see what it leaves unchanged. Tom
Here women used to use garter straps and a garter belt to hold up their silk or nylon stockings. So I see where the use of suspenders would apply. Men just used a tight elastic band (garter) to help hold up knee high socks. That would strangle my legs and just about kill me. Tom
Also note that kevlar thread is very abrasive and wears grooves in the thread path. Tom
Wrap the bible with paper the way you want the cover to be. Add enough for the seam allowance, and add some extra pocket width and depth so the bible's cover doesn't get hung up while pushing them into your leather cover. I'd add at least 1/2" all the way around to get to your stitch line, then about an 1/8" more from the stitch line to the edge. You can cut some scrap leather the same thickness as you are going to use to make just a 1" wide strap. So it's just a narrow section for test purposes to see how the leather lays, how much room you want for the pocket, etc. I'd still add a little extra beyond that. Watch your glue line as it can eat up some of the pocket space! Clear as mud, I suppose, but experiment to see if the test strip works for you. Tom
leather techniques Secrets from the Workshop
Northmount replied to Dangerous Beans's topic in How Do I Do That?
I wouldn't even try my left hand. My right hand can hardly sign my name most days! Can't even read my own writing half the time now. Thank heavens for computers, I can still type and correct, so it is readable! Tom- 34 replies
- saddle stitch
- creasing
- (and 12 more)
Ruined My First Project!! Or, Help Me Fix It Please:-)
Northmount replied to MarkInKy's topic in How Do I Do That?
Not too bad really! Just accept the learning experience and continue on. If you want, you can beat it up a bit and call it distressed, aged, etc. Now you know that dye can bleed right through the leather. So the best treatment inside may be just to slick the inside with gum trag to lay the fibers down. Or better yet, line it with a thin lining leather like pigskin. Tom -
Take a look at this "thread" http://leatherworker.net/forum/topic/9223-need-supplier-for-bonded-kevlar-thread/ There are other "threads" here on leatherworker.net if you care to do a search for them. Do a google search with the following search string. "site:leatherworker.net kevlar thread" minus the quotation marks. Restricts the search to this site. Tom
Cut the end off the posts if they are too long. Often giving one heavy wack will bend to one side if not perfectly lined up. Tapping and rotating the tool angle a little may help you. Tom
Singer 29-4 what size needle for #69 thread?
Northmount replied to Nikonmom's topic in Hardware and Accessories
Needle thread size chart http://www.tolindsewmach.com/thread-chart.html 16 or 18 for 69 thread Tom -
Here are a couple I found. You can do a google search for more. Found some that sell only in lots of 500! That would last forever. http://www.talasonline.com/Ring-Book-Mechanisms https://ohiotravelbag.com/products/item/70d2bb14-d915-47ff-b95e-d4442388697d/BINDER-7 Tom
Used mine a couple weeks ago, had to replace a line on my compressor. I have a newer one that works a little better than the old one. Should dump the old one someday I guess. Tom
Onto the third bag....
Northmount replied to motocouture's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
For general information. 1 oz = 1/64" and of course there are 25.4 mm per inch. Tom -
Bottom item looks an awful lot like half of my copper tubing flaring tool. Check out Bruce Johnson's rein rounders for comparison. https://brucejohnsonleather.com/leather-tools-sale/leather-bench-machines-sale/ Tom
You appear to be USA based. Would be a good idea to add your location to your profile so you can get location specific responses rather then half way around the world from you. Try http://www.texascustomdies.com/products.php for new dies. They have some standard dies, ready made, plus can make any you wish. Tom
Yes, they don't bottom out, letting you cinch down tighter on thinner materials. Tom
Buff it off. Remove the extra pigment from the surface. Next time, preferably before you start putting any finish on top. Tom
Reset the safety clutch Tom
