Landis 1 or pearson 6 bobbin winder
Northmount replied to T Moore Medicine Hat Saddlery's topic in Leather Sewing Machines
Try Leightons http://www.leightons.ca/ located at Delburn AB, northeast of Red Deer if I remember right. Tom -
There are threads here about using arbor presses for stamping. One thing to do is drill the arbor press ram to accept a tool handle that is used with alphabet stamp sets such as available at Tandy and other re-sellers. Some of the sets are large enough that you may be able to press directly on the stamp. Anyhow, I'd get the set of stamps of the size and style you want, then see what you need to do with the arbor press. If the search doesn't work to your satisfaction, you can do a google search and include this directive in your search string. site:leatherworker.net It will restrict your search to this site. Tom
- 10 replies
- arbor press
- customization
(and 1 more)
See the marketplace rules here http://leatherworker.net/forum/forum/70-announcements/ Pictures, model, etc. Tom
Please read the marketplace rules: http://leatherworker.net/forum/forum/70-announcements/ and abide by them. Tom
Help choosing first machine
Northmount replied to Kermode Custom Leather's topic in Leather Sewing Machines
There is a Cobra re-seller at Longview, about an hour south of Calgary off highway 22 that you might be interested in. See their FB https://www.facebook.com/longviewleather/?hc_ref=NEWSFEED&fref=nf or their website http://www.longviewleather.com/ There is another company SE of Edmonton at Delburne that sells industrial leather sewing machines. http://www.leightons.ca/index.html Both these companies are within driving distance if you want to see and try out their machines before you purchase. Tom -
Links don't work. Can you try again? Tom
Techsew ships here, had mine dropped off on the curb in Calgary, unpacked the pieces from the pallet, bought them in and had it running within 2 hours. I see from your IP address you are in Edmonton. The 2700 series, max bobbin thread is 138. I have run 207 on the top. Note max leather thickness is 3/8". Get it with a speed reducer pulley set. Cylinder arm is great and you can build or buy a table to use it as a flat bed. Phone Ron and talk with him. Tom -
They are unique. I was interested to see examples of Aussie flowers, etc. Whether you like the flowers or not, the style and instructions for applying and working with dyes are top notch. US/Canada, you can arrange to buy from Peter Main in Houston. Tom
Hi MarcinB Please add your location to your profile so people know where you are. Tom
You can do a Google search restricted to this site. Include "site:leatherworker.net" along with your search terms (without the quotes) and you can use all the advanced functions of Goggle search. Their search engines have indexed millions or billions of web pages and are faster and better than what this site uses. Try it out and see. Tom
If every one would include their location in their profile, it would be easier to pick out who is near you. Also people near you are more likely to respond. Hope to see you back here soon. Notice you haven't accessed LW since September 2016. Tom
@JohannaI'm seeing the same thing on all dialog boxes. No text, and text missing from buttons. Tom
I get the same result. Try a Google search using "site:leatherworker.net others may" without the quotes. You will get lots of results. Tom
Moved your post to Leather Sewing Machines where you are more likely to get a response. Help wanted is like the classified ads in a newspaper. I'd suggest you should join the forum here. Lots of good information available and you may contribute your experience and expertise too. OP appears to be located in Simi Valley, California, 93065 according to the IP address. Tom
For a gradient, have you tried using an airbrush? You can use any dye for the process. Dye by itself doesn't create a gradient. It is how you apply the dye that does the job. Tom
nubbies on the bottom when turning and other headaches
Northmount replied to longun45's topic in Leather Sewing Machines
You don't have skipped stitches at this point, but this little piece of info goes along with Uwe's comment above about making turns. When you make your turns, either do it just as soon as the needle is buried in the leather, but not to the bottom yet, or wait until the needle bar has risen far enough for the hook to have caught the loop. The aim is to not affect formation of the loop, and to ensure the hook catches the loop, or you will have a skipped stitch. Tom -
Pictures would help describe the problem. Tom -
I can't see the lines in the photos, so assume you are talking about the marks left by the presser feet. You may be able to reduce the pressure of both the inner and outer feet, to help reduce the amount of marking. Also make sure the leather is dry. Wet will of course mark easier. You can work out the presser feet marks with a spoon, or by tapping with a flat faced hammer. If you reduce the pressure on the presser feet too much, the leather will lift with the needle, and you will lose the loop and have skipped stitches. There are lots of related posts in the sewing machine area. Oh! Great collars. Tom
OP is located at Wasaga Beach, Ontario according to the IP address. Please peoples, add your location so you can get the best information and help from people located in your area of the world. Tom
70s Western belt
Northmount replied to lablevens's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
When you pull the lace tight on soft or moistened leather, the lace will compress the leather and partially embed itself. Space between stitches for the most part, isn't puffed out by any amount. Just not compressed. Tom -
Please all read the market place rules. http://leatherworker.net/forum/forum/70-announcements/ Tom
Some people just don't have the capability of visualizing things in their heads. For those people that have this capability, it is difficult for them to understand that others don't have it and seem to take forever to understand some of these things. When I took electronics many years ago, I could visualize how electricity flowed through different devices and its behaviour. Couldn't understand why others couldn't grasp the concepts. Then when I used to instruct control systems engineering, I found that students just want to memorize the answers for today's exams, but not to spend time learning the basics so they could then build on that to better understand the next steps. I have a mantra, If you want to be able to control a process, you have to understand the process before you can control it. I think this really applies to all types of troubleshooting. The part of my work over the years that I have enjoyed the most is troubleshooting. Being able to visualize it in your head, and to at least mentally collect the details of what has happened, or is happening makes the difference in being successful at troubleshooting. Tom
