Moved your post to leather sewing machines
Could be an expensive shipment. This is a world wide forum. So you are saying you would ship free to Europe, South Africa, Australia, South America, etc.
- 4 replies
- beveling
- edge bevelling
- (and 6 more)
You should post in the Marketplace > Wanted section instead of posting on 9 year old posts that have nothing to do with buying or selling a machine.
This is a world wide forum. Shipping anywhere for free? Pictures of what goes with the machine would be helpful. See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/
Moved your post to leather sewing machines.
presser foot lifting during stitch
Northmount replied to jollyroger's topic in Leather Sewing Machines
It definitely has to do with thickness, density and hardness of the leather. It is gripping the needle and rising with the needle. Moistening the leather will make it softer, easier to pierce and retract. It will also leave more machine marks. Are you using a leather point needle? It looks like you are, and should be better than a conical point. -
I'd be careful of how much NFO I add to the leather. Too much and you have a soppy mess. It should help. The thread would likely break before it would lift the presser foot. Lubricated thread lubricates the needle so helps. Some members have sprayed their thread (on the cone) with silicon spray and let it soak in well. You might even hear a squeak as the needle pulls out of the leather. -
You should have noticed that the leather is lifting the presser foot. This happens with dense hard (and thick) leather. The needle sticks in the leather and pulls the foot up with it. Of course that destroys the loop so the hook can't grab it. Increase the spring pressure on the presser feet. Lubricated thread can help too. -
Buy a second set of feed dogs and grind the points off if there is enough adjustment room. Some people apply a strip of tape to the underside of the material they are sewing. Make sure the tape doesn't leave a sticky residue on your leather when you pull it off.
Need help with old machines for stitching soles and outsoles
Northmount replied to Pyrka's topic in Leather Sewing Machines
See some info here. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/ Please avoid using 3rd party hosting as those pictures go missing when owner moves or deetes files, or the host decides to change policies. The the post becomes useless. Many members will not view unknown sites so would not be able to help provide the information you are asking for. -
You've got me beat by about a year. I started digitizing my magazines about 20 years ago. I was running out of shelf space between magazines and reference texts for engineering and computer programming. 2 each 4' wide shelves 6' high. Then there are the rest of the family's books. At one count 1500 approximately. I had even dumped a ton of photographic and power engineering magazines that I wish I still had. Had pulled all the ads out and stapled the informative articles and stored them in bankers boxes.
The foot has a slot cut in the front of the toe so you can see the needle and the leather as the needle approaches the leather. You can cut and grind out the foot yourself. No need to buy another foot just to get an open toe.
He hasn't been back since November 2 even though tagged December 5. So I am archiving this thread.
As Klara says above, create a database so you can search and find the articles you are looking for. Especially if you scan the magazines. Include Magazine name, volume number or date, article name, short description, up to 6 key words.
Moved your post to the Marketplace > Items For Sale > Supplies and Hardware See the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/
Adding pulleys to slow down a Consew 206RB
Northmount replied to melinda's topic in Leather Sewing Machines
First, I would get rid of the clutch motor and replace it with a servo motor. You can find lots of info and comments on servo motors here on LW. Many motors mounting brackets allow you to move the motor to one side or the other. You probably will need to move it to the left. If the bracket doesn't allow for sideways adjustment, then figure out how far the motor needs to move, plot positions for new mounting bolt holes in the table, drill new holes and move the motor and bracket to the new holes. Note the new position (center-line) of the small pulley on your speed reducer that drives the machine pulley should be behind a perpendicular center-line of the machine pulley so you can tilt the machine head back like before the addition of the speed reducer. -
@lovemycarbs If your files are too large to post here due to file size restrictions, you need to resize your files to fit. Follow this link for some helps and suggestions. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 There are lots of Apps, software, and online tools available on the web, or even built into your device to enable you to reduce your file sizes. 800 pixels in the longest dimension is quite adequate. Smart phone screens and many monitors don't display high res files in high resolution. People that live on the fringes of the internet appreciate smaller file sizes and high res photos may take from 10 minutes to hours to download. Reducing your pics to 800 pixels in the longest dimension will produce files in the neighbourhood of 50kB, lots of room to post many pics.
I collected a few hundred woodcrafting magazines over the years. Then one day decided to scan them to PDF files, then disposed of the original magazines. Pages that were only ads, I deleted, unless there was something I wanted as a reference. Pull-out pages that were just regular page size, I split and scanned. Depending on your scanner and software tools, you can splice the pages. Later I got a scanner with a carrier that scans both sides of a folded page (up to 11x17" folded to 8.5x11") and joins them automatically. You do have to do those pages individually, versus using an auto-feeder. If you are looking at purchasing a new scanner that scans both sides of a sheet simultaneously, look at ScanSnap. It was a huge time saver for me. Scans to PDF. Just cut the magazine into single sheets, remove garbage pages, stack in the scanner and go. Scans both sides of each sheet in less than 2 seconds. So a typical magazine can be scanned in maybe 2 minutes, plus the time to separate into single sheets. There was a series of magazines that had large pull out pages 21" x 31" that I have stored in pocket folders rather than cutting them up.
You already have this posted in another thread by the same name. DO NOT DO MULTIPLE POSTS ON THE SAME SUBJECT. In that post a member told you the picture was unrecognizable. So posting it again is no help nor a solution. There are numerous resources both here and others on the web. Do some research on your own looking at different rivet styles, different types of snap, etc. You can look through online suppliers like https://tandyleather.com/?country=US, https://www.weaverleathersupply.com/, https://www.springfieldleather.com/ and others. There are loads of YouTube videos you can search and look at. The suppliers listed above have videos available as well, usually posted on YouTube. I'm locking this thread rather than leaving it to be commented on by you or others.
Great reference material!
Look at this thread
@lovemycarbs Or if you work in inches, 1 oz is 1/64" thus 8 oz is 1/8" and so forth.
