Nice job. Now let's see your new "master" wearing it! Tom
TechSew 2700 Leather Walking Foot Industrial Sewing Machine
Northmount replied to Stormdagger's topic in Old/Sold
And your selling price is ??????????????? Tom -
The noise/squeal of that motor would make me even crazier than I am already! Tom Chances are a diode or SCR is shorted out. If so will cook the windings or some part of the circuit before long. The squeal is similar to the sound of a shorted diode in an alternator. Then the windings start to stink as it gets worse.
IP address places the OP in Quebec Since this is a world wide forum, it would be really nice if people would include their location in their profile. The would get better info with searches for equipment, etc. Would know what their dollar is. Tom
Something strange! Usually top tension increases with a thicker thread if you haven't adjusted anything. Seems strange you have less top tension. Go back to 69 thread and make sure it still works, then try 90 on top with no adjustments to see what you need to change. Then go for 90 on the bottom. See what result each change produces. Tom
The type of servo motors used on sewing machines follows the general rule for most motors. The slower the motor goes, the less torque there is available. So the idea for tough or thick leather is to use both a servo motor and a reduction pulley or gear reducer set. The servo motor gives you easier speed control versus a clutch motor, and the speed reducer lets you run the motor at a higher speed so you will have the torque necessary to punch through that first stitch, or to crawl along at a stitch per second, or even slower depending on your setup. I can go as slow as 7 seconds per stitch, but the high end speed is severely reduced. Tom
The clutch motor's torque remains constant, however the lower speed at the sewing machine results in increased torque at that point, so yes, will punch through tough items more easily. The inertia in a clutch motor also helps punch through that first stitch. It doesn't usually stall. Tom
You should specify your location. From your IP address you appear to be in Texas. This is a world wide forum. Some description of the type of hammer you are looking to repair would be helpful too. Is it a claw hammer with stacked leather rings in the handle, or a rawhide mallet, or ... ? Tom
Pfaff 1245 presser foot bar adjustment
Northmount replied to OldMercedesGuy's topic in Leather Sewing Machines
Really now! 7 posts all the same! Don't keep hitting your submit button. Give the server a chance to do its job. It may be busy with other posts, or you may be on a slow network connection. Tom -
Really! Duplicated 4 times. Please don't keep hitting the save/submit/post button several times. Give the server a chance to do its job. It could be busy or your network/internet connection could be slow, so you don't see the response happen instantly. Tom
Walking Foot Material Feed Problem -- Shifting
Northmount replied to JJDD's topic in Leather Sewing Machines
My 2700 tends to feed towards one side as well. Doesn't sew straight without being guided. Tom- 20 replies
- edgesewing
- materialfeed
(and 2 more)
Resize photos to 800 x 600 pixels. For your file that is being a problem, try emailing it to yourself and see what happens. In Windows Explorer, select the file, send to recipient, etc. The file might be corrupted, but I would question that if you can view it without problems. Is the file extension .jpg or .jpeg? If it is .jpeg, try renaming a copy. Tom
Leather Secrets By F. O. Baird $75
Northmount replied to Maverick Leather Company's topic in Old/Sold
And your asking price and shipping? Tom- 15 replies
- leather craft
- f.o. baird
- (and 4 more)
And the problem and repairs were ?????? I think all those following this thread would like to know. I certainly would. Tom
Take the belt off and rock the drive pulley by hand, else you are likely to do more damage. When a machine is locked/seized up, trying to power through is looking for a lot more damage and problems. Have you got the bobbin, carrier, and hook out? If not pull them out so you know they are not jammed. Tom
Moved to 'how do I do that'. Punch two holes, cut the slit between with a sharp knife. Or buy a special punch from Tandy or other supplier. Tom
- 9 replies
- buttonstud
- rivets
(and 3 more)
Part 2 merged with original post. Let's keep related posts/problems together so we can see the development and trouble shooting steps that are taken in one thread. Was the machine threaded, including top and bottom while you were winding your bobbin? If so, there is likely a bunch of thread piled up inside the bobbin and carrier that will have to be removed. Then you should be able to reset the clutch. (Not my type of machine, so take this with a grain of salt.) Tom
Singer Leather Sewing Machines
Northmount replied to Trevor Baret's topic in Leather Sewing Machines
Here is your first post. If you go to your profile at the top right of the page, you can see a listing of your posts. Tom- 53 replies
See this post Tom
Finally getting started, but where to begin?
Northmount replied to Rustedmoon's topic in Getting Started
From the IP address, the OP appears to be located in Singapore. I would advise all members to at least add their country, and maybe the state as well to their profile. It will enable people who live in the same general area to give you more helpful advice. Tom -
Has a nicely shaped yoke, so is easier on your fingers. Barrel diameter appears small, but some like the smaller diameter. I like 5/8" diameter. Just feels better. Adjusable height would be nice too. If you can, depending on location, ask to try them out before purchase. But since Tandy has a good guarantee, you should be able to take it back if it doesn't suit you. Tom
This is an excellent example of why photos should be sized to fit here, and posted here. When they are moved or deleted later, maybe even 5 years later, the thread may become useless as the examples are no longer available. I encourage everyone that posts photos of their work, to post them to leatherworker.net either as a part of your post, or in a leatherworker.net gallery which you can then link into your post. Everyone will appreciate it. Tom
OP hasn't logged in since joining on Aug 25. Tabitha, You have a response to your query. Time to log in again! Tom
