Northmount
Moderator
  1. Thread (and belts on conveyors or flat pulleys) always climbs to the high side. Tom
  2. oltoot sent me his photos and instructions so I could put them together and upload them here. Took a while to get here since the cable company accidentally disconnected me and took a week to come back and fix it. Hope you all appreciate oltoot's work. Tom Ground Seat Instructions.pdf
  3. Looks like the OP moved them or changed access permissions. Looks like they were posted on a photo sharing site instead of on this site. Tom
  4. Tell your prospective buyers where you are located! Tom
  5. Northmount
    Darkhand
    I'm sure someone does. Tell them where you are located! Tom
  6. Take a look at these links https://www.facebook.com/KingsleyMachineCo/ http://www.ebay.com/gds/BUYING-A-HOT-STAMP-MACHINE-/10000000000751965/g.html Kingsley are good presses, but are now antiques. You will need to have some method of attaching your brass stamp to a block in the type holder. The double sided tape makes that easy. There is very little working space under the type holder, so would be difficult to place the stamp, press it down to heat it up, then remove it, place the stamp on your leather, then move the package back under the type holder, keeping everything perfectly in position. When your stamp is properly attached to the block in the type holder, you let it warm up to the desired temperature, position your leather, pull down the lever pressing the stamp into the leather for a few seconds. The dwell time you need depends on the foil, leather, and amount of pressure you apply. Tom
  7. If you use leather point needles, don't back tack. Leave your thread tails long and do your back stitching by hand, doing a saddle stitch. Tom
  8. OP's IP address is located in Wisconsin. You should be posting photos and complete description, etc. according to terms of use of this forum. Tom
  9. My iPad doesn't like either file, but my PC has no problems with them. Tom
  10. I think you should copy this to a new post so you get the exposure that you want. Tom
  11. LOL You might want to rename the files to Cylinder Arm! Tom
  12. Merged your two posts into one and moved it to "Leather Sewing Machines". As mentioned above, you will get more response from this area rather than "How do I do that". Also deleted your multiple posts. Don't keep hitting the "Submit Topic" button after you have already hit it. Give the server time to respond. Tom
  13. OP appears to be from the New York area according to his IP address. Tom
  14. Moved your post to leather sewing machines. You will likely get more response there. Tom
  15. Cut a leather gusset, cut a slot in it for the zipper and stitch the zipper into it. Cut the gusset a couple inches longer than the edge you are connecting it to. Run the ends of the gusset down into the spine, as if it were a book cover. Find the exact centre of the gusset, and exact centre of the sides of the purse and glue or temporarily stitch or staple in place. You can have the zipper unzipped while doing this. Line it all up, glue or staple in place with the gusset wrapped down inside. Don't stitch the ends of the gusset into the spine, but let it float. Sew it up, done. Tom edit If you want to keep the purse real thin, just use the zipper like you did, but get one long enough to go about an inch around the two end corners, and cut a slot for the zipper to fit into. I would still find the exact centres to match up so the zipper is not accidentally distorted and hard to zip.
  16. Northmount
    Bespoke wallet
    You might like to let people know where in the world you happen to be. From your IP address, it would appear you are near London, UK. You will find it easier to deal with people closer to you rather than thousands of miles away. Tom
  17. Make sure your top thread is between the tension disks, not just riding around the outside. Has to be between the disks to work. Recheck your thread path to make sure it is threaded correctly. Tom
  18. Show us some of your new work! Tom
  19. Nice looking bag and Oak Leaf. Tandy sells "Craftaids" with all sorts of carving/tooling patterns. Tom
  20. As mentioned in one of the posts, observe what the needle and hook are doing so you can decide what action you need to take. I try to make turns either as the needle is entering the leather or just before it exits. Also not to lift the presser foot too high and lose the top tension. Tom
  21. Located near Autin Tx according to the IP Address. Tom
  22. From the OP's IP Address, he is likely located in Southern California. Tom
  23. See Kevin King's tutorial making a wallet. Comments call it a rolled edge, french roll, bound edge. I think that french roll is the correct name. Here is another rolled edge. Single layer, not bound. Tom
  24. And you are located where?
