Moved to "How do I do that" Tom
For Firefox, look at https://support.mozilla.org/en-US/kb/how-do-i-use-firefox-spell-checker. It used to be an add-in but is now part of FF. I've been using FF as my preferred browser for several years. Tom
Iphone Case
Northmount replied to Mark Peters's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice looking. It is really hard to get rid of nicks and dings in leather. Some can be burnished out, but might require a large area to be burnished to blend to smooth leather. For blood, dab it off immediately, then use lukewarm water dab it on, dab with a dry cloth to absorb the water and blood. Try not to soak it too much and avoid spreading it out further. Bleach with oxalic acid. You will likely have to bleach the whole piece to get an even colour. #1, don't cut yourself, and if you do, drop your work and get away from it, go look after the cut. Then come back to it, hopefully with no blood splatter! Tom -
I clamp a couple pieces of wood on the front and back, lined up with where you want the corner. Heat with a heat gun until it will bend easily, not too much or will make wrinkles. Press the heated side of the corner against your granite slab or cold counter top and hold for a moment until it cools off. Tom
Pancake Knife Case
Northmount replied to LoneWolf1973's topic in Gun Holsters, Rifle Slings and Knife Sheathes
For slots, punch a hole at each end and cut out between with a sharp knife held against a steel rule. Tom -
Seal/finish them front and back to reduce the water absorption. Should help some. I second making them 2 layers. I did a small sample about 4x5" for a 3 ring binder cover. 7-8 oz front, stiffening material, and 3-4 oz back. Both sides sealed. Seems quite solid. All glued together and edges are stitched. Tom
Spell checker is part of your browser (or in some cases Operating System). Some browsers have add-ins or extensions that you can add. Tom
http://www.amazon.com/Duck-240225-Repair-Aluminum-1-88-Inch/dp/B0000DI82JThere are various types/manufactures. Search aluminum foil tape Tom
3 Fords, 3 failed transmissions requiring complete rebuilds. 1 tranny took 3 rebuilds before I could drive 100 miles without problems. All the reusable parts tolerances all added up in the same direction, so they had to replace all hard parts. Multiple GM versions of cars, no transmission problems. Tom
Cut a strip with and without contamination and test it. Then you will know how much you need to use to cover it. Have you tried deglazer? It might work, again you need to test it. Different dyes (manufacturers) may respond differently too, so one person's experience might not work for another with a different source. Tom
Try http://www.leightons.ca located south of Edmonton, new and reconditioned used machines. Tom
Yes, there are several posts. If you've found only one, continue your search and you will find them. "apartment" might be one of the words to search for. And welcome to the forum. Tom
The point I was making is that water is a solvent, so a solvent based finish doesn't tell much about the type of finish. For your edification here are a couple links you can look up. https://water.usgs.gov/edu/solvent.html http://en.wikipedia.org/wiki/Universal_solvent You could do a Google search and find many more if you are so inclined. Our purpose here is to help members and visitors learn and develop their craft and abilities. Think about it, then review your comment. I think we all know that there is no universal solvent that will dissolve all types of materials. If there was, what container would you keep it in? From my limited experience, acetone doesn't contain water, but will still lift water based dyes. Tom
Water is the universal solvent. So describing a finish as solvent based does not say what the solvent is. A lacquer type finish uses acetone or similar petrochemical solvents. A water based finish uses water as the solvent. Most petrochemical solvents will soften or dissolve many water based dyes and finishes. Before applying a finish, water based or petrochemical based solvents, make sure the dye has properly dried and buff the surface until no more pigment lifts off. Then apply your finish. Avoid too much scrubbing action, or you may lift some dye back to the surface and spread it around. Water based finish on water based dyes don't usually lift too easily. But lacquer types will lift water based dyes quite easily. So air brushing light coats rather than a scrubbing action is less likely to get you into trouble. Air brushing or sheep skin applicators or brushes work. They all take some practice to work out the best method for your type of work. So do some experimentation, develop what works for you, then stick with it. Tom
One thing to consider with an axe sheath, how long is the axe handle? I don't like having to feed 3 feet of handle through the sheath to put the sheath on or take it off. So for this case, I prefer a welt at the sharp edge of the blade, and a flap that folds over the head. Instead of a flap, can use a strap angled to run across the handle, just behind the head. For a short handled axe (read hatchet), handle length is not as much of a factor. Tom
There is a type of aluminum foil used for sealing joints in furnace and other ducting. It comes with self-stick glue and tear off strip. Typically 2" wide rolls. So could easily be used to line pockets. Tom
Welcome to the forum and hopefully, the addiction. What type of work are you interested in doing? Lots of avenues to pursue. Tom
Just reminded from another post here, be consistent with the direction the thread pulls off the bobbin and passes through the tension spring. If it was originally installed to double back, and you flipped it over, it would now have less tension. Tom
If that is where you started from, did you hold onto the threads when you started? +1 on waiting until the needle is rising and the hook has caught the loop before going to reverse. Tom
Aspen here in the NW North America is pretty soft/weak. I'd trust Douglas Fir a lot farther than aspen. Tom
First off, take the bobbin and basket out and make sure there are no bits of thread, or needle tip etc. down there. If it was working well before with your bobbin tension setting, it should now too. Tom
I think this is the best one yet. I think, at least for me, the shallow embossing works better. You are really having too much fun now. Tom
Looks like Baltic Birch would be a good substitute for the plywood (laminated) parts. Likely Fir plywood would suffice, but wouldn't look as nice, also a little weaker. Tom
If your software gives you a choice, resize to 800 pixels wide or file size about 150 kB. This one is too small to see any detail. Tom
- 14 replies
- tooled leather
- saddle
(and 1 more)
