Northmount
Moderator
  1. I'm jealous. Really nice work. Tom
  2. Pretty nice job. Tom
  3. Is this a problem on multiple computers, or only one? If this is happening on multiple computers, using the same cable, then try another cable. Does it still work on other computers running other versions of windows? If it still works on other versions, with the same cable, then cable and camera are still good. Prove each piece of hardware works before trying any software fixes where they don't seem to be helping. Tom
  4. Here are a few links that might help. The third one is your specific model and MS windows 7 forum http://www.sevenforums.com/hardware-devices/184798-olympus-camera-photo-import-problem-windows-7-a.html Compatibility X-760 is compatible http://www.olympus.co.jp/en/support/imsg/digicamera/compati/win7.cfm http://answers.microsoft.com/en-us/windows/forum/windows_7-pictures/windows-7-does-not-recognise-olympus-x760-digital/5eb087dd-b3fa-4d40-b839-161b18d30515 Tom
  5. See http://leatherworker.net/forum/index.php?showtopic=44325&st=0 Tom
  6. Either a knee operated or foot operated presser foot lift is fine. For me, I have a bit of a knee problem. Hurts to twist to the side to operate the lift, so for me, the foot operated lift is much better. Tom
  7. Or an old credit card or such. I don't like taking the tip off a knife running it over metal. Tom
  8. The image on the right is a digitally controlled servo. The other 2 aren't. The left 2 have a potentiometer to adjust the top speed, analog control. Digital may have additional functions like ramp rate, reverse, ... Digital should have better torque at minimum speed. Depends on model and manufacturer. Horse power or Watts is more important. Tom
  9. Cute, let's see you wear that through security on your next plane trip! Tom
  10. Yes, all things the same ... Identical setup each time so all your processing can be consistently the same. Tom
  11. Laser engraving is definitely more flexible and faster. Have so many fonts and graphics available to use without having to have custom plates made or spend time setting up type. I guess I should find someone around here that can do it. Tom
  12. If you take all your pictures under the same lighting conditions and do all your editing with the same color and contrast/brightness settings, you should be able to add photos later and have them all look the same. Try to do the same with camera position, zoom, aperture, speed and any resizing in PS. Then sizes should also be relative to each other. Tom
  13. A finish should be applied over the laser work too. Another way of adding text or even graphics is hot foil stamping. My son used to have a setup for doing business cards and such. Stamped people's names on bibles too. After he lost interest in it, we gave it away. Now I wish we still had it! Even just the press action without the heat would be nice to have. Had several sets of type with it. Used to get plates made up too. Oh well! Such is life. Tom
  14. When taking your photos, keep the lights low, raking across the surface (from one side). This will show the 3D effect much better than the typical setup. Gives deeper shadows in the impressions. Google some landscape photos that are taken when the sun is low towards the horizon. You will see what the low angle light does. And yes, use leather for your samples. That's what it is all about. Tom
  15. I find that by the time I glue and stitch, I need at least 3/8" extra for each stitched side, else it gets too tight. 1/8" for stitch, 1/8" for glue beyond the stitch line, plus 1/8" to allow slide fit. You should be able to find the dimensions for the Macbook on Apple's website. Then cut a piece of wood to the same dimensions to test fit. Tom
  16. Nail polish remover is acetone. It is also used as lacquer thinner and for cleaning up fibreglass resin. So is available at hardware and paint stores, also automotive stores that sell lacquer paints and fibreglass resins and cloth. It certainly does soften and remove many glues, paints and other surface contaminants. Tom
  17. There are some older threads about cutting and layout surfaces. Somebody is getting 4x8 or so sheets of some sort of polyboard. Do a search if you are interested in more info. Tom
  18. Northmount
    New Year Baby
    I think this is pretty neat! The baby is the part that catches my eye. Colors are good too. The only distraction I see is the slightly inconsistent border. Remember to have fun with your work. If it is getting you down a bit, go onto something else for a while, then come back and take a fresh look at it. Tom
  19. Looks like an interesting little project. I've seen some others here that are fancier, but fancier isn't always better. I would like to see a shot from the stem side as well. Some of the petals have a lot of hair from the flesh side and rough cut. Need to try to get a cleaner cut edge. All the petals have the same curve. Try cutting some with a small depression midway on the petal and see what it looks like. Are all the petal pieces the same size? It looks like they are. Try narrower petals for the center, and gradually wider as you build up the next petal layers. I remember some 55 years ago making similar roses with thin coloured foam sheets. Brings back memories. I think you have a really good start here. A little more experimentation with petal sizes and shapes, maybe even some colour, and you will have an outstanding rose to show off, sell, etc. You can start making bouquets of long stemed roses. And keep having fun with your roses and such. Tom
  20. If it must be punched from the outside, take a short length of 2x4 or 4x4 wood. Round the edges down somewhat and use it. Punching into the end grain gives cleaner cuts generally than into face or side grain. I like the idea of punching from the inside better. Less work, less to have to hang onto while punching. Tom
  21. Do a search. There are a couple threads here about the same problem. If I remember right, burying it in a bag of cornstarch removes oil. Takes a few days. Tom
  22. Homedepot has several diamond sharpening "stones" like this http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=203381318&R=203381318#.UMU9BXy9KSM You need extra fine, so need to research a little to find the best. Also consider higher end woodworking tool stores. There are several threads here on sharpening swivel knives. Do a search for them. Tom
  23. Get a heater! My hands don't work at 33F. Bring what you need into the house as you need and take stuff back out before the next step. Lots of trips somedays, but a lot more comfortable. Things don't apply and dry as well in the cold either. I usually wear old denim jeans and shirt. When working in the garage/shop, I often wear an old leather jacket. I set the T-stat at about 63F, so it's a little on the cool side, but good for heavier work. Sitting doing close work, I raise the temp so my hands aren't cold. Tom Wood stove is a good idea if you have lots of cordwood or scrap around to burn. Used to use an old sheet metal wood heater ... sort of like a big tin can.
  24. Is the edge truly sharp, faces polished so there are practically no scratches? Is the leather properly cased? Too wet is no good, and of course dry isn't any good either. Close up in-focus pictures of the blades both profile and flat, as well as of your cuts would help someone here to give you good direction. Tom
