Constabulary
  1. I´m using an 8mm V-Belt on my 108w20 - no problems!
  2. sorry - mistyped or misread - you have 211G266 - not 166. Still, the 211G266 also has 5.1mm stitch length. Here is an extract from a Singer sales brochure:
  3. well, when you already figured your problem is on the underside of the machine then a picture of the underside could probably help. However I guess the stitch length "problem" is solved since you have a 5mm stitch length on your 211G166, right? Anyway - the 211G166 has 5.1mm and the 211G165 has 7.3mm - thats true. But as far as I can tell the 211G165 has no reverse.
  4. The longest stitch length on the 211G166 is 5.1mm so when you are at 5mm you have reached the max. I´d say. Better post pictures of the actual machine.
  5. Agree with Bob - however, I once had a pals 45K darner on my table and he asked the same thing. Fortunately his 45K (don´t recall subclass) had all necessary parts. I guess back then Singer or maybe a dealer took a 45K sewing machine of the shelf then just removed and added some parts an converted it into a darner. So I was able to convert it back into a sewing machines. But you never know - when the parts are not present it makes not much sense.
  6. Post some pictures please. Remove the needle plate and check if the lifting cam frame to which the feed dog is attached is present. It looks like this (91160) and rides on the bushing of the shuttle driver (98608) the shuttle driver needs a "bulge" on the bushing because it controls the up and down movement. Most important is if the machine has the shaft that controls the back and forth movement of the feed and if it has a stitch length controller "device".
  7. Post some pictures so we probably can ID your machine. Could well be that the badge is from a different machine . Maybe one of the former owners (not necessarily the last owner) had different Class 17 machines in use... So true! I´m always surprised what I find in my own drawers.
  8. Shuttle race looks like a plain CB shuttle race. Noting unusual as far as I can tell from the backside of the race. Im not 100% sure but the 44-79 seems to be a shorter version of the 31-19 so the timing values should be the same. You can download a manual for the 31-19 here Manual for Singer 31-19
  9. it was just an idea I have to look up the machine similarities as well but the Seiko or Consew website may show machines similar to your Singer 168w or 17
  10. or lower the tape guide and / or set it further way from the foot towards the operator - but I only can guess cause I don´t know the whole setup.
  11. What is called a service manual often is just an "advance user manual". I have never ever seen a real service manual for the vintage Singer industrial machines. I mean in terms of stripping and reassembling a machine. Not saying there are none but I have never seen one or even heard of them. Often the user manuals include some advanced technical information for timing and replacing timing belts (Singer called it arm shaft connection Belt) and the so forth but that's it Maybe there is a chance when you look for later made Singer clones of your mentioned machines (like Consew or Seiko). Maybe the clones have more detailed service manuals (but I honestly doubt). A lot of the nowadays clones are based on the older Singer machines. However, if someone has a service manual I hope he´d share it here!
  12. D or S tip needles are indeed hard to find in system 328 / 214x2. Unfortunately I have no source. I would check with SCHMETZ or GROZ BECKERT customer service maybe they can help you. R tip needles you can buy from College Sewing in the UK. https://www.college-sewing.co.uk/needles/groz-beckert-industrial-needles/214x1-groz-beckert-needles maybe they have other odds and ends you could use like bobbins, thread nips, screw drivers, needle threader.... I always order thinks like that.
  13. Needle should be system 16x4 if not set to a different needle system (f.i. 137x17) - thats not unusual. See attached manual - it should answer most questions. Machine should be pretty much the same (beside the B and W suffix). Minor differences may be possible. If you are looking for information or parts look for Singer 136w machines 136W100,W101.pdf
  14. That is because of the LR tip needles. I would use S or D tip needle for a straight seam. Check this website: https://www.schmetz.com/en/industrial-needles/needle-compass/cutting-points/ Or check this PDF brochure: GrozBeckertCuttingPointsBrochure.pdf
  15. Adler 205 came in different subclasses - what subclass are you talking about?
  16. I´m not 100% sure but do the 111 clones have the singer type "Foot Lift Eccentric" on the top shaft as well? AFAIK the clones have the slide cam (right word?) just as the Pfaff 145 / Adler 67. Or am I on the wrong track? Like this? EDIT: The manual came from Keystone Sewing: Juki_LU-563_Instruction_Keyfooter.pdf
  17. and what clone is it? Please post some pictures. Hung on the raised material I guess , right? Usually there is a cam on the backside where you can adjust the foot height.
  18. BY FAR - one of the coolest leather bags I have seen! EXCELLENT!!! They should sell like sliced bread I think!
  19. interesting that nowadays everybody is expecting a video instead of looking for a manufacturers manual. I googled it for you ls341n.pdf
  20. I guess its a SEIKO made but Singer labeled machine. Serial number does not help (me). The 51w has a shorter bed and a slimmer body / upper arm than the 136w so to me it looks like a 136 class machine.
  21. or post a Youtube Video but please not only 5 seconds or so
  22. Class 136 (usually 136w) I´d say but unsure ob subclass. Butt looks like a Japanese made machine so W prefix may not be right. Look for 136w100 - this could be at least very close to what you have.
  23. It´s really worth it to keep old machines (not only sewing machines) alive or bringing them back to life - very rewarding! I´m not necessarily a green guy but I´m convinced that we have way to much junk products in our world today and we by far do not enough recycling so its a tiny bit of environmental protection too because things we restore don´t have to be produced new (under unknown circumstances) and shipped over the ocean just for using them for a short period of time. A lot of things are already there - just brush them up and use them again! I can send you an instruction manual for the 108w20 when you send me your email address by PN. It would also be nice to see what you are doing on your machines so if you have the time please open some restoration threads for your machines
  24. it for sure will get a decal - who do you think I'am? NB thread guide is back on too - found a couple of NOS guides. Did some testing yesterday - max. material thickness it can handle is 6.5mm - 7mm then the jump foot stops working but it still sews. But you cannot block the jump foot to stay static (as on Adler 4 / 5 machine) so practically this thickness is the max.. Maybe I can tweak it a bit more but I doubt!
  25. few more close up´s in it´s "natural environment" - I like the 1st picture with the nice SIMANCO stamps. Kinda starting to like this old sucker
