I barely need one but I´m using the one fredk shows as well. They are cheap on ebay like 6 bucks or so. Well they all come from China anyway. I have polished / sharpened the blades with jewelers rouge on some scrap leather and I´m actually very pleased with it. F.i. https://www.ebay.de/itm/364005525549
Not sure what the subclass 11 includes but the major difference usually is with what accessories the machine once left the plant. What I can tell form this single picture is that it is a drop feed machine w/o reverse, it has an outdated clutch motor (you will not like it cause it is very fast and most likely not easy to control). This is the 2nd model of the Singer 51w. It has a plain presser foot instead of a roller foot. Some parts are still available but not too many. IMO the 2 plats on the machine bed look kinda odd and I don´t think they belong to this machine. Price wise i think it is too expensive for what it can do but on the other hand post bed machines are harder to find than others. If you buy it make sure the stitch length adjuster is working and nothing it broken on it. Also make sure the timing belt is in very good condition cause AFAIK they are no longer available. The 51w when it came from the factory was set up for a nowadays rather odd needle system 128x3 / 128x4 (or similar) but you can convert the needle bar for using a more common needle like 135x16 or similar. See this link: https://leatherworker.net/forum/topic/96574-singer-51w56-needle-bar-conversion/ I have the 1st model of the 51w and I like it very much but to be honest I´m barely using it. I did a needle bar conversion and a presser foot bar conversion as well but that was cause it still was the 1st model based on a Wheeler & Wilson machine. If you are interested: https://leatherworker.net/forum/topic/86292-singer-51w-sv-2-post-bed-machine-restoration/ Maybe you can give us an idea of what you want to sew so we can try to suggest some other machines. If you need more machine details of the 51w class you can download some 51w manual here:
That is what I was thinking too when I was new to sewing machines. Not that does not work! But you can turn around the product you sew and make the back stitch that way.
looks like 992 00 680 0 - ROLLE (roller) Check with you local dealer or this dealer in Germany. He has a good reputation. https://liersch.com/online-shop/ersatzteile/duerkopp-adler/10222486-rolle-5-49x9-82x7-1-0992-006800 Seems not to be super expensive. If DIY is an option the measures are in the above listing.
Take of the V-Belt and try turning it by hand. Or push down the foot pedal cause the clutch motor has a brake .... just guessing w/o having seen the machine setup.
Just from the picture... Machine has no reverse, not necessary but reverse is a bit more comfortable. Good thing is it already has a speed reducer installed which slows down the sewing speed and adds torque. The oil drip pan underneath the table is missing. It has an "old school" clutch motor. Though it has a speed reducer already the clutch motor may be a little hard to control. So a new servo motor is probably what you want Just test it maybe the clutch motor setup works for you.... See attached file it will gives you some more information 211G165_166_265_266.pdf
I´m still not sure what you mean. There is no need to remove more parts from the arm and I´m sure it is not possible and not even necessary for timing. When you have the hook installed (guessing you have one incl. the parts that hold the hook in place) and the needle plate is not installed (guessing you have one) you have a clear view on the hook and hook tip and the needle sooo....
That seems to the an oil well for the clutch but not for the machine it self.
What do you mean - looks like the bobbin / hook area is open cause I can see the hook driver on picture 2. Pictures are fairly small.... what does the brass tag say? is it 65? If it is a Pfaff 65 then it is a darning machine but not a sewing machine. If the machine is like this (German language website) there is no way to convert it to a 28 cause major parts are missing. F.i. stitch length lever and the rod for driving and lifting the feed dog. But as I said the pictures are very small and do not show the details very well.
Trouble threading a singer 29-4
Constabulary replied to Nametaken's topic in Leather Sewing Machines
You have mixed up the machine Class and the serial number. The G on the serial number is not for Germany. But G for Germany is a suffix of the machine class f.i. 111G156, 211G141. But this only applies for machines made in Germany (in Karlsruhe) after 1954. Machines made in Germany (in Wittenberge, Prussia) until 1945 had a C prefix on the serial number and a D (but not all IIRC) as suffix of the machine class like 45D91, 96D43 and so forth. After WWII until 1954 Singer did not produce sewing machines in Germany. You can get 29K threading wires on Ebay, Amazon, Etsy, Ali Exprsss... for a few bucks Personally I never had problems with 138 thread in any 29K model. They all use the same hooks since for ever. But the size of the needle hole in your needle plate matters. Iif it is too small you may have problems using larger needle and thread sizes. But be aware that the bobbins are fairly small and do not hold much of the 138 thread. -
Sorry, I doubt that. What is the serial number incl. prefix and please post pictures from front and rear. -
Never have seen this before on a patcher machine. Found this pic a while ago on the web so I cannot provide more details. Seems to be custom made. I don`t think the machine came like this from the factory. Just wanted to share this.
Missing Parts for a Singer 107W102
Constabulary replied to paqman's topic in Leather Sewing Machines
so way way cool How about making the parts from aluminum? -
Ebay is your friend - sometimes. Not cheap but he has it: https://www.ebay.de/itm/185107601974 Other than that check with LIERSCH https://liersch.com/ or Zieger https://www.np-z.com/
Buying a used first industrial machine
Constabulary replied to Zeekar's topic in Leather Sewing Machines
Singer 211 also came with large hooks depending on the subclass. I think the 666 subclass is a large hook machine. -
I would still go with the Singer. I agree with cowboyBob regarding the hand wheel on the 211 (I tried this on my 212 and I had no success) but if you want to change the motor and install a new servo motor you could add a speed reducer to slow down the sewing speed and add more torque. I would check the machines if they have matching forward and reverse stitch length. I know there is a procedure how to adjust F+R stitch length for the Singer 211 and the Adler 167 but I think I have not read anywhere how to do this on a Pfaff 1245 (not saying it is not possible). If the stitch length matters for your projects I think the Adler and the Pfaff have max 6mm and the Singer 5mm. -
yeah, looks, cracked and IMO it needs to be replaced. Its doable but not easy. You find some hints here: -
its rather a light duty machine for the shoe trade f.i. for sewing shoe uppers. Its not that you cannot sew other things on it but that is what the machine was designed for. The bobbins are fairly small. I have a Singer 18 brochure (see attachment). The Singer 18-3 or Adler 49-2 are quite the same as the Class 18 shown in the brochure with the difference of having wheel feed instead of a feed dog. Let us know what you are planing to sew (material thickness, product....) so I´m sure we can recommend a machine for your needs. Singer 18-22 Broschüre.pdf
- 10 replies
- cylinder arm sewing machine
- adler
- (and 4 more)
I have an early Singer 51w post bed machine (based on a W&W) and the upper section is pretty much the same just a bit shorter. https://leatherworker.net/forum/topic/86292-singer-51w-sv-2-post-bed-machine-restoration/ I have a manual for the 51w and it will work for your machine too. The hook seems to be the same as well so the manual should cover everything. Give me some time and I´ll upload it if the file is not too big... EDIT: well, this one should be even closer 21_w_180.pdf
The SD28 is a way cool (needle feed) machine but is also way outdated. I owned one it I loved it but it is not very... lets say user friendly when it comes to needles and spare parts. And it was not very versatile. It is mainly a sole stitcher so the number of needle sizes of course is (or was) limited to the rather larger sizes like NM 200 and bigger. So do not expect to find 1551 needles in size NM 160 or so. Maybe there were smaller sizes available but again, this machine is way outdated and rather used by hobbyists than by professional boot makers nowadays. The spare parts you find nowadays usually come from broke machines and no new parts are available AFAIK. Well maybe there are some NOS parts that are dug somewhere in the world - you never know but finding them and having them shipped to your door can be an expensive challenge. Times have changed and the sewing machines as well. However - I know there is or was a guy who reproduced needles for the SD28, I think he made them from other needles but I do not know the details... Let me see if I can find more information.... EDIT: Register in this German sewing machine forum and contact the member HENRY LEDER. This is the short thread where he said he makes new needles for the SD28: https://www.naehmaschinentechnik-forum.de/viewtopic.php?t=7059
As I said in an earlier post in this thread. I have two Jack Motors with 750W (563A actually) and they both make this sound. IMO that sound is not really an issue. The oldest is running since 2014 w/o any issues. Really, that "noise" may just sound strange but IMO its actually not an big issue. From what I have witnessed that "noise" is quite common among the "cheaper" 750W motors. IIRC the 550W Jack Servo do not make this "noise". Just my experience.
IIRC you need a spacer between machine body and flywheel to line up the flywheel pulley with the motor pulley. Otherwise you may have too much axial play .
- 6 replies
- presser foot
- singer 132k6
(and 1 more)
depends on the sub class. which one do you have? 7-10, 7-33 or....
I can´t really help but I heard rumors that JUKI PLC gauge parts could fit but that is just a rumor, I have no proof for that. Maybe worth checking this: https://www.juki.co.jp/industrial_e/products_e/lether_e/postbed_e/detail.php?cd=PLC-1700_E Other than that I would contact KH sew or a local dealer. Maybe KH Sew knows more.... https://www.khsew.com/index.php?route=product/category&path=168_227
