If the old grease or oil is gummed apply heat with a heat gun. I also had success with paint thinner (don´t do both at the same time)
Dürkopp 18 Patcher Restoration - long journey...
Constabulary replied to Constabulary's topic in Leather Sewing Machines
I know I had one but I cannot find it atm - sorry! my BUSMC machines (A1 + #6HM) are one - its a bit a pity but I have space issues and my main focus is on Singer machines though I would love to have / try out a BUSMC PILOT one day. -
In many cases the machines just differ in small details you would not notice at a first glance. it is often just the feed dogs and needle plates that differ - f.i. - feed dog has coarse teeth instead of fine teeth for better feeding of heavier materials. And the needle plate just has a larger size needle hole to run larger size needles and so forth - that could be the difference for "heavier material". Or machines have a roller foot instead of plain presser foot or are furnished for edge binding operations. Or a different foot lift lever gives the machine a slightly higher foot lift. There are may small details that COULD be different. And keep in mind even when Industrial machines with different subclasses look the same and have the same needle plate and feed dog (f.i.) you never know if one of the former owners / users or even a dealer has changed out parts or altered some settings or not. So sometimes you really can´t tell the difference between subclasses by just looking at the machine. At Singer 29K machines the presence of an oil / wax cups (for sewing with waxes thread) puts it into another subclass but the rest of the machine is still the same. But a lot of people retro fit a oil / wax so the machine name plate still has the subclass of a machines w/o the oil / wax cup.... You know what I mean?
Thanks a lot - glad you like it! I no longer own this machine. It was a lot of work but it really was an interesting project. Especially because of the special hook / shuttle system. I still don´t know why this machine produced a 8.5mm stich length - it really is / was amazing! -
The treadle stand actually is an ADLER 30 stand. There was a motor mount for this stand. I never owned one but have a few pictures. maybe it gives you an idea for a DIY mount or so. When you have a FS550 motor you can mount it on the underside and the drive belt goes from the motor pulley to the large pulley on the stand. When you are buying a servo motor similar to the JACK JK-513A you also can mount the motor upside down on top of the motor mount (or bolt the motor directly to lower the machine body) and mount the accelerator unit underneath the mount. This way you can leave out the heavy pulley. Just wanted to give you another idea... Choice is yours
Is the hand wheel supposed to be super hard to turn?
Constabulary replied to JC2019's topic in Leather Sewing Machines
Sometimes the hand wheel is too tight (pressing against the machine body). The hand wheel usually has 2 set screws and one screw on the shaft end. Loosen them all a little bit and move the hand wheel an bit to the right. Then tighten all screws but be careful with the one on the shafts end - this is often the one that s too tight! If your machine has a needle positioner you most likely have to remove it from the shaft first. -
Just found this while looking for other things (depth gauge for router) https://www.ebay.de/itm/303149957400 Could be useful for larger projects. Seems to have a quick release.
Speed Reducer mounted directly onto Servo Motor
There he is - the inventor Thanks for jumping in here and sharing more details. -
I´d lower the needle bar a little bit maybe 0.5mm or a little more. I´d also replace the needle plate - looks like this one missed the hardening process.
the belts are not the point - that is just temporarily -
This is not my idea - the pictures come from German sewing machine forum (I have permission to post them here). For sure it depends on the servo motor it self but it this is a rather smart idea I think wen you have (space) issues mounting the speed reducer under the table. What do you guys think of this solution?
Singer 51W SV 2 Post Bed Machine Restoration
So I have installed a new needle bar guide because the Singer NB is a lot shorter than the original W&W NB. Interestingly the NB guide came from a Durkopp machine and has the same diameter as the Singer and W&W NB. Really interesting how parts pretty much remained the same for decades and that different sewing machine Co´s followed the old W&W / Singer specs. I really love to figure out when parts are interchangeable. The long tube on top of the NB (see above pictures) was not a NB guide it rather is a dust protector for the NB and had a wider diameter so nothing I could use. Surprise #3: You still find needle plates and feed dogs that work with this old 51W machines While playing with google searches I figured the needle plates of the GOLDEN WHEEL 810 pretty much look the same. So I ordered some cheap sets on Ebay for for testing (hell they are dirt cheap). This was the 1st set - it fits but needs modification. Feed dog needs an oblong screw hole for height adjustment and the outer ridge of hook is touching the needle plate (remember I installed an Durkopp hook that was not designed for this machine) but needle plate can me modified. https://www.ebay.de/itm/143143427599 This was the 2nd set I have ordered and it works w/o problems I only had to play with the feed dog height. https://www.ebay.de/itm/143164778742 Hook works a lot better with this set and yet no modification is required! Surprise #4: Damn - there are even hooks for the Golden Wheel 810 / 820 that looks very much like the Singer 111 hook. They have the same needle deflector but no shaft instead they have the same "2 prong mount" as my original 51W hook and the Durkopp hook I´m currently using. So I´ll gave it a try. For less than $10 you can do much wrong. GEH-820 hook Hook is on the way already and should arrive within the next few days. Machine already works good for far... (I know needle too thick) BTW - I have removed the limiter from the stitch length lever (2nd post, last picture) and I now get approx 5 SPI. with NP / Feed dog set #2. -
Pfaff 335 clone sold as a genuine Pfaff
Constabulary replied to vanessaFrance's topic in Leather Sewing Machines
yeah - someone definitely tried to "Pfaffirize" it! Not very well done - obviously. I would be pissed too! -
Most likely these machine all come from the same factory in China (Pfaff, Mauser, Typical, Global... and so forth) just with a badge of the specific "Name owner". Pfaff no longer produces these machines in Germany - if that matters. So quality wise I doubt there is a big difference between the "Names" ( I do not say manufactures). Some pictures would be nice. -
NECCHI is an Italian brand, nothing wrong with it. But before you buy it make sure the machine is fully functional and the reverse lever works as you expect. You may have a hard time finding spare parts. Some parts may be interchangeable with Singer 45K, Adler 4 / 5 or Adler 104 /105 but some like the stitch length lever seem to be very unique.
I´d contact Uwe through his web shop / website. BTW - he has a travel note on his shop: Travel notice: Items ordered July 15-31 will ship in August.
the stitch length adjuster looks kind of odd - the Adler 5 has a different stitch length adjuster. I´m not sure but could be that it has been modified - or - but I have no proof - it could be a NECCHI made machine. I have a German language Adler 5 manual send me a PM if you are interested in the manual.
Looking for info on machine I recently purchased?
Constabulary replied to Rpatterson86's topic in Leather Sewing Machines
Seiko CH-8 http://www.seiko-sewing.co.jp/en/products/chseries/ I have seen them with Singer 45xx or Consew tag as well -
not really a sewing machine. It´s a sack darning machine
Opinion on Adler 30-70
Constabulary replied to Old Coach Saddlery's topic in Leather Sewing Machines
looks like the machine has not been used extensively. Since this is the latest model of the Class 30 with "squared casting" I would not expect serious issues or lots of wear but of course - you never know. -
The 332 needle has 2 grooves , the long has to face left and the short to the right. You can also use 135x17 needles - same here but the 135x17 (or 135x16 for leather) has a so called scarf which has to face right (towards the hook).
If it helps - I have 2 used OEM Dürkopp with PN 249400. One is complete with spring and 2 screws the other has no screws and no spring. Don´t know how good they are but you can have them for free - I just ask for shipping costs.
Exploded view Singer 29K 53-58 models
Constabulary replied to chrisash's topic in Leather Sewing Machines
Major different is the gearbox and thread lever regulator other than that ... what Jimi said Maybe the attached file already works for you. I have another 29K71 - 73 manual / parts list but I cannot compress it enough for uploading. Parts singer 29K71.pdf EDIT: this is the other one - I uploaded it already: https://leatherworker.net/forum/applications/core/interface/file/attachment.php?id=142508 -
Can a binding attachment do this?
Constabulary replied to LederMaschinist's topic in Leather Sewing Machines
The thinner the material the better it usually works for binding edges. There was a special binding attachment for leather strips for the Adler 4 / 5 and Singer 45K but I think its tricky to work with. I have attached a picture from an old Adler manual. I remember LW member JIMI (pretty sure he will jump in ere soon) has shown this a while ago but I have to look for his post. Or how about thin faux leather strips for binding edges? https://www.etsy.com/listing/624163856/38-12-34-oder-1-double-folded-vegan?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=faux+leather+strip&ref=sr_gallery-1-2 https://www.amazon.co.uk/Neotrims-Faux-Leather-Leatherette-25mm-2-5yards/dp/B01DPTXW7U MacCulloch & Wallis has a wide rangeof edge binding materials: https://www.macculloch-wallis.co.uk/c/750/bindings-leather-trims?p=1&q=750&sz=96&me=sz -
I guess machines based on the Singer 153 should have the same gears, like Seiko CW-8 or Cowboy CB227R / Consew 227 and similar. Check with Toledo Sewing Machines in OH or Keystone Sewing Machines in PA - pretty sure they can help you.
- 4 replies
- 153w103
- hook drive gears
(and 1 more)
