toxo
Contributing Member-
Everything posted by toxo
Thanks Matt. There's nothing like 1st hand knowledge.
OK guys, here's where I am. I spoke initially to Tysew and potentially, they will deliver the Tysew 3001-C and take away both the Durkopp 239 flatbed and the Adler 69 in part exchange. I was getting quite excited about getting the whole job done so easily but then @Matt S mentioned "moderate quality Chinese clone" which made me think again. I found Juki 246 and the 3141, both within budget but each with compromises and now i'm leaning towards the original deal again because; Getting a new machine and getting rid of the other two on the same day is really appealing. Comes with a 12 month guarantee It won't be getting any heavy usage Both Geordie and Harry Rogers (YouTube) use them (maybe because of sponsorship?) And have featured them on Y/T. What's holding me back slightly is wanting to do wallets eventually and I don't know if the Tysew can get down that far. Will one of Brians @RockyAussie needle plate doohickkies fit this machine? Would this be a big mistake guys? Talk to me please
Thanks Matt. To be honest I rarely sew bigger than 2.4/3mm leather but just trying to get a look at what's out there. A 2 inch cylinder doesn't worry me either. I've just had a look at Geordies Tysew, they're just up the road from you so I can drive over there if necessary. It looks like a capable machine with large bobbin and affordable. Couldn't justify the 246 on my output. Take a look, what do you think? @Northmount Why didn't I think of that? I have a great brain but it's completely linear. Can't think sideways. Can't do a cryptic crossword to save my life. Thank you. Tysew TY-3600C-1 Cylinder Arm Walking Foot Needle Feed - TY-3600C-1 -
Thinking about upgrading my Adler 69. Can you guys please tell me what cylinder arm options I have in the UK that have a bigger bobbin, will easily sew 2 layers of 6/8mm veg tan and preferably has a lock on the reverse?
This dual belt sander arrived today from Germany. A week earlier than expected. All seems well. Will update when I've had a play, with maybe a short video. Once I've sorted which grits are best I'll probably buy on the roll cos all the offerings seem to be mixed.
Or to be sure (without a template) maybe leave the outside (folding piece) over long and cut it to size when folded over.
Having just bought a buffing wheel thingy, what compound blocks are we all using and for what purpose?
IIRC you can apply solvent to silicone sealant to achieve a similar result.
This is what attracted me to this sander. Because there's no steel behind the belt there's more leeway when doing curves. there is a selection of belt grits and there's a felt one which I'm thinking will be good for burnishing. Also, the speed is adjustable.
Turns out these belts are common on Ebay so I've just ordered the sander. And it turns out that although the compressor was built in Denmark the bolt is an imperial size.
Be glad to Bob. Buffer should be here tomorrow. Holding off on the sander til I know where to get the belts. That seller doesn't sell em and doesn't even know the size of the belts. I'll be sorry to pass on that sander cos I like the ones that have no steel behind em and most of the others have really slim belts. Having to really think about my set up cos it's in a small second bedroom but I have everything I need in there. two sewing machines, an 801 skiver and a worktop so plenty of shelves. Just down the hall is a 5ft deep x 3ft wide tool cupboard. Thinking about putting the buffer and sander in there on a sliding shelf but depends on if the mess is controllable, otherwise they can go in the small shed in the garden. Still struggling with the compressor. After buying three socket sets it turns out the bolts are spline or 12 point bolts. I thought I'd cracked it with the last set but the 6mm was too small and the 7mm was too big. Can't find a 6.5mm anywhere. When I eventually get it sorted it'll make a silent airbrush compressor.
After my recent house move, although there's still a way to go I'm at the stage where I can start to produce leather stuff. Just finished a motorcycle backrest and about to start on a handbag for his wife. I've decided to invest in a couple of bits of kit to give myself some encouragement. Still trying to refurb the Jun-Air compressor. Not sure how much it's gonna put out but it will at least make an awesome airbrush unit cos it's silent Just bought this - Sealey BB2002 Bench Mounting Buffer/Polisher, 200mm, 550W/230V : Amazon.co.uk: DIY & Tools And as soon as I've found out how easy the belts are to get hold of I'm gonna get one of these. having two grades on one machine will be good I think. - 950W Electric Sanding Machine Belt Sander Double Axis Bench Grinder 220V 6000rpm | eBay My bags are gonna look awesome this year (I hope). Thoughts guys?
Welcome from Kent. Posting will give you the oomph to do it again. I run a small workshop down in Gillingham and one of my beginners did this. I lasered the owls which would have been much better with white in the detail but she didn't want to. Good luck. Paul
When the stitch is unbalanced and there's a choice to tighten one or loosen the other is there a criteria for which way to go? I'm thinking of maybe too much of one or the other may damage the machine?
Didn't know we had a Fb group Matt. I'll go look.
Might help if we knew where you are.
As per title. They seem to be abundant in the US. Who sells em in the UK?
I couldn't find my roll of wire and before I robbed this I thought it might be worth something to someone. I needed a particular colour and it wasn't waxed so I threw this together. Wasn't 100% but that was probably down to the wax. Got me out of a bind and taught me to buy waxed threads.
Excellent practical project and very well executed, well done.
Is there a reasonably priced leather supplier recommendation
toxo replied to Mulligan31's topic in Suppliers
Might be an idea to tell us where you are. -
Just laid the floor of my new bungalow and now I need to revitalise my leather furniture. This is without doubt the most comfortable furniture I've ever sat on. It not only hugs you but will recline all the way flat on 4 of the chairs so I need to treat it well. Most of it is perfectly fine (has a layer of dust on it in the pic) but there are wear marks on the surface on well used places so before I start experimenting, I thought I'd ask the hive for the benefit of their infinite wisdom. My first thought is a dilute dye mixed with a conditioner just on the wear points, but I'd love to hear from someone with experience.
32 hours of tooling
toxo replied to YinTx's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Well done Yin! What a diplomat. Some folks got nothing to do but look for trouble. -
Cut the leather oversize by about half inch either side. Glue all the length leaving 1 inch either side dry. Wrap all the way from top to bottom using low tack masking tape. At this stage the two sides are overlapping. When the glue is dry, using a straight edge cut straight through the middle of the overlap leaving a dead straight line. Of course any tooling will be done when the leather is flat. Simps
How surprised was I to find no category for airbrushing or compressors! Anyway, ever since I bought an 801 skiving machine with a purpose made vacuum system and waste bag I've been looking out for a quiet compressor to drive it (the waste system). Thus far I've been using a long air pipe and a noisy 50ltr jobby in the garden but I've just moved into a small 2 bed bungalow with no place at all for a noisy compressor. I learned that the really quiet ones like Jun-Air or Bambi are an arm and a leg to buy so my ears pricked up when an older Jun-Air came up on Ebay for a song. I didn't hold out much hope that it would drive the waste system but at £185 and refurbished I reasoned that if it didn't I could still be spraying leather with a big smile on my face. I ended up getting it for £130 but hold on! This ain't no fairytale. Here it is. I had a mooch around the net and found this Jun-Air 6-4 Quiet Running Compressor - 32 l / min at 8 bar (esska-tech.co.uk) Great joy thinks I. Then it arrived Back down to earth I came. And that wasn't the worst of it. The motor is fine and very quiet but there's no output. Now this is where I'd normally say " If I didn't have bad luck I'd have no kin luck at all", but I don't think this is the case this time. I've been refunded £80 so it stands me in £40. I've shown the damage to Jun-Air and they're sending a replacement for the broken bit gratis, well done Jun-Air and they sent a users manual and spec sheets and parts list and I think I'm gonna enjoy this project so all in all I'm happy.
