Everything posted by blue duck
Looked for a long time for that exact book. Never found it. Not much help, huh? However, if you want to learn you might try howtomakeadesignerhandbag.com It is actually an online school. Richard is the main instructor, he will visit with you before you sign up if you want. Think you can sign in as a guest to see what it is all about. Tell him Kathi sent you, if you contact him. You will learn all of that and more if you go through it all. If you only want the patterns, he is working on a new idea, he might have a simple one or two available. If it is just the patterns you want and have the ideas in your head, we might be able to help. But it is the old fashioned way, not auto cad or whatever the computer puts out. (Don't want to step on any toes, so if that last part is a no-no, either delete, or let me know.) Rick
Unless it is a surprise, ask her what style she wants. Some only want round, some hate those. Flat is easiest for you. I would put a stay or liner of felt inside two straps. The leather cut edges can be sewn and then finished or you can turn them and stitch them. The latter is a more polished look, but all depends on what you are after. If she carries much or for a long time, she will thank you for the felt. If she chooses round, well that is a bit more work. You can use rope, covered cording, or even rounded leather. Glue your leather around that, stitch as close to the cording as you can then trim and finish the edges. Don't forget to work out how you plan to attach it to the bag, either via hardware or directly sewing to it. Want to guess why I put that little reminder there? Good luck.
http://www.buckleguy.com/metal-6-riri-zipper-closed-end-brass-teeth-go-red-rust-tape-kta-pulls-16cm-6-3-in/ I know this isn't the color you probably want but pretty sure it is the zipper. Have a look, lots of colors and sizes both finished and not. I would post the picture, but that would require a few more computer smarts.
- 12 replies
- bag zipper
- luggage zipper
(and 2 more)
You might try wawak.com and or the buckleguy.com I got some of those from one or maybe both of them.
- 12 replies
- bag zipper
- luggage zipper
(and 2 more)
Thank you kindly sir. I have been using a block of wood (which I now know has a name) and use an adjustable heat gun. Maybe I am not getting it hot enough or maybe too cool? Now that I say it out loud, what is the correct temp? I have tried using a dowel to smooth it around the edges, just heat, my fingers protected with a hot pad. I keep getting a wavy edge at the corner. Looked at the vacuum table also. You are right now I have lots of questions. Do you know if some of these materials are like kydex? Thanks again.
I have been using kydex for an inner-case on several projects that need protection. I have watched videos trying to get it right, but for the life of me I can not seem to get a decent 90* corner. Say for a box. I am hoping it is something simple that some of you might be able to explain. Or complicated for that matter. Any help would be greatly appreciated, what hair I haven't pulled out is going white. rg
My New Canvas Bag
blue duck replied to huns's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice Job! Oil cloth and leather is just classic. It's all in the details and you have attended to those nicely. -
What To Do When A Saddle-Stitch Just Won't...
blue duck replied to Ole South's topic in Sewing Leather
Thank you for taking the time to spell this out. It does make a lot of difference and is a great stitch to have in the line-up. Nice Job! rg- 8 replies
- hand stitching
- stitch
(and 3 more)
I don't know if this would work or not. Ohio Travel Bag has clips with a ring on them that were made for the top of say a clutch for a removable chain/strap. You could always drill the second hole, and some of them actually have almost saw-tooth ends to clamp into the leather. I have bought light wt. ones for clutches, and looks like it could be applied like you want. I just don't know how heavy duty they come. I would call them and ask, they have gone and checked on things for me in the past. Good luck.
Nice explanation Karina. Spot on!
Top Shelf! I was quite interested in the what would you do different answer. What happened with the gussets, if you don't mind sharing? Can see where the lining is a pain, but that puts the whole case into a different class than an unlined one. Just my 2 cents.
Thank you so much Tom. Who knows if or when I will get this made, but 1/2 of this outfit has a pattern problem. At least for the time being it is a pdf and doesn't take up room. Know she will love it. rg
Actually Doug is on to something. Think these are the actual colors of leather these folks used, the black may be a stabilizer that you would normally have hidden. It is probably a build up clear coat product, what brand I have no idea, may be something proprietary even. Like the edge products the handbag companies use on/in some of their designs. As for the top layer, it looks like it was run through a skiver and turned under, then sewn on after it was finished. But like he says, pictures are hard to figure out.
Hey Chris, These folks have always been great to work with. Wilderness Fabrics http://owfinc.com/
Canvas And Leather Tote
blue duck replied to Hi Im Joe's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Joe I went back and looked. I think I would make a "lining" for the leather extension on the zipper and add it to the lining. Could be leather or canvas. Then when you sew the zipper in, that would be joining the outside and inside. You would probably want to glue or tape the zipper on both sides so it stays straight. Then go back and top- stitch against the top edge. That would hold your lining against the side as well as finish the sides where the zipper doesn't attach to the bag. Now that sounds perfectly logical in my own little world, but it may be really confusing. If so I will try again with a little more detail. But then again it may be more trouble than its worth for what you are trying to accomplish. Cheers! -
This is going to make someone a great tote. I am not sure what you have for a machine, but if you are going to do many, you might try finding a cording foot, it will let the cord ride close to the stitching line. Also when lining a bag, you might try making the lining complete, the bag complete, then drop the lining in and sew around the top edge. That will hide all of your seams on both the bag and the lining. But you have a great start! -
Thank you kindly sir. That would be really simple if that is all it was. I'll give it a go.
Thank you so much Andrew, there is a lot of information here. Never even considered a band knife splitter. What I would like to be able to do is take 4-5 oz and get it down to 2-2.5 oz for pockets and then even thinner for interior parts on wallets. So 5 1/2" limit would probably be ok. I am just always catching it for buying something to get by and then having to go buy it again to do it the right way. But think we have all been there. Also sent a pm. Thanks, Rick
Tom, J., and billybopp; Thank you all for you help and information. Might get computer literate yet.
I know this has been brought up many times, I have searched through most of them, however I am begging for some help to find what you would consider a good investment for a splitter. Your opinion is much less biased than some of those salesmen out there, I am sure. I have looked at the cheapest I could find to some that are way out of the question. I would like to get one that will not need to be replaced because of quality and can use for a long time, yet I can not justify the high dollars for an electric one either. I am sure you folks have something that will produce a quality split and not break the bank? If this helps the leather we use most of is a mixed tan, both veg and chrome tanned, (we use a lot of Horween leather) and we are producing bags, cases and wallets for the most part. So it needs to be able to split something wider than just a belt at times. Is there any other information that can help you help us? Thank you for your time and trouble! rg
Say Tom, if you don't mind, what do you use to get this pattern into a computer read format? Does that make any sense? I can build one with a pencil, awl and ruler, but that doesn't help anyone else. You obviously have a way with computers, what would you suggest for ease of use, since I am not all that computer literate, and since I am not trying to make anything off of it, something on the cheap.
Tom that was a really nice thing for you to do. Some folks can make a pattern in their head, but then there are the rest of us. Nice job!
Lots of wallets on the market these days have a mesh ID window covering. I have searched high and low, but am mostly finding either acetate, clear films, or the likes. Anyone found a source for it?
Tote Bag For Grandma
Sharp tote Joe! Bet Gramma ends up selling a few for you. Just a suggestion, you might try skiving the seam allowance so it will lay a bit flatter.
