Everything posted by billybopp
Dip dying
billybopp replied to ffjdh's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Dilute the dye and submerge longer. -
Dip dying
How much you dilute kinda depends on the dye and the result that you're looking for.50/50 is a good starting point, tho. You do not need to submerge the whole thing at once. Just get the item under the surface and pull it through relatively slowly .. Maybe 3-4 seconds submerged time for any one section. This way, you can use a relatively small container to dip items. I lay items out flat on a cut open trash bag for a short time to let them dry as evenly as possible. Some like to put belts up on edge, and then flip them after a few minutes. I have wiped items if I see dye pooling in an area. Hope that helps. -
Sheath for a Viking seax
billybopp replied to Harry Marinakis's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It might have been easier getting in and out of a boat, sitting and rowing that way. -
Its not ... And it doesn't do accents well at all.
If you REALLY want to know what's being said ... Do not try to use the youtube closed captioning feature. But if you want a good giggle, try it! Bill
Contact cement will work quite well. There are a couple of things that you need to watch for, however. If the lining is thin, you need to be especially careful that the contact cement is very smooth. A glue spreader of some sort is helpful for that. Those "sample" credit cards that you get in your mailbox all the time are very effective glue spreaders, and expendable. Contact cement can be a little difficult to align and get flat, so there are a couple of little tricks that can help. 1. Cut the liner a little big and trim off after gluing to compensate for any slight mis-alignment. A piece of plastic sheet can be helpful in letting you glue a bit at a time, when placed between the two pieces being glued. Just put it between the pieces and align them, and pull back the plastic bit by bit pressing the two pieces together as you go. Bill
Cutting shoulders straight in quicker time
billybopp replied to RockyAussie's topic in How Do I Do That?
I have a Logan 60" matt cutter that I have found works very nicely for straightening the initial edge for strap cutting. It's extremely easy to use, and big enough to nearly do most double-shoulders. Any remainder that doesn't fit on the cutter is pretty easily extended by a hand cut. It can do a vertical cut, or 45 degree bevel as needed. It also does a nice job of cutting photographic matts, as it was designed to do. Bill -
No doubt, if you're making a bunch a die is the way to go ... but I don't make a bunch of ... well anything! Bill
I have a couple of English Point punches in different sizes from different makers, and they are shaped slightly differently when compared side by side, so I don't think there is any exact definition of the shape. As belt end punches are pretty expensive, I only have the sizes that I use most, but can use a larger one for a slightly smaller strap if needed, with a little hand cutting to help the transition to the side look a bit more smooth. When I need a drastically different size, I mark both edges of the belt straight across and then use a compass scribe to mark the curves to the tip. It's close enough to look good, anyway! There are other fairly inexpensive tools available for marking your cuts such as this one. Also, gmace on here posted a quick little video about making an English Point end freehanded and by eye. I'd have to say, tho, that his hand and eye are probably more accurate than mine. I'll stick to punches and marking!! Bill
I have a few rotary cutters that I use. They work quite well for thin garment leather and stretchy leather such as deer/elk. They are not so useful for harder veg-tan for me. I do however LOVE having a rotary "paper cutter" that is fantastic for anything up to about 6oz and is the cat's a$$ for squaring up smallish pieces! Bill
I like deer or elk. Soft, a bit spongy and very comfy for the guitar straps I've made. Bill
Rotary knives work very well for really stretchy leathers such as deer, elk, lamb, etc. Also good for thin leathers, although other knives do OK on thin as well.
1/4 inch would be 16 ounce leather. Heavy stuff indeed! You'd be surprised how long you can make leather strips using a tool such as a lace cutter like this : https://www.youtube.com/watch?v=4y_R9ivP0_g . You'd probably want something thicker than the lace cutter can make, but the principal is the same regardless of the tool that you use. If you remember your mythology/history, when Queen Dido and her lot ended up in North Africa in what is now Tunisia. She asked the king there for temporary refuge for her folks .. Just as much as could be encompassed by an ox hide. being the smart gal that she was, she had the hide cut into a very thin continuous strip that marked out pretty big bit of land, which would eventually become the city/state of Carthage. Bill
Take a look at lekoza leather slam thread. Lekoza.com
I suspect that Stohlman recommended using a stitching groove for several reasons. Most his work that I've seen pictures of were done with heavier leather, where the groove would not make that much difference in terms of strength. His books are also aimed at beginning/intermediate leatherworkers, where a groove front and back will give a good reference for getting awl holes precisely aligned front to back, angle alignment, and also helps to guide an overstitch wheel for marking spacing. I have no doubt that he was aware of pricking irons, and also aware of how expensive they were before the Chinese knock-offs became available. An overstitch wheel is a far less expensive tool (not to mention readily available at the local Tandy store). As mentioned above, there's nothing wrong with a groove in the right circumstances and there are some cases where it's the right aesthetic and is certainly a good thing to know for all levels of experience. I may be wrong, but those are my thoughts! Bill
That's cool. I love homemade and repurposed tools!
I have a bunch of older Tandy snaps that are fine, but even if the newer ones were top quality I wouldn't buy them. I really don't like the fact that they feel the need to plaster their name all over the new snaps. Bill
I'm pretty sure that all such labels that used to be on machines from the factory have been crowded out by the ones that the lawyers make them put on. You know the kind "Stop machine before changing needle". " Do not put fingers beneath needle while sewing". "Machine will not sew without thread". " Thread must be purchased separately". "Power must be on before operating". But seriously ... GREAT idea for these labels! Bil
There is an excellent article on finishing edges here on LWN. Finishing Edges Bill
I don't know anything about this either, but agree that it looks really cool! I'd love to see some more pictures .. It might be fun to try to make something similar! Bill
Leather Stitching gloves
billybopp replied to Forester's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I don't have a pattern for gloves, but ..... For those long runs of hand-stitching, I've found that athletic tape is a good solution. I wrap fingertips to help prevent awl and needle pokes somewhat, and wrap pinkies where the thread rubs as you pull to tighten. Be sure to use cloth tape rather than the plastic finish type, as it has a good bit more grip for pulling needles. It also has the advantage of being clean and fresh every time you use it, as well as being cheap and effective. Bill -
I'd add to what Colt said .. When your brush is fully loaded with dye, use it more away from the cut marks and as it dries out a little move toward the edges. That will help to prevent "dye creep". Bill
A good rule of thumb for thinning substances to airbrush is about the consistency of whole milk. Eco flow and resolene can be diluted with water, I use filtered water, but distilled water might be a better choice. I don't know what you'd use to thin neatsfoot oil, but it's not TOO thick as it is, so might work straight from the bottle. I've never tried it, tho. Bill
