Everything posted by YinTx
Must say that looks like it was truly a labor of love! Nice work! YinTx
That was the video I was referencing on my first post. I spent many hours back and forth with it. For some reason, the numbers on this machine don't match his, could be because this is a Techsew and not a Juki? After I finish stitching the jobs I have, I may play with it some more to see if I can get them closer to his. I am beyond ecstatic that I have finally gotten the feet to sequence correctly, after finding the camshaft out alignment 180 degrees. Supposedly per the individual I purchased it from, this went back to the supplier to fix when it was purchased new, and they sent it back this way, and it has never sewn correctly. Right now, I am getting it to stitch, feet march correctly, both feet lift, backstitching works, tension is good, only complaint I have is the rear presser foot seems to be a bit jerky moving up and down, not too smooth at all. It is very well oiled, so not that. YinTx
It may be a simple adjustment. I have had some success today, since there is no professional around that I know of, I'm the defacto mechanic, so I do appreciate the tips and help. This troubleshooting may help others too. If you have time and desire, kindly refer to the other thread I started and provide any input you like. Thanks again, and back to the regular programming! YinTx
I have this part adjusted to where the point sticks out about 1mm. I am studying the following video to see if the eccentric cam has slipped on the shaft... at the 1:40 mark, my machine is doing the opposite of what @Uwe indicates it should be at, which may explain why the feet move opposite of what they should. I'm trying to figure out how to adjust this cam...
@Wizcrafts, thank you for that pointer. I did watch this video, as mentioned in my post last Wednesday. To avoid hijacking this thread, tho they are related, here is the thread that I started that discusses some of the issues I am having. I am beginning to believe that something slipped on the shaft causing the linkages to move in opposite directions than they are supposed to. Hoping someone has seen this before, or can point me to the right direction to understand how to get it back into timing. Since the post, I have been able to get the shuttle hook timing a lot closer as highlighted by RockieAussie. I have the presser foot lifting a bit more, but still the needle foot raises when the needle drops, and drops when the needle raises. YinTx
"Reverse Dye" Tooling - Impressions Remain Natural Color
YinTx replied to BenjaminKortz's topic in How Do I Do That?
@fredk's method is one way, another is block dying. The example you show appears to be done with block dye method. Do a search on this site for a better description of the process than I will be able to provide! YinTx -
Really cool tho. How did you get that texture on the fish?!? YinTx
Can you clarify this instruction? A bit confusing.. If the outside/back foot is already resting on the needle plate, how can you drop it down another 3/16"? I think I am having similar issues with my machine, foot timing is way wrong (inside foot is raising when needle is dropping, binding when trying to get it any different). Thank you in advance, YinTx
I'm going to agree with you there, oval grommet setter missing the bottom anvil. But I've been wrong before. The hole in the side is reminiscent of a rivet setter, which doesn't match the oval, so yeah, good mystery! YinTx
Maybe someone can help me out with this frustration. After 6 years of the machine collecting dust because it won't sew, I've been tinkering with it because I have some projects that just need a sewing machine to be finished. So here is where I am at: tried @Uwe's video showing how to set timing, not working for me. Looks simple, but not happening. When I loosen the hex head bolt to adjust the shuttle hook, adjust it, then you have to rotate the handwheel back so you can tighten the bolt, which means the shuttle hook is defacto put back out of timing because it stays still while the shaft moves. WTH? The best I can get is the hook not retracting (sticks out 1/8") at it's furthest back otherwise it will not interact with the needle correctly (ie, completely misses the needle, which will already be up before the hook comes to try to catch a loop). At just short of 20 degrees is when the hook and the needle cross, not the 30 degree mark. Also, trying to set the presser foot and needle bar foot coordination, but it isn't happening either. Tried a hundred different guesses also, none working. Always, the needle bar foot is going up when the needle is going down. And the presser foot hardly moves (5mm lift). Anyone have a simple way of setting this? Once again, tried to follow @Uwe's video, set the linkages vertical. Now its a disaster. Clearly I am doing something wrong, or something is set up backwards or I don't know. What should I be looking at? The video I made in 2015 clearly shows my issue, which I didn't know I had at the time. You can see at the 2:47 minute mark when I spin the hand wheel how bad the foot coordination is. Other than that, the rest of the video is just discussing the binding issues, which seem to have been reduced significantly. If you mess around with the linkages too much, it'll bind up solid again. I would really like to get this piece of iron functional, so if anyone has tips, suggestions, clues, etc, please let me know! YinTx
YinTx commented on Garyak's gallery image in More Leatherwork
Case for a "Smarter then me" phone
YinTx replied to Stewart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Hahahah that would do it also! YinTx -
I picked up some of these patterns, and they are in great shape at a wonderful price, so if you are thinking about it, get em! YinTx
cool. I can hear it now: ringtone: ribbit! RIBBIT!! YinTx -
Outside of NM or Tx, I think most don't know Hatch Chile. And in Tx, they want to spell it chili. And somehow chile grown in the Rio Grande Valley gets sold as Hatch green Chile. I can say it doesn't taste the same. all very confusing to the outsider. Who wants to know if they need a passport to visit. YinTx
LMAO. Showing their level of intelligence. Also, here in the good ol US of A, we have a lil state called... New Mexico. I've lived there. Folks wouldn't ship 46 miles across the state line or do any business with us because "its' a foreign country." or "We don't take Pesos." erhm.... it's a state. In the UNITED STATES!!!.. you can drive here without crossing a border ya know? We used the dollar too. But you couldn't convince em to to look at a map cuz they knew better. Now I'm in Texas, so not so bad. Course, sometimes when folks from out of state learn where I've been, they want to know if I speak Spanish. YinTx
Finally able to show these off!
YinTx replied to YinTx's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Appreciate it! YinTx -
Since I am from across the pond, I haven't a clue. Why is this? YinTx
You have no idea. !! "Hi, my name is YinTx. Thank you for welcoming me to TT Anonymous. I have . . . lots of tools. erhm... I think I may have Tool Troubles." and, thanks! YinTx -
Really nice work! YinTx
Handstitch vs Machine for artisan pieces
YinTx replied to Warhauk's topic in Leatherwork Conversation
I hand stitch. Very little machine stitched. I hand tool leather, nothing press/embossed. Can't say that I've ever had enough folks pay enough $$ to make those two endeavors profitable. I think it was maybe Maker's Leather that did a survey and overwhelmingly customers were not willing to pay extra for hand stitching. So he bought machines and never looked back. If you are good enough with the machine, you can get a very high quality stitch, that some will have difficulty differentiating from hand. Most customers don't know any different, and luxury house brands machine stitch with horrible quality and get away with it. Things to ponder. YinTx -
They moved _from_ Newark to Harrison, so your catalogue would be correct. Now, they did apparently stamp some of their tools "Newark" after the move, but not for too long. YinTx
