fredk
Contributing Member
Everything posted by fredk
  1. You need sail eyelets which have a 'washer' for one side. You need to have the matching setting tools for them. Two tools; a bar which widens and flattens part of the eyelet over the washer and an anvil with a centre hole and a circular groove; the groove prevents the eyelet from deforming and the hole allows the setting bar to do its job. The commonly bought eyelets are just basic types which are crimped using a special pair of pliers; these types are basically rubbish and useless
  2. I just took a bit of 2 x 2 inch timber and drilled holes into one side through to the other. Different sizes for the different tools, but the smallest hole will still take most of the other tools as well. It wasn't wall mounted as such but mounted on a board that got shifted about out of the way, but close to hand when needed. For mounting to the board I just put screws thru the board into the 2x2. I suppose a couple of small steel right-angle bracket could mount it to a wall. I'm redoing my working place and I'll be using of those magnetic bar tool holders now I reckon
  3. Centre punch. Standard drill with HSS drill. Use a very slow speed and a cooling/cutting fliud. There are special fliuds but in the past I've used 3-in-1 oil, brake fluid and engine oil - both new and very used. You can drill once to size or start small and work up the size in a few size steps. Best to use a drill stand for accuracy, but if you're very careful it can be done without
  4. This is a good idea On straight runs I put lolly [aka popsicle (?)] sticks between the jaws and the leather. This also helps to spread the loading further than the jaws themselves. On short runs or curves I just break the sticks to suit
  5. The only short cut to cutting these out without grief is to get a clicker cutter made for cutting them out. But I reckon you'd need to be doing a lot to make it worth while. I reckon you might be just a bit too self critical. Unless two shields are mounted directly next to each other no-one will notice any small differences, and unless they are cut really askew no one will notice any little lopsidedness. I used to make toy shields for children. I made hundreds at a time. I stacked 10 boards together, drew the shield shape on the top one - using a template - then cut the stack on a bandsaw. I used to spend ages evening up to two curves. Then I had a eureka moment. I stopped doing that. The curves were still a bit lopsided to my eyes, but no-one gave a damn, not the children, not the parents.
  6. A. the only way you can achieve this on a fold-over sheath is to have the belt loop as a separate piece. 1. Sew the belt loop near the top of yellow, on the back, with the good sides together with the loop part extending up from the top, 2. then fold it downwards and 3. sew it to the back of yellow further down. Allow about 2 inches between the inside of the curve of the fold and where its sewn further down B. On a two piece sheath you could have the flesh side of the leather on the outside of yellow, and just fold down the extended top of yellow and sew it to the back of yellow I think sewing is better in this case
  7. I found that it was a personal preference to how high the knife was on the belt. I made the knife sheaths in my medieval group. All of the knives were longer than 15 inches and some were 18 to 20 inches long. Some chaps wanted the knife with the top of the hilt level to the top edge of the belt, some others preferred to have their knives lower down. Only one person wanted his with the top of the hilt a couple of inches above the top of the belt; but his fighting style was such that he could cross-draw that blade very swiftly
  8. bikermutt has it; but I fold the card first, then cut the the 1/2 shield shape. When the card is flattened the two curves are the same. I just cut them out with shears as & when I need them
  9. An idea/thought on peening rivets; long forgotten, just remembered. Last used a long time ago when I worked more with wood. Place a disc of thick card board around the rivet head, allow the head and washer room. Use thick compressed card, like the stuff on card envelopes, the ones that say 'do not bend'. When you start tapping with the hammer and you miss, you ding the card and not your wood or leather surface
  10. The 'shadow' or 'ghost' is caused by the tool bouncing. Its all in how you hold the tool. Grip it fairly tight and hold it tight against the leather, pushing it down slightly. A loose grip or not holding it really tight against the leather allows it to bounce, and your reaction is to then increase your grip and push it against the leather, making the ghost
  11. Get pure nfo, not nfo compound
  12. NFO has only a very slight smell. You'd need to put your nose right up onto the leather and sniff in heavily for a few moments to get its smell. If it smells any stronger than this the NFO is 'off' and shouldn't be used
  13. I cannot say just what you should charge. What I'll say is how I used to charge in my other businesses for bespoke or special items. I'd look and see what others are charging - but maybe not actually getting - I'd reckon mine was 2000% better and I'd charge anything from 2 times to 10 times the average asking price. Often I'd get that price, sometimes not. Often I'd get told 'so & so is only charging so much' so I'd tell them to go buy from 'so & so'. Only one in 100 customers were that way. Another group of customers I did business with always wanted a discount. For them I'd hike the price up then we would haggle till they got a price they were happy with and their discount, but still way high from my view In other words; do not undervalue your time, your creativity, your skill. Ask for as much as you possibly can, then if absolutely necessary give a reluctant discount Do not, never ever, cut corners on your work. It'll show. Be happy in the methods and styles you do. If you are happy/content with the way you make things, on how you finish it, your heart will be in it and it will show in the finished item An old joke; a man's car was running badly. He took it to a garage. Mechanic lifted the hood, reached in with a tiny screwdriver and turned something. The mechanic tells the man 'that'll be $100' 'What' says the man 'a hundred bucks and all you did was twiddle a screwdriver, and that only took 2 minutes!!' The mechanic tells him 'twiddling with the screwdriver costs $1, the other $99 is for me knowing what to twiddle' Skill costs money; the worker is worth his pay PS; #1 son has been having a go at me lately cos he thinks I'm charging way to low for my leather items. He reckons my prices need to go up by x5 at least
  14. That looks like a water stain in the polished finish. You can get that if you put a hot cup of tea/coffee directly onto the surface. Sometimes it will cure itself over time. Sometimes putting a damp cloth towel over it and ironing with a mildly warm iron will draw it out and return it to normal In this instance I'd let it sit and air for a few days, allowing some warm air to blow over it; warm air, not hot
  15. that one gets em every time
  16. I'm still me on most other forums except one where my name was taken so I'm Black Knight on that one Chose Black Knight cos I'm not. In my history group all the men wanted to dress up as knights, especially in black, but not me. I always went as the craftsman, doing leather work, or making arrows, or cooking. I got my photo taken by the public more than the others and I got into the local/national papers more often
  17. No, but its why an aeroplane can take off from a ship; take a WW2 type, nominal take off speed was around 70 to 80 knts air speed. An aircraft carrier steams into wind at 20 knts, wind speed is 15 knts = 35 knts along the deck, WW2 fighter just needs to accelerate to ship deck speed of 45 knts to get to take off speed of 80 knts a/s
  18. yes , although the air speed is the same, the ground speed is different; going A-B the ground speed is 90 knts, going from B-A the ground speed is 110 knts. T'was one of the first basic questions at navigators classes in RAF. Then it got more and more complicated; air pressure at various heights, different cross winds, fuel consumption of a Buccaneer S2B in lbs per minute. Got through it all. Answer to Viking puzzle later...............maybe
  19. With respect Oldnslow; I don't think thats the reasons. I reckon its because there are mighty few on here who have made a case, or do so at any time. Look how old the threads are Northmount found. Most of us make belts, bags, sheaths, holsters, saddles etcetera, but I don't read many talking about their cases. Its kinda more specialised
  20. I reckon its either LumpenDoodle2 or Sheilajeanne turn to be 'it'
  21. it takes a few days for others to come on and see it. I'm not playing cos I read that list on a certain website, Might be a give-away but I reckon they should have included Spirit in the Sky - Norman Greenbaum and Mrs Robinson - Simon & Garfunkel I'll give the answer to my Viking puzzle soon,........... maybe later.......maybe not
  22. Part of that is false; the inside pockets do not need to be sewn flesh to flesh with the outside pieces; they just need to be sewn directly to the outer panels so that the two become one. The sewing of the inner pockets to the outside panels can be at the same time as the gusset is sewn to it, if its to be about the same size
  23. If you sew the inside panel directly to the front and/or rear panels, they need to be flesh-flesh. When you go to turn it inside-out the double panel will turn as one, the outside of the outside panel will still be outside. I'd keep the tops of the extra inside panels weel short of the tops of the outside ones. especially the rear one, makes for easier access to the pocket
  24. Give that man the ceegar! Your turn, you're 'it'
  25. Trivia*; In the UK the 'Best before' date on packets of crisps** is always a Saturday*** ** crisps = potato chips in US *** I wonder if its the same in US/Oz/Canuk * Trivia. from Roman Latin, Tri Via, three-roads, or a cross roads, where people use to meet on market days to get the local gossip
