Dwight
Everything posted by Dwight
  1. My adult belts have holes spaced at 1 inch apart. Kid's belts that age would get 3/4 inch spacing. I also punch 7 holes instead of being cheap like most are and only punching 5 (in the hope the belt no long fits sooner, . . . they get to do another belt). I don't use snaps on my belts, . . . I use chicago screws, . . . and would do the same for the kid's belt. May God bless, Dwight
  2. I very seldom (can't recall the last one) make a single layer belt. They are all double layer, . . . and most of em are destined for CCW. All my belts are veggie and veggie, . . . contact cemented flesh to flesh, . . . makes an almost indestructable tool for carrying things on your waist. My thinnest belts I make measure out (when put together) at something around .160 or roughly 10/11 oz. My thicker ones (I'm wearing one right now, and it is my "go-to" belt 6 3/4 days out of 7 ) actually run a full .250 which is 16 oz. With that in mind, . . . try a 3/4 oz backer and see how you like it. Take a look on here, I replied a couple times in this, . . . one place I did a little video, . . . take a look at it, . . . belts like this are easy. May God bless, Dwight
  3. I have a similar problem with oval punching the holes for some of my belts. How I've "cured it" is to first hit a very light stroke, . . . allowing me to see if it is where it should be, . . . adjusting if necessary, . . . then punching. My belt holes have become significantly better since I started that practice. Try it, . . . just might work for you as well. May God bless, Dwight
  4. Well, . . . I'd say shoot it and bury it, . . . but I'd only be joking, . . . one of those personal things, . . . I don't do snakes, . . . including snakeskin. It is, though, . . . a good looking piece of raw material, . . . best wishes on how you use it and what you do with it. May God bless, Dwight
  5. Personally, . . . I would prop the split open, . . . dab a VERY LITTLE BIT of Weldwood contact cement to both sides, . . . dry with my heat gun, . . . press together, . . . and roll out with a seam roller. Next step would be a 2 inch long by 1 inch wide piece of fabric, . . . again, . . . Weldwood would be used to apply the fabric to the back side. Be very careful about not letting any of the wet glue get up to the hair side of the leather, . . . it will not dye as previously stated. This WILL WORK, . . . white glue will probably squeeze through the crack, ruining the whole thing, . . . yellow is not a good choice, . . . and the meat glue is totally unknown to me. May God bless, Dwight
  6. If you take the rawhide and get it right real good sopping wet, . . . it can be molded, . . . then dried, . . . a piece of veggie tan can then be wet down, . . . molded to the rawhide, . . . and when it dries, . . . contact cemented to the rawhide. I had a knife sheath a couple years back I did that to, . . . only didn't use veggie tan, . . . used suede, . . . if I say so myself, it was brilliant and worked like a charm. Guy who got it was happy as a squirrel in a bucket full of nuts. That rawhide will make one stiff holster. Also, . . . force dry the veggie tan at about 135 F, . . . and it will harden it up as well. The hardest holster I ever made was a pancake made out of 4 layers of 6/7 veggie tan, . . . 2 layers (flesh to flesh) made the back, . . . and 2 layers (flesh to flesh) made the front. Once molded and dried, . . . I think you could knock a guy out with it if you threw it like a frisbee. The knife sheath is below: May God bless, Dwight
  7. I use Feibings dye reducer and thinner. Some folks on here apparently use everything from water to diesel fuel, . . . After messing around with some of their suggestions, . . . I went back to this formula, . . . works great. When I buy a bottle of dye (4 oz), I buy a bottle of thinner for it. Open one, . . . open the other, . . . pour em into my bottle for that dye, . . . shake well, . . . good to go. Yeah, . . . they probably save some money, . . . but with this formula I don't have to guess, . . . wonder, . . . worry, . . . or hope, . . . "how will it turn out???". AND, . . . I don't throw out as many junk pieces because the dye was the wrong color, . . . wrong shade, . . . splotchy, . . . etc. May God bless, Dwight
  8. It is not a 100%, . . . absolute, . . . "dyed in the wool", . . . cure: but it comes awful close. I ran into this problem some time back, . . . and found "my" solution. 1. 24 hours drying time from the very last stroke or stamp on a cased piece of leather. No heat, . . . just room temperature (70 or so F). 2. Apply a light coat of neatsfoot oil, . . . and let dry another 24 hours. 3. Dip dye everything, . . . I use Feibings oil dyes and spirit dyes, . . . all are cut 1 to 1 with thinner. I no longer have hardly any of that splotchy and streaky looking dye jobs. They are basically uniform, with the exception of the grain of the leather. May God bless, Dwight
  9. Here you are Don: May God bless, Dwight
  10. Years ago, I worked with a master carpenter named George. What he could do with wood was not short of phenominal. I was tasked to do a certain job by him, . . . and when it was done, . . . I received a few complaints by others. I suggested to him, how I could fix it, . . . and he smiled and complimented me with one of the best I have ever received. He said: "It is not the man who never makes mistakes who will become the master, . . . it is the one who can cancel out or cover up the obvious mistake that becomes the master". I never forgot it, . . . and have followed that advice in every thing I have done since, . . . and it HAS worked out. May God bless, Dwight PS: AND, . . . for only 4 months, . . . that is a beautiful billfold. Keep up the good work.
  11. Rickybobby, . . . I have down thru the years came across your exact situation more than once. My cure for it was simple, . . . build a wooden replica. I have a small tub of them, . . . including a S&W 29, . . . a Kahr (forget the model), . . . a little bitty .380, . . . and others. Start with the basic outline after you have made a board the appropriate thickness, . . . band saw it out, . . . sand down the edges, . . . and go for it. So far, . . . none of my customers have seen the dummy I use, because they are pretty much all mail orders, . . . but I've also never had negative feedback. I'm not out in the shop right now, . . . but if you want I can get pics and post em for you to show you what I've done. AND, . . . no it really is not hard to do. I usually knock one out in about an hour, . . . and I use my "down time" to do them. May God bless, Dwight
  12. It is really simple, . . . if you are using glue, . . . toss it out and graduate to contact cement. If you use so much contact cement that is squishes out, . . . you are using it wrong. Leather adhesives are simple and work well, . . . if done right. May God bless, Dwight
  13. I use a $50 belt sander from Harbor Freight, . . . a little job that sits on the table, . . . I use 120 grit belts, . . . works like a champ. BUT, . . . I sand before I bevel, . . . and keep all my beveling tools sharp, . . . get good edges that way. You will probably throw away the first belt, . . . maybe the first couple, . . . until you learn just how to do it, . . . so be prepared for that. May God bless, Dwight
  14. I've made my version of the Eastwood rig, . . . as dikman said, . . . it's a rough out holster, . . . I used double 6/7 for both the belt and the holster. In fact, all the leather except the belt loops, came from the same hide if I recall correctly. It is a fun one to make, . . . sometimes I wish I had kept it. May God bless, Dwight
  15. For the few I've used, . . . buy the right size width, . . . cut to length with hacksaw, . . . round and smooth ends on a belt sander, . . . sew into the leather and forget them. I do give em a coat of varnish or something though, . . . just to make sure they don't rust away in the first few years in there. May God bless, Dwight
  16. I'll second the above motion ^^^^^^ as IF I DID IT, . . . it would be my process as well. Trying to sew around something like that already bent is a process dedicated to a migraine. May God bless, Dwight
  17. Thanks, Josh, . . . I like that system, . . . especially since I'm already familiar with and use Murphy's. Since there are several, . . . worst that can happen is we trash one of them, . . . and doing em one at a time might be the ticket. May God bless, Dwight
  18. Personally, I've made em both ways, . . . what works the best for me is the buckle end is a single piece of leather, . . . the tongue end matches the belt, . . . but I always use 6/7 and try to find the thinner end of the hide for the tongue end. The buckle end is always one thick piece, . . . makes it so much easier to patch it back into the belt so it can be fastened. My ranger belts are made from the John Bianchi school of gun belts. May God bless, Dwight
  19. Thank you, . . . I'm going down to see them later this weekend, . . . may just try that this time. May God bless, Dwight
  20. I'm not sure there are names or makers marks on them that anyone could find or decipher, . . . they are "really" bad. Leather is hard and dry on all three, . . . fourth is a nylon skirted suede seat, . . . that could probably be on a horse in a couple of weeks, . . . All the others were taken off the horse and just put, . . . and the folks did not care where it was "put" so to speak. One is a kind of show saddle, . . . lots of silver spots on it, . . . if any of them get any kind of treatment from me, . . . it is a likely candidate. Gotta get the neatsfoot oil on them first & see if I can loosen em up a bit. I've personally got an old Jumbo, . . . love that old saddle, . . . started to re-do it years ago, . . . decided it would ruin the history, . . . so I'm sending it to a friend in Arizona who promised to use it on roundups. May God bless, Dwight
  21. I have a friend who has 3 saddles in that bad a shape, . . . she wants me to "fix" em for her. Just not sure I'm up to that, . . . but I did enjoy seeing what you did. May God bless, Dwight
  22. Darn good there, Forester, . . . My only complaint is not you, . . . but the prop man that gave him a gun belt with no spares on it. Bonanza is like that as well, . . . one of my pet gripes, . . . just don't think it would ever have happened, . . . but I may be wrong. Guys today carry a 5 shot revolver with no extra ammo. May God bless, Dwight
  23. Good morning from Marion, Ohio, . . . Good looking holster there my friend, . . . May God bless, Dwight
  24. http://www.selfreliancecentral.com/2018/09/19/girl-with-gun-teaches-thug-painful-lesson/ I never saw her holster, . . . but she was packin', . . . knew what to do, . . . how to do it, . . . and far as I could see, . . . did a bang up job (pardon the pun). Had her figured for purse carry. May God bless, Dwight
  25. Somewhere in the actions we do, . . . our final product is different. When I use Weldwood contact cement, . . . I do not put it together until it is DRY, . . . and I mean DRY. Touching it anywhere will not get a tacky or moist feel at all. The only thing that will stick to it, . . . is another piece of something with contact cement on it. I stick the two pieces together, . . . and somehow PRESS them together, . . . palms of my hands work, . . . a seam roller from wallpapering days also works well, . . . especially on the edges. I then sand the edges of everything I make, . . . to make them even, . . . and when I burnish, I cannot hardly at all see see the line where the two pieces come together. May God bless, Dwight
