CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. @Desircustoms Here's a manual for it. Rex,Chandler 26-188 A@ manual.pdf
  2. On a 111w you should get it back as far as it will go but not beyond the edge of the table top (in case you put it against a wall) so this way your motor won't be in the way when you mount your knee lift.
  3. I wanted to use a size you could buy over there! Yes,there's alot of things in metric here & you almost have to try & put a wrench to it to find out !
  4. We call these carraige bolts here in the US,they are a M8 x 75mm long
  5. Be sure to let us know what you think of it after you get it sorted out.
  6. There's a Facebook group dedicated to these & most of them seem to enjoy having to tinker with them & the even accomplish some sewing with them.
  7. Looks like a Singer 45K53 their harness stitcher would sew almost 1/2" .
  8. That lever is for the belt guard.
  9. Nice looking stand,you might want to tighten your bobbin tension alittle to keep it from showing on the top.
  10. I've never seen one like that with a top feed on it,it is made for sewing along the edge of carpet.Sure looks like it's been setting for a long time.
  11. This is part # 350299,College should have it.
  12. I just found out yesterday Organ quit making the 7x3 #18 !! I'm looking for other manufactures but haven't found any.
  13. Yes,as Constabulary said there is heat involved from the friction of the needle going through the material.As long as it isn't burning your thread it not something to worry about if it does burn the thread either slowing down or lubing the thread will help.
  14. Do you have the inline feet?
  15. There can be a few reasons for this & one simple one is a loose feed dog screw.
  16. Have you taken the tensions discs apart yet & looked at them? You might find fuzz from the thread in there & possibly grooves worn in them from the thread.
  17. Uwe,to confuse you more,we call it 1341 here in the US but Techsew calls their 1341 model 4800 so according to you "they need slapped"or is their model ok with you since it's Techsew??
  18. Have you tried loosening the foot pressure? And yes some leathers are softer than others & you may need to rub out the marks.
  19. This could be a timing issue but we'll start with the easier causes first.Check your needlebar thread guide by taking some thread & pulling through it & see if it shreds,also check the bottom of your inside foot & feed dog for burrs or sharp spots.
  20. Yes,we used this type of servo years ago & stopped after so many complaints,the ramp speed & lack of low end torque topped off by the boards burning out in 2-3 out of 10 we discontinued buying them & switched to the type with brushes. We have tested & even have the 1100 watt servos for sale BUT have found that it lacks the punching power @ low speed & won't run as slow as our little FS550 servo does with a speed reducer on it,the brush type of motor also seems to have more low end torque.We stopped using the electronic servos years ago & have had alot less problems do to their simplicity,they also seem to have a long brush life.
  21. Looks good & at 4-1 that should work real slow esp if you ever get a servo motor.
  22. If your on Facebook you might want to join the Holsters for Handguns page,there's alot of knowledge on there about other guns that may work.
  23. I'm glad it fixed your problem !
  24. Loosen the lower screw on this plate behind the stitch length adjuster & take out the upper one & put a 1/4" washer behind this stitch length bracket ,reinstall screw & test.
  25. This happens from not being moved for a long time.Oil oil dries up & can make things like this stick together.I doubt if you'll have problems adjusting it again,I would oil the shaft either it will just make it slip out of time easier.
