CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. PB blaster or WD40 should dissolve the old oil & free it up.
  2. Before you go tearing it apart you should try putting some good penetrating fluid around the outer part of the washer w/2 screws in it @ the needlebar should free it up.
  3. No,just so it's easy to get to,it is a pinch collar that rotates on a shoulder screw.
  4. Old Coach is right just tighten this screw just alittle behind the back cover.
  5. Yes,he's right about the parts,the small gears that run the shuttle in this machine have been discontinued many years ago & break pretty easy if you were to jam it up.
  6. WE sell them to the Amish,they extend the shaft & use them for clutches on their lineshafts.
  7. Be careful when you oil that you don't get oil in the groove that grabs the wheel or it could cause it to slip shortening your stitch length.
  8. I could be wrong but I think the Standards were made by White,this site is mainly for Industrial machines.There are some sites on Facebook (Vintage Sewing Machines) & the web that can probably help you better.
  9. I think it is a model 128
  10. Are you using cotton or linen thread? Nylon & polyester won't work in them.
  11. It will need to be straightend IF you want to get the wobble out,I've done alot of them over the yrs BUT it really won't hurt to run it that way.You would have to turn it around & find the high side,take the handwheel off & put a pipe on it 2 meters or so long with an inside diameter close to the shaft & give it a good push.Then put the handwheel back on &give it a few spins & see how it looks & keep doing this until it's straight.
  12. That looks like a 7 class to me,that has missing parts that make the foot lift when it walks.Poor thing has had a rough life,looks like some treadle parts are missing or broken too,which will be real hard to find unless you are able to make themHere's a pic of a 6 class we have,you can see how much beefier it looks.
  13. After you put the shuttle in,close the slide plate & hold the needle thread tightly,turn the machine one full revolution & the bobbin thread will come up through the needle plate.Also when you start sewing you need to hold the needle thread for the first 3-4 stitches. $200.00 is a great price for a new shuttle.
  14. Your right & that is what Turbo needs to do get the bracket out more @ the bottom so it shortens the foward stitch.,some machines feed longer in reverse THEN you shim the top.
  15. On certain materials when it moves it can push foward,but you can you can try it & see what happens,it's an easy adjustment to lower it if needed.
  16. You do not want the feed dog any higher than the needle plate on this model.
  17. Your right,I need to look closer !
  18. Get a punch,nail anything the size of the pin & tap it out! They might of had a problem with the timing slipping is why the did that.You might try putting a screwdriver in the slot & gently try to pry it open.
  19. Yes.you need to remove that pin somebody put in there.
  20. Here the timing . CB441 manual pg8.pdf
  21. No Driver ! Do what I said,put the needlebar all the way down & THEN push the stitch length lever all the way down & then put it in reverse THAT's when when the needlebar should not move front to back .Make sure it's @ the bottom dead center when you do this.
  22. Single needle chainstitch ruffle.
  23. Your hook timing is OK,you need to adjust your feed timing,when the needlebar is all the way down & you push the stitch length up & down the needle shouldn't move front to back.So you need to turn the cam(with the forked rod on it on the left w/2 allens on the cam) on the top shaft one way or the other(just alittle @ a time) (when the needlebar is all the way down) until it stops moving front to back.
  24. It threads the same as the Cowboys & we have a video on our website BUT here's Consews manual on your machine. consew 756R.pdf
  25. I'm glad to see you got it fixed,pretty easy too!!
