CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Use size 23 with 207.
  2. When you shorten the stitch this machine like many others it will make the dial alot easier to go to a lower length by pushing the reverse lever down an inch.This takes the pressure off the dial.
  3. Another cause,the motor belt many of them have bulge where they join you can feel it with your finger.Or it could too tight.And since you moved the balancer you should try to put it back the where it was so the #1 feed cam & #1 balancer screw line up.
  4. Judging by the looks of it I'd say it hasn't been used a whole lot & for the price I'd buy it.
  5. @Nico619#458 is a 3/16"x28
  6. We have sold alot of these over the years approx 3000 or more & haven't seen any major problems with them yet!Yes,the feed mechanism is alittle different that the larger 3500 & 4500 .BUT this was made as a lower price machine to get people sewing for less $$.That's why it's limited to 1/2" of leather for less stress on the feed parts.
  7. Yes,it will fit in the table BUT it uses a different knee lifter & might require on belt adjustment.
  8. @ArtD I've sold alot of these over the years & never had a problem like this.If you haven't already you should try to lower the height the feet walk.
  9. They won't work on this machine they are close to 10mm tall & you only have around 13mm foot lift.
  10. @Damas The 441 pressure feet will interchange BUT both the needle plates & feed dog do not interchange with the 441 or the 205.I'm almost certain you can use the standard plate for all of your sewing needs.The only other plate that is available is a slotted one which requires removal of the feed dog,this is used for thinner leather.
  11. All double needle machines need 2-bobbins(hooks) so you can't make a double needle out of it.if you did since it only has one bobbin, the stitch will look like a zig-zag on the bottom side,causing the thread to wear through quickly.
  12. Here's a thread & needle size chart.https://tolindsewmach.com/thread-chart.html
  13. Yes,your going in the right direction,birdnesting underneath is always the top thread.Either it's too loose or not threaded correctly,try tightening the top tension 1/2 turn @ a time until it goes away.
  14. Nice video,the 207 thread sews good on the Pfaff 30.The shuttle in the 15 class allows for larger thread,I've never tried heavy thread on the 201 since it's a rotary hook & usually won't take as big of thread & the 15's are alot more common in this area.
  15. If you want to use a portable get a Singer 15-91 the 201 is best for dress making it won't use the #69 (T40) thread like the 15-91 will.
  16. Since the needlebar & foot bar ride in the same casting there's no adjustment,my guess is the foot is bent ,you can either try to bend it backwards alittle or grind it out w/a Dremel of get a new one.
  17. @TZHunter It is a shirring or ruffling attachment for draperies.There's an arm w/a blade on it w/teeth that grip the material & push it into the foot.It fastens on the shaft in the front.
  18. If it doesn't have the stop on it it's for the 111w only. The 211 tension needs the take up spring stop & the correct part# for the complete 211 tension unit is 244727,if you can't find it we stock them.
  19. The needlebar has on none threaded hole in it so you can see that the end of the needle is all the way up,the one screw holds the needle in & the other one holds the needlebar thread guide on.There are not to many Ind machines that have a needle stop screw,BUT you will see them in alot of household type of machines.
  20. The problem with the 211 is it doesn't use many of the standard screws for previous models (look @ the tap chart I attached) AFAIK the tap kit is NLA either just like most of the screws & many parts for a 211. page0096.pdf
  21. @Jama 211's are good machines BUT it is a re-designed 111W (which you can still buy all the parts for) they changed alot of parts & screws SO many small items like certain screws & other small parts will be hard to find since they've been discontinued yrs ago.
  22. @Leather144, The inner basket of the hook slid out of the position finger when it jammed up(very common problem) so take the black screw out of the position finger (chrome piece) turn the inner basket so the v-shape part is @ the top & line it up so the piece of metal sticking out @ the end of the finger is in the cut-out like in the pic.And oil the inner part of the hook every hour or so,Just one drop.
  23. You can buy belts @ a hardware store,auto parts,lawnmower,etc get it 3/8" wide by the length you measured.
  24. 29-4 Manual.pdf Singer_29K1,_K4,_K10_to_K18,_K21_to_K23,_K30_to_K33.pdf
  25. Most people use Nylon & a #22 will work or even a 23 BUT a #24 will make a big hole & won't look nice.
