CowboyBob
Contributing Member-
Everything posted by CowboyBob
Adler 205-370 kicking out of gear
CowboyBob replied to ScarlettStarlett's topic in Leather Sewing Machines
Yes,we get calls from people every once in a while about the lever moving on them & have to explain it.Glad to hear it helped you. -
Hydraulic shop press as a clicker press for cutting dies
CowboyBob replied to Anubis78's topic in Leather Machinery
Clickers have a short travel on the ram so you can set the depth it cuts.If you go too deep you'll cut up your board.So if you use a hydraulic press you'll need an adjustable stop maybe 4 (one on each corner) but they can be made to work.- 36 replies
- leather cutting die
- clicker press
- (and 9 more)
Yes,Greg ,Thanks now that you mentioned it I have seen the model 360 on these before.
This one looks like a bottom & top feet type of walking foot & the feed dogs will making the bottomside,the 226R has a walking foot needlefeed that will leave a lot less marking on the bottom of the leather.
You can turn it down to the lowest setting,loosen the 2-screws on the collar, turn the pointer to mittel (making sure the shaft doesn't turn), tighten screws & turn down more.
It's a model 226R,setting the way it is you can't sew on it so it might need some adjustment or parts.You will need a table,motor,thread stand, bobbin winder & light,& a drip pan.It will add up w/shpg alittle under $300.00,unless you can search around & find a used one.
This is a very easy adjustment.You need a 10mm wrench & a 2.5 mm allen wrench,take the 10mm & loosen the nut in the pic,take the 2.5 m & put inside the nut on the allen bolt & turn it alittle clockwise & check the tightness of the stitch length handle & when you get it where it doesn't move up& down by itself tighten the 10mm. -
Is This Adler 167 Tension Assembly all Stock?
CowboyBob replied to AlexanderDyer's topic in Leather Sewing Machines
If your machine was a double needle you would have 2-posts(with the tension discs),one on the right & one on the left,on single needles it's on the left & yours is on the right.It really doesn't matter as long as it's working,which it will but I was just letting you know. -
Yes,it original both the single & double needles use the same back plate but the tension post on a single needle is usually on the leftside. -
Some great info for a newbie there!! Thanks!
- 3 replies
- sewing machine for dummies
- leather sewing machine
- (and 3 more)
You mainly need to lube the thread For 3 reasons I can think of is when your sewing real fast,it helps cool the needle so you don't burn the thread,#2 if your sewing dry & or old leather & #3 is when the leather is real thick or if your thickness close to the max for your machine it prevents skipped stitches.
- 6 replies
- lubricating thread
- silicone lubebricant
- (and 11 more)
Help - I think needle broke off in 29k58 needle holder
CowboyBob replied to ELeBlanc's topic in Leather Sewing Machines
Yes,Joe is still servicing machines,I meant blow air in the needle screw hole.The soldering gun might help too. -
Blow some air in the top hole sometimes gets them out. -
Singer 132K SV 11 -> a 132K6 variant?
CowboyBob replied to Constabulary's topic in Leather Sewing Machines
I just sold a CB4500 yesterday to a customer that bought a 3200 a year or so ago & he got into heavier sewing than what the CB3200 could handle & he wants to sell it,He's in VA by DC.If your interested give me a call or message me for his ph#,I don't want to post it here.
Pfaff 545 industrial sewing machine overview and video
CowboyBob replied to gavingear's topic in Leather Sewing Machines
Ok,I just got back from Weavers & bought 32 machines!But I'll be in tomorrow. -
Nice looking machine you have there,you have something to be proud of.
Hey Jeff, Thanks for the kind words,glad you got it so quick. We do as hard as we try not to make a mistake once in a while like anyone can BUT we work on them & TRY not to do it again. Thanks, for your order. Bob
Wendy has Singer 97-10 questions AGAIN =)
CowboyBob replied to wendlynne's topic in Leather Sewing Machines
Oh,one thing about the 1000h is they only come in a round point,the 331LR only comes in a twisted leather point. -
I'm not @ the shop & can back to you tomorrow w/a measurement since we have them in stock.If I remember correctly they are 3&1/4" long. -
Cowboy Sewing Machine Dealers
CowboyBob replied to MendellLeatherOK's topic in Leather Sewing Machines
That's what happens when you make something you noticed all the little mistakes.I had to go back & look @ it again to notice it.LOL! -
Hey Gary,Great looking job there.
