RockyAussie
Contributing Member
Everything posted by RockyAussie
  1. I must admit I must have been lucky here as I have had several printers Canon, Brother and Epson styles 1100 which can do A3 and never experienced this problem with any of them. That is of not much help but I suggest that you consider a small diode laser for this work. I started off using one like in this link a couple of years ago and once you get used to it and a good drawing program you will not have to cut the patterns at all. You have to draw the pattern anyway so why not just laser cut it straight up? https://au.banggood.com/EleksMaker-EleksLaser-A3-Pro-2500mW-Laser-Engraving-Machine-CNC-Laser-Printer-p-1003863.html?gmcCountry=AU&currency=AUD&createTmp=1&utm_source=googleshopping&utm_medium=cpc_bgcs&utm_content=frank&utm_campaign=frank-ssc-AUg-top100-07dp-stage1-0623&ad_id=445107833412&cur_warehouse=AU Once you have the focus right you can get the cut line width down to .25mm on normal printer card stock which is something you can allow for in your drawing pattern if you think necessary. You may find it useful for burning in pictures and other stuff as well. It is fairly easy to build an enclosure and vent fumes away as well as I have done with mine which I have enlarged to be able to get up to full poster size boards. Total cost for building this large and enclosing and adding smoke extraction was considerably under $1000 au. (not including the couple of days labour it took me to build it.) This pic shows how it came standard and I am cutting through some masking tape on a belt for later painting. Here showing removal of the masking tape Because I could not trust myself or my dogs or anyone else to not see the laser going in the open I decided to expand the size and enclose it all at the same time. Here is what it is today. This is a link that shows the very inexpensive but very effective fume removal fan I use - https://www.ebay.com.au/itm/381970877031
  2. No problem friend. I forgot to mention that if that skin is a stiff as I suspect then another thing I do at times before any fabric attachment is sand with very rough sandpaper the flesh side in order to break the tension in it down. DO NOT sand for long in any one area as the heat generated negates the purpose because it sets it back stiff otherwise. Also make sure to hold the skin out flat as you go to not sand into the valleys too much. How are you going with your skiver now days? If you are not very confident it may be better to think about just cutting and edging the edges. Cut some thin strip along the tail edge and give it a go before deciding on your new pattern.
  3. @Fukovskiy to answer your questions properly one would need to get a better understanding of the type of product you expect to produce. I realise that you have mentioned "Specialty:Wallets, belts and bags Interested in learning about:Machinery " Unfortunately the machinery required for this can be quite different depending on the style (carved and stamped with burnished edges using veg tan leathers?) I manufacture very little of that but a look at my profile in the about me section would show a very wide range of products and some of the machinery used to make it. The best I can can offer at this stage is to not buy any machinery until you know exactly what that machinery can do for you and how it compares against other similar machines. I would try and stick with reliable brand names like Adler,Pfaff, Comoga, Fortuna but also take into account the local people that would be available to service any of these if needed. If it were not for the Covid restrictions I would say come over and spend a week or so here but I would urge you to find any local manufactures that would be willing to help you make good decisions with this. I would offer to pay them to show you how the machinery works, how to do the adjustments etc. I have wasted many thousands of dollars over the years getting machinery that is not really ideal for the required work and I could have saved a lot by paying the right people for advice before I started off if I could have found them then. You will see in my profile where I make use of a laser and 3D printer a lot these days and I would make sure I had those on my shopping list early. They save me huge amounts of time and money compared to how I had to do things some years ago. Brian
  4. The centre foot is not holding that thin leather down consistently enough and changing the needle to a leather point (LR) or (TRI) will help but you may need to go up to a size 19 as well. A centre foot that comes down both sides of the needle would be better but that may not work for your application but chances are your application would not need to be that thin and soft either.
  5. The patterning does not look too bad. The skin will need some taming as it appears to be traditional tanning/glazing and may be heavy on the veg tanning going on the under colour I see. With this type of skin you need to quite a few preparation steps as follows - Cut it out so that the it is about 1/4 bigger all around than you finished size. When you cut it out you will see that the skin relaxes and your straight cut lines will be all bowed and not much like your pattern. Next recut the skin to straighten up a bit but still leave it 1/8" oversize around the edges. Now you will need to skive around those edges at least 1/2" in but no thinner than .5mm at the outer edge or you will get holes showing up in all the valleys. (sportif diagonal is way easierfor this part) . Next is to cut some open weave cotton drill about 3/8" smaller than your your outside pattern pieces all around and then fully glue it onto the flesh side of the skin and follow this by covering the top side with some glad wrap and then I use pieces of Masonite smooth side down to rest on top. I then put some weight on top to set overnight. Do not overweight it or you will have the scales end up sitting down too flat and it does not look so good. This process controls how the croc/gator skin bends and folds and stops it from having localised popped out bits on the finished article. The tail section may be good if you can slip the pattern up on one side next to the clacker hole. If not big enough the lid fold could be pretty bad not to mention folding the edges on those round lid corners etc. Could you give me some dimensions to work with and I will draw up a pattern and might make up one along with you if you like. Alternatively I have quite a few bag orders to start on in the next week or 2 and I could picture some of the relevant parts as I go.
  6. Looks like you are getting better at it mate. To offer any constructive criticism on the construction techniques I think we would have to see how you made it or know what stiffener and padding types and thicknesses and the cut out design of them. You may need a heaver stiffener support at the front flap edge if you want to keep using that type of snap fastener but I would think about going to a spring clip type or perhaps small magnets. As to the gusset stitching method I will add that most makers will fake stitch the outer piece and attach it at the tops only. If sanded and glued and hammered down onto a purpose made block it will look better and never come apart if you do it right. The lid flap would be stitched together though. Doing the above using your current method in glazed alligator would be very difficult and the skiving will really come into play. Look for the smaller scale stuff between and above the back legs area if you can or up into the head chin area. If you don't mind the scales going diagonally you will find that it behaves better when it folds on the edges as you tend to not get the furrows in the scale lining up on your folded edge so much. Also the lid flap will not be as likely to have kinks show up when it is down.
  7. Closest machine for the job that I can think of would be the Techsew 2600- https://www.techsew.com/us/techsew-2600-narrow-cylinder-leather-industrial-sewing-machine.html That would get you about 7mm in from the edge and thread up to 138. Some bigger diameter cylinders will get close as well with some modifications but I like the small diameter for other bags and stuff myself. On the end I decided to go with an end cap to fill the hole as shown in the following pictures. This is easier to do if you have a 3d printer as you can just print the diameter and depth of cap you want to cover instead of sanding down a eva rubber as I did in these pictures. This one is the finished bag Looking inside and note the gusset end position The stitch on the outside goes into the lining only and a leather filler cap is glued and pushed into the gap first The end cap is made with design stitched on then attached to a eva foam to fit firmly into place. This piece was the fake croc test piece. This shows the back of the plug ready to glue up and push into place. All the thread in this case is 138 (20M) Note: I don't believe a shoe patcher will give you the quality of stitching that you would want with this type of job myself. If you do go with the Techsew make sure it is the type with the oscillating dog foot and not one set up for binding.
  8. The most common method I use is to draw out the pattern generally 2.5mm oversize along with the finish cut sizes to be done. This then gets printed out on light card which then gets a light spray of contact glue applied to it. Once dry I then can place the card pieces onto a cutting board to cut them out. The advantages are that the contact glue helps to stop the card from moving around on the leather as you go on to cut it. having the rest of the drawing on top makes sure that you can see the alignment is where it should be as you go onto the second cutting steps. Some of this can be seen in this earlier post I did awhile back - Nowdays I often get my laser to draw the pattern on top of card (green lines) and cut out the design all in the one operation and sometimes I elect to 3D print the shapes out If I need to do multiples without going so far as getting clicker knives made up. Some of this can be seen in this earlier post - Brian
  9. You can see at about 40 seconds in where they are forming the curve for the lid over a wooden piece and that the lining is a little over size which would go onto be trimmed off later. The Saint-Laurent purse above is folded on the lining edge (great then no edging colour is needed) which means that the exact size of all of the pieces have to come together just right. The base fold you need to allow for a 180 degree fold as it does not need to open as much and the lid you need to only allow a 90 degree fold as that has to open and close. To some degree you need to get the thickness of all the materials used in the making and put this together on a strip at say 20mm (3/4") wide and fold and trim it as that is then your ruler guide. Warning.. the Dior bag construction is way easier to get than the purse with the folded bottom but if you need to put fittings in first then that is the way to go as shown a bit in a couple of pictures of bags below that I make pretty regularly. This is showing the lining section ready to go in to the outer section behind it -
  10. That is some unbelievably great skiving shown here and I hope one day you can show the technique to all here.
  11. Excellent planning and execution so far The lining looks maybe a smidgeon short perhaps. The credit card pockets are edged and ironed in to perfection and that is worth noting on those inner corners which would have been quite tricky.
  12. I think that we are taking away from the OP's post here somewhat and if you like, we could continue this further in the private message part on LW. Hermes own a lot of different companies and these companies do a lot of other products than what you see the Hermes brand on. What they use from these companies is hard to say for sure but I know awhile back there was a lot of pressure put on getting veg tanning due to a whole bunch of restrictions in Europe regarding chrome tanning. This is not an issue in all countries however. PM me if you want. Regards Brian
  13. Could you show me where you have seen that? If they claim to be a supplier I am amazed that they would make that claim as any supplier to them has to sign a contract that forbids them in any way disclosing that sort of information. They would be gaining a financial benefit by doing so.
  14. Most of the croc skin around is done part chrome tan and part veg. What I said is all of the croc skin used by Hermes is supposed to be veg tanned. I did not read that I was told by someone who should know. I myself don't like the French tanned croc veg so much and way prefer the skins tanned in Singapore (Chek Hong) which are not but if you know something I should know please elaborate.
  15. Yes all of the croc skin and Alligator skins used by Hermes is supposed to be Veg tanned and doing a small intricate job like that you would want to be able to wet mould it. This almost cuts out glazed skin for the job but that can also be done at the expense of not getting as much of the glazed finish back after the job is finished. You can get a very high shine which I tend to like better anyway. I have only ever done a couple of jobs where I have had to resort to wet moulding the croc and although they turned out fine I would rather take the easier way where possible. I don't think I have ever used so much croc on a job as they do there I must add.
  16. I only ever mould the veg part first then contact glue the exotic into place after then go on to put the parts together..
  17. Sounds like a bargain. Just about any machine can have trouble with multiple layers depending on how they are stacked and held together and so on. For example depending on the work and the desired quality of the finished job multiple layers that go from thick to thin to thick etc means that the thread tension really needs to sometimes be tighter and looser as well and that can be an issue for sure. It would help if you could show a picture of the type of work you want to do with it I think. I find this machine good for a lot of things but the height of the post is not high enough for tall bags of some types and things like that need to be be considered. The needle positioner and presser foot lift would be very useful to have with multiple layers for sure.
  18. Excellent innovation there @Gulrok and thanks for sharing.
  19. I tried a few different things along that line and found that the heat generated as the mix goes hard managed to soften/melt and pull it up in most cases. The mould release spray helps but I never found a perfect answer to that part of it. Problem is the more you put on the more detail gets lost so I just accepted that it was a 1 time master. Let me know if you find a better solution.
  20. It can go up to 7mm ok but that is not common in my use. I looked up to find a bit on the sub classes and found some info on this site - http://www2.duerkopp-adler.com/export/sites/duerkoppadler/commons/download/public/268/B_268_EN.pdf My sub class is 268 - VG-3-S and if you look in the pdf file you can see that the 268 - FA -3-S is very similar except that mine is limited to a 4.5mm stitch length and yours can go to 6mm stitch length. NOTE: both of these versions only have a needle range going from 18/110 to 22/140 and that means that the biggest thread would be 138 (20m). I will attach a couple of pictures for you where I am sewing some stiff veg at around 7mm with a 110 needle which is all I have here at the moment I think.
  21. I would be surprised if that punch design would ever work very well myself. Even so I recommend that you polish the crap out of the cutting edge area with some tripoli polish and a rag wheel if you have one. doing this operation by hand is never easy and following the advice that @Dwight gave is good. I would invest in a higher quality oval punch or at least one that does not have a check out for the waste on the long side like that. Some punches like in this fella's page are pretty good if you can get them.https://www.dovesaddles.co.nz/Hand_Tools.php or these http://www.leprevo.co.uk/photos/English-crew.htm Note how they are all polished and smooth.
  22. You're welcome.....dont forget to think about the registration points as well.
  23. For a leather point I think you need a 135x16 LR or TRI like in this https://www.schmetzneedles.com/item/135X16-DIA-Needle-System-100064
  24. If it is the same stuff I used I would say it may be your mixture ratio. I did one plate for a cowboy boot cigarette lighter holder and I did thousands of those with out any problems. Dampen the leather and let it sit until firm mellow and bang under my clicker press ...presto
  25. I have one with the driven roller foot but I have had plenty of other machines with roller feet that are not driven as well and at the end of the day I believe that it does not make much difference. Because the driven roller foot cant spin backwards sometimes seems to hamper going around tight curves but not much of a problem. I used to get pissed off about missed stitches on it at times but later found out that the minimum needle size is 18 and I until then had been using mostly 16. Now missed stitching is rare. I use this machine for stitching my dress belts mostly but it gets used for stitching in zips into our circular coin purses which you can see in this video I made ages ago.
