shoepatcher
Everything posted by shoepatcher
  1. System 88 shank dia. 1.9mm, 332 LG shank dia. 2.0mm glenn
  2. You can actually run #207 on top on these machines. It will sew 10 mm depending on the hardness of the leather or material. I have sewn 10 mm items on them before. Again, this was not saddle leather. glenn
  3. contact Puritan Industries in Connecticut. They are still in business 1-860-693-079 glenn
  4. You get the motor from Cobra? If so, call Steve. glenn
  5. C, Interested to see how you progress goes on this machine. I have not started on mine yet. Adler's to do first. Take lots of pics. glenn I
  6. C, Interested to see how you progress goes on this machine. I have not started on mine yet. Adler's to do first. Take lots of pics. glenn I
  7. Contact Ryan Neel at Neels Saddlery. They are the US distributor for Cowboy machines. he should have copies of the manuals that he can email you. Looks a lot like the Cowboy 2500 glenn
  8. What color is he machine? I can give you a rough age based on the color. If you are looking for the knurl screw that you can lock the butterfly from turning, it is called a stop screw. I need the color of the machine to see which one it needs. i may have some. glenn
  9. Pics of the machine? glenn
  10. WIZ. 29-4 did not have an eccentric for timing the shuttle. glenn
  11. They are rare. No reproduction made to my knowledge. You could contact Seiko and see if they still make the extension plate. glenn
  12. Needles available on line or from Toledo Sewing. You need to determine the class first. The 1 and 2 use system 81 needles, the 3 uses system 88. Can we see a pic of the machine? glenn
  13. New the machine head only is a t least $2500.00 so no $900.00 is not a bad price. They may have cannibalized it for parts which I never do. It is great that you can get the parts. I have a Juki 1508. Had it for over 20 years good machine. it replaced the LU-563. Get all the books on it if it did not come with it. part list, operations manual, engineering manual. You will need them. glenn
  14. Is there any numbers on the cover on the horn? It would either be an 81 0r 88. Also, max. stitch length should be 7.5mm glenn
  15. Wozzer , I got you. Check your messages. glenn
  16. pics of the machine? glenn
  17. Should be a standard "G" size bobbin like Singer 111 as to size. I would get a Pfaff bobbin for a 145. I know that will work. glenn
  18. Pic please. glenn
  19. Heritage tools are now Weaver Leather? I believe Mast Harness Shop manufactured the tools under that Label. If so, it was sold to Weaver Leather years ago. glenn
  20. Look for a mechanics manual for the Pfaff 345. The 341 was in this family of machines glenn
  21. College Sewing only caries parts for the newer 29K machines. Not 29-4 or early K machines. glenn
  22. call Bob Kovar at Toledo Sewing. He sells Consew and may be able to help you. glenn
  23. Look for the parts list for the machine. Henderson Sewing should have it on their web site. It is downloadable. glenn
  24. yep. Consew 287 Narrow cylinder arm would be 277. glenn
