shoepatcher
Everything posted by shoepatcher
  1. Jonnyblaze, There are no generic feet for Claus shoepatchers. Constabulary is correct, do not remove top shaft. Send me a pic of the spring you are looking for and the foot. I may have them, glenn
  2. I would also try Steve at Cobra. He is in your neck of the woods. glenn
  3. The thread does NOT and I repeat NOT go over the pin. The function of the pin is to locate and hold the tensions discs in place. Some of my operators use to put the needle thread over the pin and it disrupted the top tension let alone the thread wearing into the pin. That is a no no. By the way, nice looking Pfaff 345! glenn
  4. Stitch adjustment is on top above the timing belt in the picture. She is a beast. Feet look like they are off a 112W139. This requires more investigation on your part. We need to see the feed dog. Capped bobbin hooks like on a 168W101. glenn
  5. Running thread thru a thread lubricator with silicon lube should cure the problem. glenn
  6. Juki 341 is a heavier machine than the Singer. Juki has high lift, bigger bobbin, and will sew #207 thread! If you need to sew with #207, buy the Juki. glenn
  7. The 2210-6 is Juki's copy of the Adler 767. The Juki is a good machine. The -6 is the earlier version of a machine with thread trimmers and toys. Now they are a -7. I have used both the versions and they are good machines. Medium duty high speed walking foot machines. Does this have the toys or has it been striped to a plain jane? Depending on the thickness of the leather, should sew the canvas and leather with no problem. glenn
  8. A 105-64 is what Ferd built the first Bull out of. That would sew 1" of leather. German engineers from Adler came over from Germany to see the machine and were amazed it would sew. The had never seen anything like it. Ferd's son Ron told me the story some years ago. For those of you who do not know, I am talking about Ferdinand Jean Blanc who was a legend and a genius when it came to heavy leather stitches. I met him some years ago at the IFA show in Atlanta and the Cowboy boot show in Texas. He built the Bull and the Pro 2000. I heard he is in a medical facility now in Idaho. Great guy. glenn
  9. I know what you mean. glenn
  10. That means the lift is 14 mm but it will not sew that thick!!! glenn
  11. send pics of the plate in the back if you can showing model number. glenn
  12. This machine did not pre-date the Consew 227 which was created by Seiko. The Consew 227 machine was a copy of the earlier Singer 153K or W but with improvements. The 153b8b was made for Singer by either Consew or Brother. Maximum thread size is #138. maximum stitch length 5-5.5mm. 3/8"maximum thickness. I strongly doubt you can run #207 thru the machine., certainly not in the bobbin and probably not on the top. glenn
  13. Hydraulic oil ike they use in tractor attachments. Only one or two types made. Your manual was mailed yesterday. glenn
  14. call New England Needle and ask for Tom. He would know or would have them. You could also call Diamond Needle in NY. glenn
  15. Chandler for a long time was the Adler importer here in the US. There were a lot of Chandler Adler machines here. That looks like a 105-64 which is a bottom feed, needle feed machine. Will sew 12mm with heavy thread #277 and up. Good machine. It was the heaviest Adler cylinder arm made until the Ferd came up with the Bull using a 105-64. Then Adler came out with the 205-74 in late1985 which became the 205-370. Uses needle system #328 if I remember correctly. glenn
  16. It look like the 20-2. I would buy it. It has the original bobbin winder on it. Will have to be gone over but that is where projects are both work and fun! glenn
  17. I may have a manual. USMC made the Model A and Model B clickers. They were hydraulic with a pump on them. Not sure what difference was between model A and B. Usually board size 18 x 36 or 20 x 40. 15-20 ton capacity. Hydraulic oil in bottom of the machine in a container to power the pump. Yours has the big head on it. Parts not really available anymore. Most in service have had the electrical board rewired or redone. The model C is a mechanical Clicker called and Ideal clicker. Yours definitely needs new hydraulic oil in it. glenn
  18. Someone buy it. A cheap price. glenn
  19. Awful big hole in the inner foot!!! Do they make a foot with a smaller whole? glenn
  20. I would buy it just because of the rarity and the $100.00-200.00 price glenn
  21. JNN, These old shoe patchers are designed in the old style of the 1880's. Great machines. Bradbury, Politype, Claes & Fetje, Dandy were all designed in this style. The cheap Chinese one is the only one made in this style today. Even Claes' design has changed. The needles it used had no scarf on them. It was designed later. Hooks are almost non existent. However, I found a bobbin that will work in the hook. It measures: dia. 0.604", height 0.206" , hole opening 0.161" Cost $1.25ea. Did you get my email on the manual for the clicker? Call Diamond Needle or New England Needle to get the specs on the #81 needle. glenn
  22. Ok. Machine is a walking foot because I see three shafts coming down. One for needle, one for inner foot, one for outer feet. It is a 138W102 but the SV means special version. The HP does stand for high post. That is a rare machine. Never seen one. The feet changing would probably not be a problem. I had a double needle version of the 111 which was a 111W139 and the feet look the same. The throat plate and feed dog is another story. I think Consew makes a double needle walking foot post that might fit your throat plate and feed dog. We need to see pics of the feed dog out of the machine and the throat plate. what is the gauge spacing on this machine? Should be a number on the feet like 5/16",3/8"., you get the idea. As Greg stated, the most normal gauge spacing is 1/4" in apparel, 3/8" in upholstery. If you ever find prices for the different parts like the feed dog, outer foot, etc., the 1/4" is usually the cheapest because it was the most popular in a lot of fields. What are they selling it for? $500.00 would be a good price if it works in my opinion because of the rarity. Love to see more pics of the machine especially from the front and back. glenn
