kgg
Contributing Member
Everything posted by kgg
  1. I think you have topped out your machines sewing abilities. As a possible solution to the bending and braking of needles I would try a large diameter needle by moving up to a size 22 or 23 needle for the extra needle strength and increase the stitch length. If that doesn't work I would probably would look at investing in a different machine. kgg
  2. I have two question:. What is the combined thickness of all the layers of leather that you are trying to sew through What machine are you using? Also I don't see any attached pictures in your post. kgg
  3. I do change thread size (v69/v92/v138), type (bonded polyester/ bonded nylon) spool size (8oz / 1lb.)and most importantly manufacturer (branded/cheap Chinese). I have noticed variations in stitching even with colour changes, white vs black. I have never done an actual bobbin tension measurement but do the bobbin drop test, adjust bobbin tension as needed and do a test stitch when I make a change to size, type, colour, manufacturer or size of spool. I have found that threading a bobbin from a spool getting down close to about 70 percent will have developed spool coil memory or if has been left on the bobbin for an expended period of time the thread will also develop a bobbin coil memory either is a royal pain. kgg
  4. The question I have is what size of thread are you using or planning on using in the new machine. Then decide on what diameter size of cylinder would be best with patcher type machines nose diameter being the smallest. From that the field of machines could be narrowed down. I do agree with dikman that you probably looking at a 335 type machine. Then decide on brand name or clone, new or used. kgg
  5. I am so glad that you found the Singer 29k to be usable and put some enjoyment back in sewing stuff. The only other suggestion I can offer is maybe fitting the Singer 29k pr similar machine with a table top extension similar too something like Harry Rogers shows in his youtube video called "Simple DIY Conversion Singer 29k Patcher Cylinder Arm to Flatbed". kgg
  6. The old ones may have been able to do V138 thread I can't say for sure but it probably changed when production moved to Shanghai, China. Pfaff now is part of VP Worldwide the same ones who now own Singer. When I checked the Pfaff site ( www.pfaff-industrial.com/en/portfolio/sewing-machines/cylinder-arm/pfaff335 ) in the spec section I found that it uses a 134-35 LR needle system with needle sizes from 80 - 100 Nm and thread size of 40/3. Then I went to the Toledo Industrial Sewing Machines thread chart ( www.tolindsewmach.com/thread-chart.html ) which list a 80 needle at V33 and a 100 at V69 . If I am reading the chart right the Pfaff would have to be able to handle a size 140 needle to get to V138. kgg
  7. Typically where I am, Pfaff's are more expensive for parts thus repairs and are not that common while Brother machines / parts are as scarce as hens teeth. The short answer is yes using a speed reducer. The higher wattage motor doesn't relate to speed rather it will have more torque (diesel vs gas engine) thus more punching power for going through thicker items while better maintaining your stitch speed / motor speed which may cause a lesser rated motor to stall while going through the same stuff. kgg
  8. I think the Pfaff limits you to V69 thread with a max foot lift of 14mm while the Juki can go up to V138 with a 16mm lift. For me V69 is usually the top end of domestic sewing machines and the bottom end of industrial sewing machines. Parts and accessories for the Pfaff maybe more expensive / harder to get then the Juki. Since there is no shipping for the Juki I am going to assume Bills is fairly close to your location. If the Juki 1341 is in good condition. and you can find out what parts / adjustments had to be made and Bills can do any future repairs / adjustments I would definitely go with the Juki but I wouldn't consider the Brother. I did notice no tax amount for the Pfaff machines, why? kgg
  9. From the info I have seen Dick McGahen founded the Craftool company in 1947 in South California and later sold too Tandy in 1959 with some Craftool's still being made in the USA until about 1999. After that they are made in Asia somewhere. Maybe not all the stamps are being made in the same factory so that may explain why some are good while others not so much. With the invent of the CNC machines, 3d printers and computer design programs one would think the stamps could / should be of superior quality to the originals. kgg
  10. If you are planning on sewing seal fur in any amount I would check with the Sealers Association as they would be able to put you in contact with someone close to you. That way you could probably visit and get them to show you what machine works best for seal. Seal is one of the best and heaviest furs out there. The hide isn't the problem for sewing its the fur thus the horizontal edge sewing. kgg
  11. The short answer is yes. Most of the Singers 201's you find in North America are the pot mounted gear driven version (201-2). There were other version of the 201 which were hand cranked (201-4) or belt driven motor (201-3). A good location to look at a 201-2 to 201-3 conversion would be ( https://www.flickr.com/photos/kpinkert/sets/72157622825563869/) or search Treadling a Singer 201-2. If you wanted too you could put a servo motor and or a reducer on it. Hope this helps. kgg
  12. As trash treasure has said cutting a table down is not that hard a job with some basic tools. I table mounted / inlaying a Barracuda using an old Singer treadle base, making a 1 1/2 " table top and making an arrangement to utilize the the treadle foot peddle to activate the foot peddle of the Barracuda motor. If you can modify a standard sewing table then I would forget the portable sewing machine and go with a real walking foot industrial machine either new or used. If you are buying new and only need a walking foot I would recommend something similar to the Juki 1181N. If you go with an Chinese clone there are too many options to recommend one or another. Comparing brand name machines with clones on the Rock is probably going to be near impossible. Some clones are good others not so much. Buy Once, Cry Once. kgg
  13. Haven't see a pair of scissors like that for a long while. I would suggest finding someone with a machine similar to the Twice as Sharp machine that can do multi angles. The steel is going to be hard but when properly sharpened the edge will last a long while. Do not, I repeat, Do Not let anyone use a bench grinder on them. They will ruin them and probably take the temper out of the steel. I had a set of nice $450 scissor for dog grooming which I let some ass try to re-sharpen that I wasn't aware of their sharpening method. Ruined. After that I got my own Twice as Sharp as well a nice 16 inch plate sharpener for clipper blades. Ask a tailor or better ask a high end hair dresser where to send them. It is not uncommon for hair dresser scissors to cost $2-3000 a pair. kgg
  14. The Sailrite Leather/Delicate Foot looks a lot more refined and probably work fine. I look forward to seeing your mods on the feet. kgg
  15. These machines are not the quality you would expect from a Juki so the presser foot can be a bit aggressive with rough/sharp machining. This can lead to hooking, marring or leaving impressions with some materials. So you may have to also play with the amount of tension on the presser foot as well as sand, fill in between teeth or tape over the bottom of the presser foot. The trick is to going to be finding that sweet spot of getting the right amount of downward pressure without damage to the materials surface yet enough to move multi layers of material along. The foot pedal and motor on all the portable sewing machines that I have used act like what you would expect from a domestic sewing machine not that of a servo motor driven machine. The tiny foot speed control pedal is going be a lot more sensitive too downward foot pressure and can be less forgiving. You may have to make a little angled platform to sit the pedal on so you get a more comfortable operating foot position to prevent foot twitch. If you decide on a portable sewing machine keep it well oiled. kgg
  16. Some good options have been suggested by others. From a manual prospective I think you are down to the Cowboy Outlaw, Tippmann Boss , a older Singer 29k with the side crank or a Chinese patcher. kgg
  17. As a note I do have experience with the reliable barracuda and the Sailrite. I found the Barracuda to be a nice capable little machine and if you put the Barracuda alongside the Sailrite with your eyes closed I think would be hard pressed to tell the difference. kgg
  18. If you wish to purchase a portable sewing machine in Canada I think you have three basic options: 1. Reliable Barracuda ( https://reliablecorporation.ca/products/barracuda-200zw-portable-walking-foot-zig-zag-sewing-machine ) at ~ $650 CAD 2. Techsew 611 ( https://www.techsew.com/machinery/industrial-sewing-machines/portable-walking-foot/techsew-611-pro-portable-walking-foot-straight-stitch-zigzag-sewing-machine.html ) at ~$720 CAD 3. Omega WF22ZMW ( https://walking-foot.com/product/omega-wf22zzmw/ ) at ~$475 CAD All appear to be of the same design and features just different names on them. The questions I would check are warranty, if the holes in the bed are tapped for allowing accessories like swing-away binders /folders to be attached and what the max thread can be used. You may find that on any of these machines you are going to probably have too smooth out the presser foot so it doesn't mar your leather. kgg
  19. I use mostly in 1 lb spools Coats Dabond bonded polyester in V69 if I want seams to stand up to heavy bleaching. I also use 1lb spools of American & Efird Anefil bonded nylon in V92 and V138 for extra seam strength for something not going to be greatly exposed to heavy bleaching. I also use some cheap Chinese V69 stuff in 8 oz spools which has much more problems related to spring back particularly in black. kgg
  20. Nicely done. Simple and reusable that gives nice consistent results. It is pretty amazing how 3d printing is changing things. I would expect in the next 5 years as the metal 3d printers become more reasonable in price 3d printing will really move forward. Problem, design solution, and print it. kgg
  21. I would give Chris at Japan Sewing Machine & Supply Co (905) 764-0100. Their website, ( http://www.japansewing.com/ ) is not that good but their service as well as prices for Juki and their own clones are very good. Drop him an email or phone call. I dealt with him for my Juki and found him to be a straight shooter, no BS. kgg
  22. I would go with a brand name like Juki if you are looking to purchase new. For that price you should probably be able to get a Juki 1541S out of Ontario. kgg
  23. Like nylonrigging suggested get a small spool and see how it works for your stuff. For my stuff so far I find bonded polyester better then bonded nylon. kgg
  24. You have a great budget for a machine. I think you need to decide on what thread size you are going to use and how thick the item you are going to sew 90 percent of the time. For the other 10 percent buy a good used machine. No one machine is going to be able to do everything well. You need to find the sweet spot, to light a duty machine and it will struggle or worse not be able to do the job while too much machine will have to be dumbed down and still may not do a nice job. Both situations can be frustrating to say the least. I would advise you take a sample of your stuff that you are planning on doing to a dealer and see what does a nice job. It sounds like your local dealer has both a brand name machine (Juki) and clone machines so you could do a honest side by side comparison. Buy the best you can afford. Buy Once, Cry Once. kgg
