kgg
Contributing Member
Everything posted by kgg
  1. You basically got two options depending on your budget i) find a good used machine or ii) purchase a one armed bandit. i) Tippmann Boss ( https://tippmannindustrial.com/tippmann-boss-leather-sewing-machine/ ) at about $1000 USD plus shipping and it can according to the spec handle up to V415 thread and with a max sewing thickness of 3/4". ii) Cowboy Outlaw ( https://www.tolindsewmach.com/cowboy-outlaw.html ) at about $1395 USD plus shipping and it can according to the spec handle up to V346 and possibly V415 thread and with a max sewing thickness of 5/8". iii) Master Tool Cub ( https://www.weaverleathersupply.com/collections/cub-manual-leather-sewing-machine/products/master-tool-cub-manual-leather-sewing-machine-aluminum ) at about $1999 USD plus shipping and it can according to the spec handle up to V346 thread and with a max sewing thickness of 3/4". Get a machine that meets your needs and budget from a company that you feel will provide good after sale service. If possible test drive various machines. kgg
  2. Just my experience but overall it was just too temperamental for my liking and seemed like it always needed something readjusted from the simple things like top and bobbin tension too set screws in the bobbin drive shaft / gears backing off issues. It might have been just that particular machine, the amount of abuse it got before I bought it, lack of maintenance or that I was asking it to do to much. Then add to the mechanical problems that diaper brown color. kgg
  3. I am going to assume you meant to type Juki DU 1181N not Juki DL 1181N. This is a walking foot not a compound feed machine and is a light duty machine that is rated for V92 thread. To do bridle work you would be better off looking for a class 441 machine. kgg
  4. From the info I have see it is rated for system 134-135 needles in the range 110 - 140 ( #18 to # 22). That to me indicates it can handle thread V69 (40) to a max of V138 (20) in thin material. I did own an old casing PFAFF 1245 for a very, very short period of time a couple of years ago and it was a disappointment. Also it did have a small bobbin. There is a couple photo's of the machine after I overhauled it and it's name plate. kgg
  5. If I was looking for an old machine that was an oddity I would probably consider purchasing it as a keep sake. If I was looking for a something that would be a main stay machine with inexpensive parts / attachments I would not consider it. Without knowing what you are planning on sewing it would be hard to give any suggestions as to what machine would be able to do the task???? wallets, belts, bags, holsters, leather over 3/8" thick. Also what is your budget?? kgg
  6. First off what are you planning on sewing? This machine is a right handed machine rather then the typical left handed machine, parts are going to be expensive, if they are still available. Looking at the photo it appears to have a clutch motor and for better sewing control you will need to replace it with a servo motor about $200 Cad. What is the asking price? If this is going to be your only or first machine I would look at other options. What part of Ontario are you located? kgg
  7. Depending on how many hides you buy it maybe worth while to make a road trip to Montreal and pick your hides. kgg
  8. This could be as simple as: i) top thread path incorrect ii) needle inserted incorrectly and or not fully seated iii) incorrect needle system or incorrect size of needle for thread size. What size of thread are you using with what size of needle? kgg
  9. You could use 3D printed stamps or metal stamps however if this a one of project like @Bert03241 has suggested you would be better off hiring someone or a company to make the stamps. By the time you invest in equipment, learning a design program and the time of doing a prototype it wouldn't be cost effective. The main problem is going to be dealing with the client and what they want / expect the logo to look like on the items (straight impression, burned in, colored with dye or foil, etc). If they already have a logo suggest that they go to whoever did the logo and get them to supply the stamp or stamps if they want different sizes and you just take care of the actual stamping. If they just have a hard copy of the logo get someone to convert it into a electronic file and ask for prices from the various embossing / stamp companies / individuals on the net. @fredkhas made a couple of good suggestions. kgg
  10. I will only comment on machines as I am not familiar enough on the linen thread to comment. a) There are concurrently three one armed bandit machines available: i) Tippmann Boss ( https://tippmannindustrial.com/tippmann-boss-leather-sewing-machine/ ) at about $1000 USD plus shipping and it can according to the spec handle up to V415 thread and with a max sewing thickness of 3/4". ii) Cowboy Outlaw ( https://www.tolindsewmach.com/cowboy-outlaw.html ) at about $1395 USD plus shipping and it can according to the spec handle up to V346 and possibly V415 thread and with a max sewing thickness of 5/8". iii) Master Tool Cub ( https://www.weaverleathersupply.com/collections/cub-manual-leather-sewing-machine/products/master-tool-cub-manual-leather-sewing-machine-aluminum ) at about $1999 USD plus shipping and it can according to the spec handle up to V346 thread and with a max sewing thickness of 3/4". b) There are a lot of class 441 clone machines available between the $3000 and $4000 price range like the Cowboy 4500 (7/8" max sewing thickness with V415), Cobra Class 4 ( 7/8" max sewing thickness with V415) to name a couple. Most clone machines either come with a wax pot or it can be purchased separately. c) You mentioned are planning on sewing several layer so you would be able to use up to three layers of 10-12 oz leather in the above machines but not four. The thing to remember is 10 to 12 oz leather is going to be in the range of approximately 5/32" to 1/4" in thickness ( https://www.leffler.com.au/leather-thickness-conversion-chart/ ). As far as recommending a machine choose one that meets your needs and budget from a company that you feel will provide good after sale service and if possible test drive various machines with your items. kgg
  11. kgg
    Tobacco Tray
    Nice job on the boxer head study. The tray is a nice addition for those that roll their own or use a pipe. I gave up smoking cigs, pipe and chewing tobacco about 5 or so years ago after 50 good years of indulging. I converted to vaping not for health reasons just a 4 pack a day habit was getting a little expensive. kgg
  12. I would buy presser feet and a feed dog to fill with JB weld. First I would suggest two things: i) if the feed dog is leaving unwanted marks check the height the feed dog is above the needle plate. It maybe to high and need adjustment. ii) if the presser foot is causing the unwanted marks try reducing the presser foot tension. kgg
  13. My understanding is that i) the Juki 563 and the Consew 206RB, that you have, take the same presser feet which are the same as those that fit the Singer 111G, 111W and 211W ii) According to the link you provided for the smooth presser foot they are supposed to fit the Singer 111W. iii) the Sailrite Fabricator is a clone of the Singer 111W. iv) The Sailrite portable walking foot machines have specialized presser feet that only fit the Sailrite and clone portable walking machines and don't fit any industrial sewing machine. The price for those feet from Sailrite are expensive at $49.95 USD ( $68 ) and the style reminds me of those that fit the PFAFF 1245 or the Alder 669 as how the center presser foot tightens on from the left side. I wouldn't bother purchasing them as I would just buy a cheap set off Aliexpress for less then $3.50 USD ( $5 CAD ) and fill the teeth with JB weld. But that is just me. kgg
  14. There a lot of clones of all the Juki models but a lot of people seemed to be pleased with the Consew 206 RB-5. kgg
  15. Here is the manual for the Singer Class 7 and should answer your questions. Also here is a link a cross reference of needle size to thread size ( https://www.tolindsewmach.com/thread-chart.html ) class_7_one_needle_lock_stitch.pdf
  16. I think you maybe disappointed with that machine. That machine appears to be: i) sort of a Juki DU-1181n clone, ii) just a walking foot (presser foot , feed dog) not a compound feed (needle, presser foot, feed dog), iii) can handle up to 1/4" max thickness, iv) limited to small max thread size of V92 (one size up from domestic thread), v) can handle a max needle size of 135 X 16 size #22 (140 metric), vi) smaller bobbin then Juki du-1181n vii) low presser foot lift of 10mm viii) Weaver rates this machine as a LIGHT duty machine. I own a Juki DU-1181N and it is a light duty walking foot machine made more for fabric. I think you really need at least a Juki DNU-1541S or clone if you want to do belts and knife sheaths. kgg
  17. In my opinion both those machines you listed are upholstery class machines with one being a cylinder arm machine (the Cobra) and the other a flatbed machine. Neither will do the job properly if at all as both are rated for less then what thickness you want to sew. That leaves you needing the punching power of a class 441 machine. If you want a manual machine (one arm bandit) you will need a machine like the Tippmann Bose, Cowboy Outlaw or the Weaver Cub. If want a motorized class 441 you will need something like the short arm Cowboy 3200 or the short arm Cobra Class 3. What is your budget????? kgg
  18. If it is a Singer don't be surprised at not finding a tap as Singer and some Juki's had their own specific custom thread. kgg
  19. The machine head is going to be heavy expect it to be in the 110 + pounds range. You will need the second set of hands for lifting or moving it. I would: i) use your truck bed for the pedestal stand down laying it on it's side on a piece of thick styrofoam covered with some heavy moving blankets and strapped / tied down. ii) the head is going to be nose heavy and definitely well want to fall forward nose first. So I think the best way to transport it is with it strapped down securely on it's side in the cab on the seat or strapped securely in place stood up in the cab with the nose supported with styrofoam. Best of luck, kgg
  20. The circled part in photo #2. kgg
  21. I would send back the motor for a refund as the cover has damaged the bearing face as can be seen in your photo's. I would not accept a replacement as there is a problem with their cover mold and you are more then likely just going to have the same problem. The problem with keeping that motor is it will never run true and is going to fail, when who knows. kgg
  22. It's the simple stuff that can get you everytime. kgg
  23. A good source for needles and thread I find would be Wawak.com and I prefer the Schmetz Needles whether for fabric or leather. A good article with a photo's of some of the various needle points and what your stitching will look like can be found at https://www.sailrite.com/leather-sewing-machine-needle-types I would recommend changing your needle frequently. Needles and thread are least expensive part of a project. I change my needle after 8 hours of use, when I think it is getting dull, having a stitching problem, been a while since I used the machine last, before starting a new project which ever comes first. kgg
  24. You can probably buy it off one of the reservations just like smokes and gas. kgg
  25. I am not familiar with the bonded thread but BNT69 indicates it is Bonded Nylon Thread in size V69 thread which is the same as Tex 70. The polyester thread size has do with how much weight there is in 1000 meters and in this case 75 grams. Some things to remember: i) Buy good quality thread made in North America like A&E thread (made in Canada and USA) but stay away from Chinese made non name thread particularly the 8 oz spools. ii) Items that are going to be exposed to the outdoors or to bleach Bonded Polyester Thread will stand up better then Bonded Nylon thread. iii) The V69 (Tex 70) thread is the "strong thread" is the thickest thread that the domestic sewing machines can handle and is really the bottom end size / strength wise used in industrial sewing machines. Some industrial sewing machines really don't like trying to use V69. Your machines is rated to V69 to V138 thread and probably would prefer V92 as the smallest size of thread. iv) The strength of V69 is 11 lb, V92 is 14.5 lb, V138 is 22 lb v) When sewing leather with your machine use 135 X 16 with the correct size of needle for the size of thread you are using (leather needles cut through the fibers of leather) and 135 X 17 for fabric with the correct size of needle for the size of thread you are using (fabric needles push apart the fibers of fabric). vi) A good reference chart for thread size to needle size can be found at: https://www.tolindsewmach.com/thread-chart.html vii) Your machine should be able to sew close to 3/8" of material under the presser foot depending on the toughness of the material. viii) If your machine came with a clutch motor change it out with a servo motor to get greatly improved sewing speed control. kgg
