Everything posted by Matt S
Size is sometimes laser etched on, but you need keen eyes or magnification to see it. Class is rarely noted on the needle. If you're really keen you can measure it and compare it with manufacturers' drawings to make an educated guess. Tip is simply a visual check, most common are round blunt, round sharp, ball point for knit fabrics, LR/RR slanted cutting for leather etc, straight cutting for leather etc, and a few other odd shapes like triangle cutting. Run the tip down a piece of leather. If it cuts rather than scores or dents the surface it'll probably work to sew leather though it might not give you the look you're after. Yes, if you have the wrong class of needle your machine will not work. Too short and your hook won't form a loop, or maybe the needle won't even reach the leather. Too long and you'll get needle strikes, which can damage the machine or send bits of needle in a random direction. If you want to try a needle turn the machine over by hand a few times before switching on the motor! Probably. Quality industrial needles of this common sort are £5 per pack of 10. Wrong/worn/damaged/rusted needles can cause a lot more than £5 of damage to your machine, work, person or sanity.
Professional wallet making tutorial (book)
Matt S replied to Danne's topic in Marketing and Advertising
I am curious to know what secrets she reveals in her book that, for instance, Nigel Armitage doesn't teach for free on Youtube or for a modest cost with his pattern packs, book and paid video series. But then my sceptical hackles tend to rise when someone sells their book as "revealing secrets" rather than simply "teaching skills" or "passing on experience". Not $150 curious mind, but curious nonetheless. I don't mind spending that sort of money for information that is useful or interesting to me and not otherwise available. I think I paid nearly that for a video series on a specific shoemaking technique. Books I would happily buy for $150: Servicing and adjusting of band-knife splitters Techniques for reliable and repeatable wet moulding for batch production Modern water/moisture/corrosion management techniques for leather and associated hardware, with special regard to general outdoors, maritime, military and fetish environments A proper modern analysis of fat/grease/oil behaviours in leather and many others on information that either is already out there (but not published), may not have been studied scientifically in depth, or may simply not have been put together in one place before. Wallets, belts, saddlery, holsters are all really popular subjects that are, if not done to death, probably near the market saturation point. With the utmost respect, like what? I'm reminded of the blacksmithing/bladesmithing world. If anything it has a lot more mysticism, myths, "wisdom of the ancients", half-truths, outright lies and promises of "revealed secrets" than leatherwork. A very experienced and wise old smith summed it up pretty well, and I'll paraphrase: It's metal. Once you learn how it behaves (under the hammer, in the fire or slack tub, on the grindstone and when cutting) it's all just experience, practice, process planning and diligence. There's always something more to learn, study, practice or research and you can get very deep down specific rabbitholes, maybe even to a level of understanding on that topic that few others possess but there are really no secrets in blacksmithing. -
Not necessarily dedicated/designed for leather, but should certainly be suitable for leather. Many not-intended-for-leather machines are discussed here, such as the Singer 31K, which is/was mainly for tailors making and altering clothing or the Singer 132K, which was mostly intended for heavy canvas work e.g. tents. These are industrial machines that can be setup to work in certain slots of the wide spectrum of leather work. Equally not all industrial machines are well suited to leather of course, like most garment machines which need to be run at the multiple thousand RPMs in order to deliver oil to their moving parts. Domestic machines are discussed here, within their own context. Many members (including me) are very keen that people reading posts don't take away or have reinforced inaccurate ideas of these machines' capabilities that unscrupulous or inexperienced salespeople often claim. The most popularly discussed domestics here are mid-century or earlier ones with cast iron bodies, case hardened steel gears etc. Frankly they can take a pounding above their design envelope far better than what I have seen being offered on the domestic market for the past 50+ years. But then I'm not an expert, maybe there are better modern domestic or quilting machines that can do it without premature wear or breakdown. Doubt it though. Some people make a hobby of taking older domestic machines and making them what they are well suited and were never intended to do. That's fine as an enjoyable activity in its own right rather than a reliable way of making a leather sewing machine and again has often been discussed here. Domestic machines have been discussed on these fora many times, but like many other topics it can be hard to look through the archives without knowing exactly the lucky search terms. Unfortunately the internal search has always been a little under-performing. I find that using a Google site search to bring up more useful results. I think there's been a reduction in posts here in the past couple years so perhaps the topic of domestic machines just hasn't come up much recently? Limits for domestic sewing machines on leather are, generally speaking, 2-3mm total thickness of medium temper chrome tan or a bit less in veg tan leather unless very soft. Max thread size is probably v69/TKT40 using a size 18/nm110 leather point needle. Max stitch length is generally around 3mm or 8SPI and may be lower on leather as the maxed out tension, potentially grabby foot and not-very-positive feed may not grip the work enough to feed it the entire length of the feed stroke. As 99+% of these machines are drop-feed-only you are very likely to encounter layer slippage unless very carefully handled or your layers are glued together, and very likely feed-dog marks on the underside (which aren't the end of the world, but are usually less acceptable these days than 50+ years ago). There's also likely to be uneven/inconsistent stitch length and formation. Tension will be at or near its limit which will put extra strain on parts like the take-up arm and its driving parts, which will increase the likelihood of breaking or bending. You will probably also have the foot pressure cranked up to max to prevent lifting of the piece with the needle, which may inhibit the easy functioning of your machine. Remember that sewing anything other than thin, soft garment leather will put stresses on a machine that domestics and most garment/cloth type machines simply weren't/aren't designed to handle. Primarily they occur at the point when driving the needle into the material, pulling tension on the thread, and pulling the needle free of the material after stitch lock. This will put strain on the moving and fixed parts that may result in premature wear, breakage or bending. Your motor may also be put under extra strain, as it takes a lot of force to drive the needle into the leather. Older machines (especially those fitted with a hand crank or treadle) are often found to be more useful as their have a heavier balance wheel which "stores" more energy to get through that through bit of the stitch cycle. I don't think I've seen any modern domestic with anything like that, except some Indian copies of 19th century domestics.
10,000 RPM? My burnisher goes 3,000 and is probably twice as fast as I'd like it just for burnishing veg tan. Very easy to burn rather than burnish at that speed. There is a speed controller fitted but it's probably the basic type that massively cuts power with speed (and, as Bruce says above) it's not exactly overendowed in that department to start with. I'd also question what's the duty cycle? Motor housing looks pretty slim, which comparing with similar induction motors probably means a 50% duty cycle of <20 minutes (i.e. run for 20 minutes, leave it off to cool for 20). It may suit those doing one project an evening but I'd prefer to save my money a bit longer and get something with a bit more grunt and versatility at 2-3 times the price. ETA: the first one looks like a brushed motor, which can be noisy to the ear and electrical devices.
Compact and possibly portable sewing machine for watch straps
Matt S replied to suhajko's topic in Leather Sewing Machines
I've just checked the spec and you're right. I'd forgotten that the 246 has a larger hook and bobbin than the 245. -
IIRC the Juki 245 takes a M-size bobbin (roughly 1" diameter and 3/8" thick). Roughly 50% increased capacity over a 111-style G. Even a G-size bobbin ought to be fine for a few dozen watch straps a month I would have thought. -
Your smallest and lightest reliable option is probably going to be something like a Pfaff 335 (of appropriate subclass) or Adler 69. These particular two models have the added benefit of being so popular that mods and accessories are readily available. The head weighs about 30Kg without motor, bobbin winder etc. They are proper industrial machines. Anything less and you lose important features (like a Singer 31K, which is available cheap but is a drop-feed-only, less positive than a compound feed and trickier to get consistent results with for a less experienced operator). For slow speed you should make sure that the machine is equipped with a servo motor. Jack makes popular and reliable ones that aren't too expensive. Unfortunately the minimum/"start" speed is probably higher than you'll find ideal so you will have to put a speed-reducing idler pulley between the machine and the motor. You can either make one with a large and small pulley, a piece of 15mm steel shaft and a pair of pillow block bearings or just buy one from Sieck. IIRC €85+VAT. If you don't have space for an industrial machine stand you can mount them on a sturdy wooden board and put them on your workbench, but then you'd either have to rig up a remote pedal or just turn the wheel by hand. If you can't cough up for a real one, there are Chinese copies available of various quality but being mechanically inclined my preference is very strongly for a second/third/fourth hand machine from a "premium" manufacturer -- Singer, Seiko, Durkopp, Adler, Pfaff, Brother etc. Quality of manufacture trumps a shiny paintjob in my book, but that's not everyone's taste. -
Can anyone help me with a running a 3-phase Juki at home?
Matt S replied to williaty's topic in Leather Sewing Machines
Yes I think you may be right -- we have "full fat" single phase 240v (the European harmonised standard is 230v, but it's really 240v in the UK and 220v on the Continent and usually around 244-247 depending on loading conditions in my workshop) delivered as a minimum. Usually about 100A from a 25-35SQMM service cable (either direct buried or ducted), or 60A for small houses and flats. In reality it's a single phase from a 3ph generation and distribution infrastructure. It's not unusual to have 100A 240v 3ph service to normal houses and small commercial buildings, and I think will become quite common with the increases in electric vehicle charging, a general move away from gas and oil heating, and microgeneration that's expected. It's already common in mainland Europe. In fact we've got it at this house but only a single phase to the service cutout, as it would have cost a lot more in installation and internal wiring costs when we made alterations. It's significantly cheaper for me to run a converter when I occasionally need 3ph than it would be to wire for it. AFAIK we only get split-phase stuff as temporary supplies on building sites (110v, arranged as 55-0-55 centre tapped to ground). We're moving beyond my ken here, as for obvious reasons I only really know how to fanangle our setup. Have you considered a rotary in a "hush box" like for compressors, or maybe installed remotely in an outhouse? -
Progress photos wallet
Matt S replied to Danne's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very neat work as usual Danne! What's the leather? -
Not leather related but too sad to pass by
Matt S replied to DrmCa's topic in All About Us and Off Topic
As others have said, it's a disquieting story with a lot of empty holes where information ought to be. I'm not one for jumping to conclusions 5 minutes after the fact but if no further details have been released 2 months later something doesn't smell right. Maybe someone saw five when there was only 2 and 2 in front of them and twitched if you see what I mean. What's the procedure for investigating a death like this? In the UK all deaths are investigated by a coroner, who then will pass any findings of potential wrongful death to a relevant law enforcement body (usually not the one involved). There's also an automatic self-referral of the police force involved to the independent police watchdog in the event of anyone getting perforated, no matter how justified. It sounds like Mr Kotanko is a loss to the local and international communities. I don't know what Ontario Police SOPs are but in the UK it's been standard to arrange one more ambulances ahead of time if a raid is planned where firearms are known to be present or officers with firearms are sent in. It's not the police's job to be executioner, and it could easily be one of them that gets perforated rather than the suspect. I'm not sure I'd read too much into one being present from the off. I don't really want to get into politics here but the apparent ramp-up of anti-gun unilateralism in Canada the past few years has made me rather uncomfortable. Moving vast swathes of firearms from "non-restricted" (not registered or recorded, just possession of a general licence required AIUI) to the "verboten" list in one fell swoop is idiotic in the extreme. Not only do I disagree with the general thrust and "logic" <coughcough> behind the ban (it's the nut behind the butt which is the biggest potential danger to society IMO, not the hardware in front of it) but there's obviously going to be huge amounts of accidental or deliberate non-compliance, along with overcompliance from people who aren't quite sure what's suddenly turned from a tool or a toy into a massive legal liability. If I were minded to such things I'd cry "conspiracy" but I am a strong adherent to Hanlon's razor as a general rule so, like most bad law, I chalk it up to ignorance and unintended consequence. Mostly. -
It might be that static converters are setup to run a little differently with our electrical grid over here, but as I understand it static converters make an ersatz third phase from the supplied one through a capacitor as you say. That makes this phase lag by roughly 90 degrees, which is "close enough" to the ideal 120 degrees to work okay under most circumstances with a slight loss of voltage and increased noise and vibration due to imbalance. This is the minimum it takes to run a 3ph motor on a 1ph supply and is sometimes called a Steinmetz circuit. It's possible to make a second ersatz phase by connecting a suitable inductor between the first and third, which will lag behind the third (or ahead of the first), which will help the motor to balance a little better and provide a little more power. As more or bigger motors are run simultaneously the closer to 120 each phase will be, and so the better balanced everything is. I ran my 4-motor Fortuna splitter off a static for a few years and you could hear the motors become more balanced as they kicked in in sequence. This is essentially the basis behind a rotary converter -- a big "dummy" motor with no load which is used as a triangular array of inductors with reactances that vary at the right speed all at 120 degrees from each other. Sometimes static converters have a bank of capacitors which are switched in and out of circuit manually or automatically in order to regulate the voltage drop from L1 to L3 across varying loads, however there is always a "run" capacitor in-circuit when running. They will often though have a larger "start" capacitor to get the motor turning, which is only in-circuit for a few seconds before being switched out. -
How about adding a welt the same thickness as the D-ring bar underneath that top-piece? Then the top surface of the top piece would be flat and you could sew as close to the D as you like. On longer pieces you could skive the welt down to a feather edge a short distance from the D so it tapers up to the D ring from zero (taper length an dangle depending on how fast your machine can climb). Or just forget the backtacking and go round in a single course, overlapping your first and last 2-3 stitches. This is something I prefer rather than separate start/end points because it's faster, looks neater and is a bit more reliable tensioning 2x sets of stitches into one set of holes than 3x sets of stitches. If you can't get close enough to the D on one of your short sides due to the bulk of your foot set, try turning the piece the "wrong" way and going in reverse for that side.
I'm not an expert on 3-phase, but from what I can figure out VFDs are actually only any good when directly driving a motor. Nothing -- no contactors, no brainbox, probably not even an overload breaker -- should be between the VFD output and the motor coils. The VFD also tends to need to be programmed for the motor size and load, and of course for any inputs (e.g. controls or sensors) that you might want to use to influence the action of the motor. They're not clever/robust enough to make a more general-purpose 3ph supply from 1ph. Static or rotary converters are more of a generic "1ph in, 3ph out" type converter, but each has its own strengths and weaknesses. Or, I suppose, a motor-generator unit would work, or a fuel 3ph generator. Depending on what you got at what price, and how many bells and whistles you actually want to be functional, you might just be better off flogging the 3ph electronics and buying a couple of good but basic 1ph servo motors. -
I saw this a few months ago and am really curious to tear one down. If it works it'll be a massive game changer, certainly for the hobby leatherworker. I have a "real" band knife splitter, a Fortuna UA. It's a pretty standard 12" model but a little old fashioned. Weighs 800lb including the cast iron frame and stand, 4x induction motors totalling 1.5KW, and the precisely machined steel adjustment mechanisms. Modern equivalents weigh about half that. Before I got my machine I was shopping Camogas with the UK dealer. The chap I spoke with said that they are still so massive (in volume and weight) because that's what's needed in order to tension the knife without distorting the frame. Just no getting around it, basic physics. Having now been elbow-deep in my Fortuna many times I completely understand. That's the first red flag to me about this desktop version: it doesn't seem sturdy enough to withstand the tension needed on a standard band knife splitter blade. I suspect that it's not a full width blade, to avoid stress on the frame. If the blade is narrow it'll have a relatively short life and be more prone to variation in split (the leather will be more likely to veer into or away from the blade).There may also, in the real world, be an excessive distortion of the frame causing things like blade crashes or splits that vary across the width of the leather. The blade sharpening is another issue for me. Band knife splitters, like most edge tools that work on soft materials, absolutely rely on a perfectly honed blade. Leather is an abrasive material and so the blade needs sharpening frequently. On "real" band knife splitters there are a pair of emery wheels which sharpen both edges of the blade at once, to prevent burrs. This may be adjusted for either constant or just frequent grinding. The desktop model appears to use sticky-back sandpaper to sharpen the blade, which I would think would cause a lot of problems with uneven bevels, clogged sandpaper, and being inconvenient enough to not happen as often as needed. The size of the knife wheels can't be very big either, which again hints at maybe a skinny blade or one that's likely to crack prematurely. Just like with a bell-knife skiver scrap sticking to the feed wheel is a common problem when operating a band-knife splitter. The solution is largely the same: a vacuum extractor which pulls the scrap away as soon as it's free. There doesn't appear to be one on the desktop model. This may also be a health hazard as the same system captures dust (from the leather and from the knife grinder) and keeps it out of the operator's lungs. Band knife splitters have a bewildering range of adjustments, mostly for spacing, parallel and tension/tightness. All have to be very nearly dead-nuts-on to work reliably and "want" to shift with vibration, or even to adjust mid-split due to the forces exerted. Frankly I have seen few Chinese-made mechanical devices where the adjustments were accurate, smooth or held tension well. I know that not all Chinese products have screws made of cheese but colour me sceptical by experience. As a result reliability, repeatability and accuracy are likely to be suboptimal. There also seems to not be enough physical space in the machine for half of the necessary adjustments, which would leave them factory-set and prone to wear. Speed also seems to be something that the desktop splitter doesn't do well. That's not the end of the world because it's not exactly a production machine but I bet splitting the components for a half-dozen billfolds would get very boring very fast. It is my repeated experience that electrical safety of direct-from-China machines (rather than made in China to Western design/spec machines) leaves a lot to be desired. This a mains powered metal cased machine. I make it a policy to check the wiring of any mains powered machines that don't come through a proper UK dealer. I have never wasted my time by doing so, and never had to not correct a design or manufacturing fault or shortcut. Similarly mechanical safety may not be up to snuff, certainly for use in a workplace, but I'm not well qualified to discuss that. Finally, it looks like feed roll tension is adjusted with the pair of silver hooks under the front. They look like they're straight off a bell-knife skiving machine. I doubt they're up to taking much tension, and certainly don't have much "granularity" of adjustment (5 steps IIRC). Maybe the fine adjustment is what that wheel's for. It certainly doesn't seem to be up to the sorts of tension I have experienced on a "real" band-knife splitter, though admittedly I have only run a grand total of two. For reference I weigh about 160lb and have to put at least a quarter of that on the pedal to counteract the tension on my Fortuna. Well that depends on exactly how "tolerant" an individual may be on thickness. 0.1-0.2mm thickness variation across a hide is pretty standard these days and for most projects there's a fair bit more leeway available. I'd say that location on the hide, grain orientation and choice of hide for appropriate hand/texture is probably important than getting exactly the correct thickness to the nearest 0.1mm. I understand that having leather split can be difficult with minimum orders but once we're talking about plonking down $5K you could probably afford to get every hide you're likely to use split to every thickness you're likely to want. 100% with you regarding the bell knife skiving machine. I just hate adjusting mine (never been much good at it) so once it's set for a job there it tends to stay until I really need to adjust it for the next one I can't do without it!
I'm going to take that as a yes. You make some cool looking stuff. You have an eye for design and you're clearly pleased with your work, but I really don't understand why you like to imply on the internet that you're actually stitching the leather through with your machine. The amount of effort you use to get that contraption to do something it's really not suited for is impressive. If you presented the steps and time it takes you to use one of these machines to put 207 size thread through holes you've already punched through the leather on an open forum, with an honest discussion about its severe limitations that several people have tried to discuss with you, I'd be more impressed. This forum has some of the most honest and generous tradespeople I've ever encountered. I don't think it's fair of you to advocate to beginners to spend their time and money on something that, at best, will need a considerable amount of skill to sew leather to a mediocre standard at roughly the overall speed of hand stitching.
Is that with or without pre-punching the holes?
One of the great things about making stuff out of leather is that there are many ways to skin a particular cat. Your design is very clever for being so efficient. I think that I would prefer the design in the OP as it appears to have more positive retention and the increased rigidity is less likely to rotate up on the belt during a hasty reload. To each his own.
Help! My cat peed on $300 worth of unused veg tan leather!!!
Matt S replied to SlickWilly's topic in Leatherwork Conversation
Well yes and no. Piss was used as a weak base in the pre-industrial world, and amongst other things used in the liming of hides (soaking in a basic solution to aid in removal of hair and fat before tanning). Tour any tannery and you'll find some rather pungent scents in the "not yet leather" stage that you wouldn't want in your finished product. I've dealt with bodily fluids from many animals and wouldn't countenance anything that came out of the hind end of a carnivore in my workshop. I certainly wouldn't want to inflict that on my customers. If it were me I'd cut off any particularly bad sections and bin them, then wash the lot in plain water with some vinegar thrown in, and allow to dry flat. Especially somewhere with a breeze. -
That's a neat design! As @Hags says, once they got the design just right it's an ideal candidate for a clicker die. I reckon it's regular old tooling russet. Maybe some skirting scrap if they had a source from a Western style saddle maker. Shoulder would be my preference, but any not-too-stretchy part would do fine. How much leather do you guesstimate is in the thing? Maybe a quarter to half a SQFT? Even if it came from "virgin" hide not scrap/offcut you're not looking at an awful lot of $ of raw material...
Well you didn't exactly make it clear in your OP that you were looking for the cheapest supplier, just that you were struggling to get any! I was "there" in 2020, most of my business is dog collars. I was scouring every supplier I could find in the country for suitable buckles, cleaning most of them out. Most of my leather suppliers either closed their doors for a while or couldn't restock. I ate some of the increased costs, raised prices a little, and simply turned away work when I couldn't get materials at the right price. After that I started reading about business resilience planning. $2 hook on a $14 item. That's a tight rope to walk, especially if that includes postage. Part of the problem when selling a narrow-margin product is that any price increases eat into your profit, and something has to give. Buying/stocking large quantities of material helps to get a lower per-unit cost and insulates you some against price and supply issues but you're still relying on a chain with an awful lot of links, many of them recent world events have proved to be be far weaker than previously believed. They're showing out of stock RN, but it may be worth reaching out to Weaver (some of their lines are getting restocked very soon). Their solid brass 3/4" square eye swivel hooks are <$2 in small quantities, and looking at my wholesale catalogue significantly less in large quantities. I would again suggest that you avoid relying on retail-type wholesalers (middle-men resellers, probably a lot of their product coming from China) and research US-based trade suppliers and manufacturers. As I said before UK "hard" manufacturing is a fraction that of the US and I've got several to choose from. There's got to be something for you Stateside. (Incidentally VAT would be discounted for a sale outside of the UK, it's a domestic-only tax.)
@TomG I've bought hardware from China when I can't get what I want from closer to home, but can you seriously not find it in the US? The UK has a fraction of the manufacturing capability of your country and I have two foundries I order from regularly. Often with next-day shipping. They're 2-3x the cost of the ones from Chairman Xi's Workers' Paradise but it's well worth it for the quality, the speed of delivery, and keeping the money and skilled jobs onshore. These are the two I use, both long-established firms in Walsall, the traditional home of English saddlery and associated leather trades: https://www.abbeyengland.com/ (you'll need to sign up for an account to see prices) https://www.fmartinandson.co.uk/
I've bought some stuff on there. Rivets, snaps, and a few small pieces of machinery. Not my preferred choice of marketplace or country of origin, but there are few options for what I was after. Everything has worked out that I've bought from there, but wouldn't buy leather from there. There are far better options for not much more money, and not all leather is made equally. My time, even when doing hobby rather than job leatherwork, is worth more than the difference.
Double Needle machine for single needle use?
Matt S replied to krausewich's topic in Leather Machinery
How do, Mike! For normal flat-sewing work you generally you can just take out the needle and bobbin you don't want to use and go at it. If you aren't likely to use the second needle very often, move the unused shuttlehook assembly out of gear by moving its bevel gear out of mesh, or moving the assembly away from the driving gear. You may be able to get a flip needle holder for your machine, which allows you to engage or disengage each needle at will. That's quite handy for twin-seam square corners. I don't recall seeing many cording/piping feet for twin-needle machines, but I guess some 111/112/211/212 style feet might be compatible. -
Were chaps an Anglo thing in the 18th century or were they still the preserve of the vaquero at that time?
Really? They must be hiding that in the small print somewhere. This is the UK version of their page about the paid and free accounts. I wonder if you could point me to where they have that? I'm intending to buy a Cricut and run it on my own drawn pathways but not keen to pay every month for the privilege of using a machine I bought outright.
