Northmount
Moderator
  1. Nice job! Tom
  2. Interesting story. Thanks for posting. Tom
  3. Do a google search like this "site:leatherworker.net how much length to add for thicker belt" without the quotes. site:leatherworker.net restricts the search to this site. You can change the search string (words) to refine your search. If a term you don't like keeps popping up in your search, add it to the search string with a dash in front of it (-lazy). One of the posts the above search string found is A refinement to the search string could be remove thicker and add lined. Try different words if necessary to find or narrow the search. Tom
  4. Take the handle off and make sure it is well supported. Cast Iron doesn't do well when dropped! Tom
  5. This topic has been posted about a number of times. Have you tried a search? Mathematically speaking, the increase in outer circumference would be 2 x added thickness x pi (3.14). (back to basic math) Tom
  6. @Jacktheboatguy Moved your post - Even though you aren't sewing leather, you'll get more response in this area - Leather Sewing Machines. Tom
  7. @kimosabi66 Moved your post to Marketplace -items For Sale -Machinery -- Cutting/Leatherworking -Used All items for sale should be in the Marketplace area. Please read the Marketplace rules at https://leatherworker.net/forum/forum/70-announcements/ and comply with them. You need to provide photos, full descriptions, condition, etc. Members may reply here or by PM. Tom
  8. @OldRedMule Moved your post to Saddle Identification, Restoration & Repair. You should get more response here. Have you searched through this area? Tom
  9. Looks to be a heavily built machine compared to many. Try contacting https://www.facebook.com/pages/category/Product-Service/Jason-Systems-391906050959698/ Sees to be quite a few ads on the internet, from about 2016 and up. So doesn't seem to be a big seller. Tom
  10. Do you have a manual for your machine? There have been posts here about balancing the forward and reverse stitch lengths on some machines. Try a google search "site:leatherworker.net balance forward and reverse stitch length" without the quotes. You may need to adjust the search parameters by including your machine mfg and model. Tom
  11. @Jay6040 Have you read this post? Tom
  12. @Vladinard Moved your post to Leather Sewing Machines. Have you done a search for info here? Try a google search "site:leatherworker.net Junker & Ruh SD28" without the quotes and you will find several posts that reference them. Tom
  13. Presser foot pressure too low so the leather lifts a bit at times, loosing the loop so the hook can't grab it? How thick is the leather, hard or soft, thread and needle size? Tom
  14. Ed hasn't visited the site since July 13, 2017. @esantoro Tom
  15. @LeatherinCornwall Moved your post to Leather Sewing Machines! Tom
  16. @Jzamora21 Moved your post to Leather Sewing Machines. As Rocky says, you are more likely to get answers in this section. Tom
  17. URL / Link is fixed Tom
  18. Hack into it and set the throttle full bore max speed! Watch the operator with a built-in camera when the machine takes off. Tom
  19. I've seen some comments here about using deglaser to remove at least the surface oils and waxes. Another experiment for you? Tom
  20. Yay! Works for me! Tom
  21. If you set a permanent security cert exception, then all logins go right through with no warning. I'm still seeing it this morning. This is all part of the same problem. Tom
  22. Still being worked on to resolve. Tom
  23. I use a couple that sit on my table with the large holes. I group my tools and put like tools together. Tom
  24. It is being worked on. The hosting site was supposed to automatically update the security certificate, but it didn't, and of course it happens on the weekend when there is even less support. Tom
  25. Don't try using in a powered portable drill! Can wrap things up in a hurry! For powered use, use it in a drill press, and what ever material you are cutting should be clamped down securely. Tom
