What was the resistance (ohms) between the black and blue? I assume you had the power switch turned on? If so, the only choice is black and blue for 220 VAC. From the 3 phase circuit diagram, it appears the hydraulic pump runs continuously and that the push buttons (item 9) and possibly microswitch 8 on the handle activates the solenoid (10) to switch the hydraulic valve to provide force to actuate the clicker ram. Switch 8 is the end switch to stop the ram at end of stroke. On your home/shop wiring, the 3 conductors from the breaker panel are typically red, white and black plus bare ground. White is neutral and is not needed for 220 VAC. Red is 110, white is 0, black is 110. So the voltage between black and red is 220 VAC. Tom
Singer 111W155 Timing/thread Issues
Northmount replied to TSquared's topic in Leather Sewing Machines
This is only a shortcut link from your computer. Not the pdf. Please retry. Tom -
Use with the matte side up. Pencil or pen works better on the matte side. Shiny side against the leather. Tracing or drafting velum works nice too. Got a part roll when they switched to plotters for drafting printouts. No cost was nice. Tom
The diagram on page 13 of the pdf is for a three phase motor. Item 1 is a manual switch. Item 2 is a thermal overload breaker. When you hook up a 3 phase motor, you hook each of the phase connections to the 3 phase supply. Then do a bump test to see if the motor rotation is correct. If it is not, then you reverse any 2 of the 3 connections to change the direction of rotation. You can prove the continuity with a multimeter set on resistance (ohms). Resistance will be less than 500 ohms. Turn switch 1 on. Test the resistance across the wires. Clip one lead from your multimeter to one of the wires and keep it on that wire. Test the resistance to the other 2 wires. If there is continuity in both of these tests, and the resistance values are relatively the same, you have a 3 phase motor. Tom
What is the info on the motor nameplate? Would help to know if it is three phase or not. Sounds like the cordset is using European wire colours. What kind of plug was on the end, or is it supposedly setup to be wired directly into a box? Tom
Bar C, you have a couple people interested in this equipment. See above posts. Tom
- 7 replies
- sewing machine
- rivet setter
(and 3 more)
Vinegaroon tutorial
Northmount replied to scooby's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Look at Will Ghormley's website. http://www.willghormley-maker.com/MakingHOGRig.html Scroll way down til you get to his rust tank and read through it. Tom -
Take a look at Ohio Travel Bag, called key plates https://ohiotravelbag.com/shop/search.aspx?term=key plate#f=&p=1&s= These are not removable, but are close to what you are looking for. I think the removable ones fell out of favour due to loosing keys when they loosen up a bit. Tom
Glovers needles are triangular point, harness needles are round point. The triangular shape has sharp edges and that is what is cutting your thread when doing saddle stitching with them. Get harness needles. Tom
Do a search here for rawhide mauls. There are a couple threads about making your own. You need to take the maul apart, figure out where and how to remove the nuts from the bolt. Then all you do is cut a stack of washers basically and put it back together. These other threads will give you more info. Tom
How to avoid leaving pressure foot marks on Veg Tan Leather?
Northmount replied to IvoryCreek's topic in Sewing Leather
Newspaper ink smears and leaves marks on leather. Then you have to clean it off! Tom -
What do you have? Tom
I've used pine, fir plywood, etc. Moisture is not going to change the shape/size all that much. Plywood might de-laminate over repeated usage. You don't need a lot of pressure, so that shouldn't be a problem. Leather does not normally need to be saturated with water. Wood with rough grain will emboss the leather surface, which you may or may not like. Clamping against a smooth laminate will keep the leather surface smooth. You can varnish or wax wood to reduce the amount of moisture it will absorb. You can also use high or low density polyethylene, like kitchen cutting boards. Or UHMW Polyethylene. You will still need some hand or power tools to cut and shape the material. Wood is easier to cut, carve and sand to the desired shape for molds. Handy hand tools would include a coping saw, hand saw, rasp, mallet and chisel, sandpaper, ... Tom
Daughters Project
Northmount replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Reduce the size of your picture, then you should be able to post it. Lots of links here and elsewhere on the web about reducing your picture size. Search them out and give it a try. Tom -
Their is someone in the Montana area the flies falcons and makes hoods. http://lchoods.weebly.com/about-us.html Tom
- 7 replies
- help wanted
- hood
(and 1 more)
Vintage Al Stohlman Swivel Knife Info
Northmount replied to maritimemoose's topic in Leather History
I'm surprised. Sold for less than $50 when I bought mine. Tom -
Sold by Tandy 5 to 10 years ago. Nice large diameter barrel. Nicely shaped yoke, easy on the fingers. Bought it because of the yoke and barrel diameter. Not because of the fancy work! Tom -
Edge Guide for Consew 225 (and clones)
Northmount replied to KeithHideWorks's topic in Leather Sewing Machines
more switchable magnets http://www.leevalley.com/en/wood/page.aspx?p=56000&cat=1,43838,47843 Tom -
Machine help- too much good info- please.
Northmount replied to Brad2017's topic in Leather Sewing Machines
Sitting on the fence doesn't get you anywhere. Pick a machine in your price range that is in good condition and is suitable for your work and fly with it. There is always something better out there, but in the meantime, you will have a machine to use and build your business with. With the experience you gain, you will be in a better position next time to decide what is best for your next acquisition. And you will have had some cash coming in along the way. To me, the important part is servo motor and possibly a reduction pulley set if you are sewing thicker and harder temper leather. And a cylinder arm is more versatile than a flat bed. Tom -
If you are taking an LTO, there is no need to pay out early. Better to take the tax write-off and keep the cash you have in hand to keep your business going. Being able to write-off leasing costs is only beneficial if your business is making enough money to use the write-off. If you are just a small part-time business, hardly making it pay for itself, there is no benefit to LTO. Get a good positive cash-flow if you really want to be in business. Tom
- 21 replies
- financing lease to own
- loan
(and 3 more)
Edit is only available for a short period of time, so after it has timed out, just do as you have, adding a post to the thread. No stitch groove for thin leathers. Probably max #69 thread with max #14 needle size. You can get leather tape, or double sided seam tape so you can turn the edges instead of trying to crease. You should be able to use a home sewing machine since you are dealing with very thin material. Maybe 15 stitches per inch. Too close together and the leather will rip along the perforations. You should experiment with some small pieces first. If the fur gives you a problem, you might need to shave the fur along the stitch lines. Do a search here for sewing fur. You will find several posts. Tom
- 3 replies
- needle thread
- sizes
(and 2 more)
Look at the 2700 and 2750 at http://www.techsew.com/machinery/industrial-sewing-machines/cylinder-machines.html Techsew is in Montreal and ships to western Canada. Online quote will show sipping cost. I have a 2700 and am happy with it. Also http://www.leightons.ca/catalog-general.html Leighton is near Red Deer, Alberta. Both places may have second hand reconditioned machines so give them a call and see what they have. For bags and such, a walking foot cylinder arm would be a good choice. You can add a flat bed table accessory for typical flat sewing. Tom I see that Leightons is no longer on the web. Must have gone out of business or let their domain name expire.
Nothing wrong with using crooked in a name. We have a pair of lawyers, Richards and Crooks. So their email address is RichCrooks@xxxx. Easy to remember, and catchy. Here is an old brand book if you want to look at various brands for ideas. http://booksnow1.scholarsportal.info/ebooks/oca4/42/albertahorsecatt00albeuoft/albertahorsecatt00albeuoft.pdf It is a large file, takes a couple moments to load. Tom
two old saddles
Northmount replied to KornelKobak's topic in Saddle Identification, Restoration & Repair
There are a couple old saddles listed here http://www.kijiji.ca/b-alberta/antique-saddle/k0l9003 that have some similarities. Could be made by Great West Saddlery. Also look at this post. Makers mark is like a horse shoe. More links here https://www.google.ca/search?q=great+west+saddles&ie=utf-8&oe=utf-8&gws_rd=cr&ei=jOqIWJLlA8OmjwTo5bSQCg Tom -
two old saddles
FO Baird won't be the Calgary Saddle. Tom
