Tree Reaper
Contributing Member
Everything posted by Tree Reaper
  1. Two part epoxy like JB Weld.
  2. I'd switch to pull the dot. How are you cutting them?
  3. What make are the snaps and how much post is above the snap prior to setting?
  4. It should come off by wetting it with a damp clean rag.
  5. Looks good, your work is improving with every new project.
  6. Search for "circle cutter" http://www.lionop.com/circle-cutters/
  7. That's a whip finish used for rope ends. It's designed to lock, that's why they tell you not to tighten it too much.
  8. That's why I was asking, most common buckles for dogs are one inch and smaller. Webbing might be another choice as well.
  9. Are you planning on using a 2 inch buckle or stepping it down to one inch?
  10. It depends on the strength you require. A double fishermans will work but you won't be able to load it because it will pull back together until the two knots lock. A prusik knot or blakes hitch will lock under load and is adjustable.
  11. Check the banner up top for Barry King.
  12. They look good, thanks for posting the pictures.
  13. I usually tack the upper left corner down and strip the leather from the right side. Make sure you have a new or very sharp blade. Sometimes it's necessary to cut the leather into smaller manageable pieces.
  14. I would have liked the bags to come out the bottom but the length of the belt clip wouldn't allow it. The case would have been too large.
  15. Thanks Mijo; The flap is fairly stiff on this one and it opens easily. I used it last night and it worked well.
  16. Welcome to this forum Azur, I hope your project goes well.
  17. I have the same problem. Wrote them twice to ask about my order and no answer. If it isn't here in a day or two I'll have to call them. POOR SERVICE
  18. From the album: Tree Reaper
    Bag dispenser for dog owners.
  19. You people with dogs will know what this is.
  20. I usually wet it and then bake it in the oven but there's a fine line between hardening and ruining. Lowest temperature for twenty to thirty minutes max.
  21. You're welcome. The punch sizes will be very close to the buckle size but everyone sooner or later acquires them all.
