Tree Reaper
Contributing Member
Everything posted by Tree Reaper
  1. Very nice Tanya, good detail.
  2. What type of thread will you be using?
  3. Thank you; The only real problem I have is with the battery box. The switch is on the bottom of the box and has to be relocated to the end. The top slides off to replace the battery so why they would put the switch on the bottom is beyond me.
  4. I stitch and burnish liners. I don't see any stitching here.
  5. 5/8 punch works good for 5/8 buckles. Kevin.
  6. Thank you Mijo, I appreciate the compliment.
  7. Thanks. The pictures are two of the same collar. They are automotive LED strips bought two in a package at Walmart and powered by a 9 volt battery. The cover slides off the battery box for battery replacement.
  8. Here's another night collar ...
  9. Did you try with damp leather?
  10. The leather was cut on a curve and then stitched.
  11. Looks good Jaan, did you put a welt in there to protect the lace from being cut? Kevin.
  12. Thanks everyone for the help, I talked with her tonight and she now wants one inch wide webbing so this will be easy, thanks again. Kevin.
  13. You can make the holes and then dye.
  14. Thanks for taking the time to search, I saw that but it's lighter than what I was looking for. The thickness I wanted is closer to .095" and ten yards is about 9 more than I'll ever use. I hate to bother anyone for a measly one yard but it's most likely a one timer. I tried talking her into leather but she's set on a bright neon like nylon. If I can't locate it I might end up with the thinner webbing but I hate to settle on something I won't be as happy with.
  15. Thanks Tom.
  16. Hi, I have a friend that wants a lime green webbing collar for her dog, 1 1/2 " width. I've tried searching but haven't had any luck. Anyone have a source? Thanks. Kevin.
  17. I use a foam brush, mink oil on the finished side and masking tape on the flesh side.
  18. You have to paint on a block out or resist to the areas you don't want dark prior to applying the dye.
  19. I haven't used shoe goo, Locktite brand super glue is also what has worked well for me.
  20. I would use crazy glue and clamp it closed. Put wax paper between the clamp and leather. The crazy glue will run into the bottom of the crack.
  21. That's smoke'n hot! Nice work.
  22. It's easier with more space to work with. When I stitched a set of saddle bags it was nice not having to struggle with them.
