Everything posted by Tree Reaper
Box Pocket--How To Neatly Trim Excess Leather Flaps?
Tree Reaper replied to thekid77's topic in How Do I Do That?
If you get foam rubber about an inch thick,( two is better)specially made for forming wet leather you can put your wooden form on a piece of plywood,wet leather on top of that , the foam on top of that and another piece of plywood on top of that then clamp the entire works together using C-clamps or a vise. I use a 10 ton shop press. 40 durometer foam is too stiff but there is some foam here that I have yet to try ... http://www.knifekits...roducts_id=4293 I'm forming some cell foam cases today, just took the mold out of the shop press. This will make two cases. A few scraps of wood will work after forming but the molding process is easier when more than one item is being made and the finished product will look better coming out of a mold. -
I agree with Dwight that you should mold the leather from one piece and avoid seams. If you don't have the tools to make the matching forms then foam rubber can be used to mold the case over a simple block of wood. -
You might have to heat one up and bend it.
Have not used crayon, I sand, dye and then burnish.
Sand it out and re-burnish.
Underbust Holster In Action
Tree Reaper replied to ReneeCanady's topic in Gun Holsters, Rifle Slings and Knife Sheathes
More of a bolster than a holster. -
Shoot for 1/32. Rotate the punch off center once you initially set it. You can buy a forstner bit and drill the leather also. http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/forsbit.htm?zoom_highlight=forstner+bit
Get a good quality fastener like DOT. They have different length posts for different thickness in leather.
If the stamp itself didn't work you can brand it if you use a metal stamp. A one ton would be enough for that.
Looking For The Help Of Someone With A Lathe...!
Tree Reaper replied to ItsJustNC's topic in Leatherwork Conversation
If it's worth $20 plus shipping, you can send it to me. Kevin -
What you really need is a threaded end to screw a nut on to hold the burnisher in place. You can use a piece of dowel or broom handle and bore a 7/32 hole through the middle and hold it in place with the nut. You can put grooves in it with a file or sand paper. -
I have a cowboy 4500 and it isn't really meant to sew watch straps but it will easily sew anything else. The biggest problem with sewing small leather goods like a watch strap is the hole in the plate is too large and the leather will get pushed down inside the hole. You can buy a plate with a narrow slot but you lose the feed dog.
Armguard With Snakeskin Inlay
Tree Reaper replied to Geronimo's topic in Collars, Cuffs, Leashes and Leads
Very well done, I hope that rattler stays connected, they're pretty flimsy. -
Flip the wallet over and sew from the finished side towards the inside. Back up interior down.
That first belt looks like it might be synthetic, the harness looks leather and it's advertised as leather. The harness belts could be made with veg or chrome tan but you will want two finished sides so 5oz. will be heavy unless you can split it. I would look for a predyed hide in the colour of your choice. Kevin
I have used a similar idea incorporating a drill press and a pin vise. The biggest problem is having the leather come back up with the awl because there's nothing to hold it down like a foot on a sewing machine.
Torn Leather Car Seat - How To Restore
Tree Reaper replied to DStar's topic in Leatherwork Conversation
I'm afraid it's terminal. Where ever you made a repair if it was even possible, it would still deteriorate outside the repair. The material is done and will only get worse with time regardless if it's leather or vinyl. -
Mexican Loop Style Knife Sheaths
Tree Reaper replied to Josh Ashman's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very good, thanks for taking the time and posting the pictures to explain that. Kevin -
Did you try the white compound? These work good also ... http://www.ebay.com/itm/6-Gray-Rubber-Polishing-Point-Cylinder-Dremel-427-Rotary-Dental-Jewelry-240-grit-/320854472747?pt=LH_DefaultDomain_0&hash=item4ab46ab82b
Very nice , is that a friction fit or is the sheath attached ? Kevin. -
I use a wheel and green compound to sharpen my awls and knives. I started with a felt dremel wheel and compound and it worked so well I bought a large machine with 8 inch wheels.
