And I wish I could pick up some vintage Singers models on your side of the pond
can you open a new thread and post some pictures
Thats how different things can be. Lots of folks on my side of the pond are not willing to drive 2 hours for a sewing machine. I have no problem with 4-5 hrs one way but thats my limit and it really must be worth the trip. I usually try to combine the trip and pick up something else or take a day off or visit a friend or so...
Wild guess w/o having seen your machine. Probably the stitch length adjuster assembled the wrong way. The squared frame and the gib have a "wedge" which have to be in a positioned correctly. The wedges give the presser foot bar space for its movement (feeding). Could also be that the parts are worn or damaged. I would also try to increase the foot pressure and clean and oil the machine and the involved parts thoroughly. A few pictures of your machine could probably help
Problem of Site not redirecting to forum properly?
Constabulary replied to kgg's topic in Feedback and Suggestions
Google search still does not work, it is still redirecting to the main forum site but not to the thread I wanted to go to. -
Machine maintenance/repair advice
Constabulary replied to BearNorthwest's topic in Leather Sewing Machines
check the needle / hook timing - often the needle bar is a little bit to high. W/o sitting in from of your machine - I would try lowering the needle bar by 0.5 - 1mm. -
Agree with the hand wheel the 211 is not a candidate for a larger hand wheel. However - you do not find many walking foot sewing machines of this class for just $300. Even when you have to invest in a new servo motor and a speed reducer (you can also DIY a speed reducer) its still worth the money. If you do car upholstery and sew belts, guitar straps, wallets and stuff that is not thicker than approx 8-9mm with thread no thicker tan 138 then this is a good machine when properly set up. I have the 111G156 predecessor of the 212G156 and 212G141 2 needle / needle feed version of "your" machine. I cannot complain. But the decision is finally yours.
Singer 111W153 presser foot lift height
Constabulary replied to Sugarkryptonite's topic in Leather Sewing Machines
Okay - I just thought the fork piece with the slider inside (for needle bar) would probably limit the foot lift but that seems not to be the case. I have seen this on a Dürkopp 239 machine which has same walking foot mechanism. Can you push the foot lift lever over the flat side so that the slider rests on the levers "right angle" edge? Know what I mean? I can do that on my 111G156 and to me is seems the parts are all the same so I think it just has to do with the position of parts. I unfortunately have no procedure I could explain. I have setup my machine when I restored it an never had to touch or reset it ever since. Picture 1: 10mm foot lift Picture 2: 12mm foot lift -
if not Dürkopp I would assume Christian Mansfeld (Leipzig) but I´m not sure.
I´m not professional either - not at all! This is my thread + odds & ends cobbler-cabinet-organizer. It originally wan mean for rubber heels. It´s not professional but I love it. Usually thread spools have a sticker on top of the spool or there is one on the bottom side with thread "size", length and manufacturer / supplier. Thread size is "calculated" by weight per meter or kilometer and not by visual thickness so it could well be that different thread sizes look the same.
problem could be the lifting lever (see picture - know what I mean?) or how the machine is set up - please post pictures (view from left side) with open face plate and foot lift lever up -
One more Service Manual Singer 211G155_G156.pdf
Looks like a barn / garage find - its dirty and untested. I´d say not a too bad price but do not expect too much from the seller - wondering why he is not cleaning it before he is selling it (at least whipping off the dust with a rag) I would! If the seller is not able to set it up for sewing it is a gamble. Look for a manual print it and take it with you and test sew the machine. Ask the seller for more pictures (incl. motor, motor data plate, backside and accessories). Bobbin is small (I´d rather say standard) size but millions of people are using this size of bobbin (incl. me) and that's not an issue at all. Bigger is better but you get what you pay for. Its dirty - yes - but when I you "think away" the dust - then it looks not too bad. People here have restored way (way way way) filthier / badly rusted machines. Expect to invest another $200 incl. a new servo motor or $300 if you want a speed reducer (I bet you want it) but then you have a machine that will serve you many decades. Parts & accessories are no problem. Maybe you can get is for $300... JFTC you go and check it - here are some related files: Singer 211 Operators Guide-Small.pdf
The Google search no longer works - seem when I click the google link it redirects to the /forum/index.php site and not to the thread I wanted to go to. -
Thats actually a tricky part! I think LW member UWE has a Youtube Video how to replace this part. I have replaced 2 of them on Singer 111G156 machines. I´m 99% sure the Dürkopp part is the same. But you no longer find original Singer parts and you have to be careful with aftermarket parts. What I figured is that original SEIKO and original JUKI parts fit for Singer 111 machines whereas some "Chinese" aftermarket parts do not fit. The difference is in the pin that goes in the small hole near the presser foot bar clamp (part # 460111 in your picture) Juki and Seiko parts have a pressed in or heat shrinked pin (just like Singer and Dürkopp) whereas some aftermarket parts just have a bent piece to sheet metal - and that just does not work (my own experience) I hope you know what I mean and I explained it right. So - before I loose my self in long explanations.... I would try a JUKI part # B1460-246-0A0 or SEIKO part # 10546A In my 111G156 I´m using the above JUKI part and just recently (due to the BREXIT) I ordered the SEIKO part from College Sewing in the UK (just to have a spare). They have the same function but I think the SEIKO part is a bit closer to the Singer part and is better made. If I were you I would try the SEIKO part. Keysew has the SEIKO part on their website: http://store.keysew.com/catalog/product/272a3dfeb4184c8890c3def5c018fff0 EDIT: here is the Video:
No - feed do and needle plate are different - there are no Singer parts and as far as I know no after market parts for this machine. It just shares some parts with Singer but not all
Pic 1, 2, 3 - left is the Singer hook, right is the Dürkopp hook. Pic 4, 5 - this is the Dürkopp hook, the shaft remains in the machine you only pull out the top part. Advantage is is you (usually) do not have to re time the machine. Singer hook and shaft is one piece. EDIT: I´m not sure but it could well be that the hooks for Singer 153w machines could work for the Dürkopp 241 - see what I mean - see below link: https://goldstartool.com/Hook-for-Seiko-CW-7-7B-8-8B-8V-8VB-w-b.c..html
They do - I had a Dürkopp hook in my 111G156. However - the shaft of the 111 hook has a grove where one of the set screws sits in but the Dürkopp hook as no such grove. Thats the main difference beside that you can separate the shaft from the hook at the Dürkopp 241 hook and the Singer 111 in one piece. Meaning - when you replace the 241 hook with a 111 hook you have to pull the entire hook including shaft (most likely you have to re time the machine cause the gears could get out of alignment) When you replace the old Dürkopp hook with a new Dürkopp hook the shaft remains in the machine and you only pull out the hook which is attached with a (vertical) screw. hard to explain - let me see if I can take some pictures...
Mitsubishi DU-105 22, advice needed
Constabulary replied to Damas's topic in Leather Sewing Machines
Tension unit looks a bit like a Pfaff tension unit. Since you are from France I´d check with college sewing in the UK. https://www.college-sewing.co.uk/mitsubishi-industrial-sewing-machine-spare-parts/ You may find other useful parts or maybe a servo motor there. it worth browsing their website. The DU-105 for sure shares some parts with the Singer 211 so checking Singer parts could be also helpful. -
For sure a handy machine - you never know when you have to sew the next airplane hangar for you friend or neighbor. I think last year we had a post with this Singer 8-8 machine - not sure if Bob @ Toledo Sewing had one - or so - do not recall.
The 105-64 is a bottom feed + needle feed machine - they usually have less aggressive feed dogs compared with plain bottom feed / drop feed machines. So the marking are approx the same as on walking toot / triple feed machines.
they have a oval data plate with Class and Subclass. Like 45K89 - 45K is the class and 89 is the subclass.
Are You Able to Identify this Simanco Part?
Constabulary replied to Evo160K's topic in Leather Sewing Machines
Singer 7 or 97 and Adler 20 winder have a longer pin for the bobbin and a wider filler tongue /stop latch. I´d also say Singer 132K / 133K but the coil spring is missing. Yes friction leather strip is missing too, they were attached with brass pins. -
Yes, I have one for the Adler II and Adler III - I can send you both when you send me a PM with your email address. I have used 794 needles back then. System 794 needles are approx 68-70mm long so I think whey could work IF the needle you have is the original needle - you never know. This was my project back then:
Recommendation - Jack Jk-561A-1 Servo Motor
Constabulary replied to Constabulary's topic in Leather Sewing Machines
I haven`teven tried to find out more - I just removed the NPS and I´m good. You can turn of the NPS.
