Constabulary
  1. you have no sight hole - you have an oil hole - the sight hole is above the bulge (see picture of my 111G156) You can pull out the stitch length knob (and rod) and nothing goes out of alignment. There is a short end with very coarse threading at the end of the hand wheel that's the "guide" for the pin inside the stitch length knob. You screw it in by turning it toward you with a bit of pressure to the knob (jiggle it a bit back and forth for finding the right point...) EDIT: the last 3 pics are from my 108w20 which has the same stitch length adjuster as your early 111. And the Singer 153 also has this type of stitch length adjuster.
  2. The machine (pictures in 1st post) has no safety clutch (no plunger in flat bed) and does not need a plunger for stitch length adjusting as it is a very early version of the 111 with a knob for stitch length adjustment. I would guess its from the 1930´s - 1940´s era. Well depends on the point of view - if it was a plain drop feed straight stitcher I would not touch it but a triple feed / walking foot machine that cost me nothing - why not? You cannot earn money with a restoration & selling it but for the fun and then owning a functional walking foot sewing machine for what ever (future) purpose... why not :-) Seems most parts are present. I would first buy the missing parts (not many I guess) and then reassemble it and when it sews I would start the restoration. I would also not strip it completely. Maybe dry ice blasting is a fast way for cleaning and removing old paint.
  3. You are welcome. There are some differences but basically they are pretty much the same in terns of threading and their basic functions.
  4. Maybe the 211U566 manual helps more - should be approx the same machine but made in Japan instated of made in Germany. Singer 211U157A_165A_166A_566A THE MANUAL.pdf
  5. is the G566 subclass special somehow? if not this one should help you Singer 211 Operators Guide-Large.pdf
  6. I have a attached a manual and mechanics instructions - hope they will help you. Manual Adler 30.pdf EDIT: I cannot attach the mechanics manual - file is too big (cannot compress it properly) Please send me a PM with your email address so I can forward it.
  7. sometimes it helps when people are writing full sentences instead of throwing some words into the crowd
  8. I haven´t sewn gloves yet but even some fur sewing machines where sued for sewing gloves - maybe an option for you. see from min 7:00 onward
  9. Industrial sewing equipment is not universal fitting. I guess you have to modify the throat plate and maybe feed dog or the screw posts or the binder attachment or all - modifications are not unusual. Some pictures may help to evaluate your issue. I had to modify my 108w20 a bit as well. I have chosen a different kind of binder attachment so I modified the binder bracket and the throat plate. Works perfect for me now.
  10. does the cat have handles now
  11. I would not remove the shaft. Rather wash out the grease with Paint thinner, motor cleaner, Diesel or similar. Really leave the shaft where it is! If other tension springs do not fit clip off the top coil - will not hurt giving it a try.
  12. Your machine has no safety clutch! Hook is no longer spinning - looks like you have loosen some screws on the hook driving gears. I guess hook is out of time now (too). I did not say thread goes the wrong way. I said it seems to be hanging somewhere between the small tab of the bobbin case and the notch in the throat plate (tab sits in the notch) and your bobbin case opener is NOT opening the bobbin case to let the thread pass between the small tab and the notch in the throat plate. So my guess was that you only have to adjust the bobbin case opener - thats why I linked the video. Hard to assist you from the distance if you don´t know anything about sewing machines. I would honestly recommend that you go to a sewing machine technician for industrial sewing machines.
  13. You will not find any manual where the thread is running over the small pin - neither Singer nor Adler or Pfaff - period. You just see this in YouTube Videos and from there on it spreads around the world because very one "has seen this on youtube" and trust what they see. People no longer look into their manuals cause everybody is expecting to find things on youtube nowadays. Plain and simple - RTFM. Running the thread over the pin may work but it is just not necessary. If it works - fine - go ahead and continue this but there is no technical reason for running the thread over this pin. It just makes threading a bit more difficult The tread hanging (I think) is either a timing problem (hook advanced / thread lever lifting to early for what ever reason) or your machine is not set up for the thread size you are using and the thread keeps hanging between the notch in the throat plate and the small tab on the bobbin basket (space between the parts too narrow so the thread cannot slide through properly). Furthermore - it seems your bobbin case opener is NOT opening the bobbin case - this could be parts of the problem too. But an 8 second video is probably a bit short for seeing a pattern. EDIT: The bobbin case opener function is quite well explained in this Video:
  14. Very uncommon for a button press I think - common standards are either M6 or 1/4" / 0.635" I would either return the press or the tools - or both. I switched on my press from M6 to 1/4" because it seems to me the 1/4" is more common / you get more tools.
  15. should be 6,35mm / 1/4" Depending on the press you sometimes can buy adapters. I have a Shaeffer / Scovill press and it has a M10 screw-in adapter. So I can use M6 or 1/4" tools EDIT: this guy has several adapters - not sure if they fit your press but he had one for mine https://tvt-web.de/Handpressen-und-Einsaetze/c1000253619_u8430_zfe1da35a-9517-44d6-bebf-8d5ed35e979a/
  16. If someone needs an original cap - I still have 2 of them
  17. sure - I understand - I don´t want to discuss this I just wanted to show you some options. Good luck. Try some German dealers https://www.ledermacher.de/ https://www.rickert-werkzeug.de/
  18. I would guess it is because of Geoblocking - you have an IP address from an "unwanted country". F.I. I have no proper access to the Harborfreight website from my regular browsers (Chrome, FF, IE) due to my unwanted IP address I guess - the website looks scrambled and and is not usable. Try the TOR Browser and set your Exit Node (Exit country) to US - I think that solves the problem. However be careful what you are doing - If you don´t know the TOR Browser google what it can do and what the risk is. Sorry - I cannot explain it well enough in english so please google it. - OR - Try a VPN AddOn for your browser like winscribe (or similar) and set your country to US. Both works on my end with the Harborfreight website. The choice and risk for both options are on your side.
  19. The 2nd foot is a hold down foot afaik - similar to the Singer 132K6. it is pressing down the material while the needle is penetrating the material and lifts when the material is feeding
  20. the 20-4 is the one with a geared speed reducer (seems some gears the a gear support bracket are missing) but afaik the 20-7 is the one with the 2nd presser foot. But not I´m 100% sure. Maybe a combination of both features leads to another subclass.
  21. what therad size exactly is this - have you mistyped? And what machine model are you using? Probably a problem with the thread path? Thread keeps hanging somewhere? Burr in needle eyed on on some thread guides? Too much thread tension (top and bottom)? Needle bar probably a tiny bit too high? Have you checked the needle hook timing? Needle insert correctly? Do you have a manual for the machine?
  22. CLAES Patent Elastic or Colibri. Needle system should be System 81 or 88 depending on the hook size. You still can buy them. The modern CLAES 8346 are still using these needles systems. Could be that these old machines also came with 3 different shuttle / hook sizes - just as the later models RPX / 200 / 8345 /8346. To my best knowledge CLAES is still using the same shuttle / hook type today. But minor modifications maybe required if you want to use a new made hook in these old machines. Thats what CLAES once told me when I asked for Mod. 200 spare parts a while ago. I don´t know if it was the same with the Patent Elastic patchers but only the largest hook model (-3 or -30 subclass) is using the longer system 88 needles. The smaller hook models were using system 81 needles. I think LW Member SHOEPATCHER knows more and he probably has some spare parts.
  23. Double needle post bed machines are a whole different story. We have been talking about flat bed machines. The gauge sets mentioned above do not fit for post bed machines as the feed dog and needle plates are different.
  24. Probably increasing the operating foot lift will help EDIT: extract from the manual
  25. one day... maybe...
