Constabulary
  1. If I had too choose I would go with the nickle / chrome plated ones rather than pure brass because when leather is in contact with brass it can develop this nasty green waxy stuff (copper acetate). Not sure if it will (takes some time) but could be. Therefore I would choose the plated ones when working with leather binding tape. My 2 cents.
  2. I assumed he has manual for the machine - if not see attachment. The screw on the left (circle) is for limiting forward and reverse. There is a kind of "butterfly" on the lever and the limiter screw is the end stop for the "forward wing" and "reverse wing". The deeper in the screw the shorter the stitch in forward and reverse. If the screw (arrow) is loose the butterfly could be out of alignment. See drawing - not sure if this is obvious enough (I´m no artist). When the screw is all the way in (stitch length zero) the feed dog should move just up and down but there should be no forward and reverse movement at all. Very simple but very effective too and works very well. Bomb proof old Singer technology! Not the most technically advanced F & R system but simple and functional . So when the "wings" are in good shape and screws and nuts are tight this will work reliably for ever and cannot go out of adjustment (usually). 2nd thought is the clamp and set screw on the feed shaft are loose or they fixed the shaft in the wrong position. Therefore the question if the feed dog probably hits the needle plate. But I only can guess.... 02_Singer_45K_manual.pdf
  3. No - that's a different screw the screw I mean is internally. its a large slotted screw. The red arrow points where the hole is & and on 2nd pic where the screw is. You probably have to rotate the hand wheel to see it. Not my machine its a pic from the www. This is mine I restored it in 2016. Different subclass but basically the same machine and it works perfect ever since. https://leatherworker.net/forum/topic/72789-singer-45d91-restoration/ Have you noticed the question above? When the machine is in reverse (lever all the way up in the slot) is the feed dog touching the needle plate in the longest stitch length when turning the hand wheel?
  4. Maybe it´s because of wear. Is your limiter screw present (see red circle)? First I would check if the screw that attaches the stitch length adjuster / reverse lever to the casting is tight. You reach the screw through a hole in the casting right under the top shaft / behind the hand wheel. You probably have to remove the hand wheel first. Also, when you dialed in the longest stitch length is the feed dog touching the needle plate in reverse when you rotate the hand wheel? Post some pictures of your machine please.
  5. I make a turn when the needle has risen and I leave just the needle tip in the material (needle eye visible) and I lift the foot just enough to give the material free like 2mm above the material so I have no tension release. On my 111G156 I also have adjusted my tension unit the way that it releases very late meaning it only release when the foot lift lever is in its upmost position. That ensures I have no tension release when seeing very thick materials. If you are using a foot lift pedal make sure your foot does not rest on the pedal. My 2 cents here.
  6. keep in mind - the UK no longer is in the EU so for everything you import from the continent or elsewhere you have to pay 20% VAT + tax on top. I don´t know the 669 but I assume the binder brackets are the same as for the 69 https://www.college-sewing.co.uk/parts-by-machine/durkopp-adler-parts/durkopp-adler-69-parts?p=4 I would check with College Sewing, they sell KH binder and stuff as well. When the UK was in the EU I ordered everything from them (I´m in Germany). When ever I had a question I was in touch with Justin -->> Justin[at]college-sewing.co.uk
  7. BTW - often the Singer "D" machines from Wittenberge, Germany have a decal instead of a brass badge. But the decals are often rubbed off. However the decal looks like this bras badge here and says "Fabrik Wittenberge".
  8. Not Persia - I´m sure she said Prussia The German Singer factory back then was built in Prussia (Kingdom of) but K.o. Prussia is history since the German revolution in 1918 (to make it short but story continued). Nowadays it is located in the Federal State Brandenburg. Before loosing too many words this may be of interest for you: https://www.singersewinginfo.co.uk/wittenberge Some of the factory buildings still exist and I have visited the location in 2019 and posted some pics in the below linked thread:
  9. I have a class 17 parts list and the gear driven winder is shown in the list so I guess certain sub classes have this type of bobbin winder. I haven´t seen a model 16 either (meaning one that is clearly marked as model 16) but the historical list of Dürkopps & Adlers clearly shows a Dürkopp model 16 as cobbler machine. Maybe (maybe!!!) we ID some class 16 as class 17 cause differences are not known and the 16 has many similarities with the 17. But as long as there is no clear model number mentioned on the casting I only can guess. So I really do not know... Maybe SHOEPATCHER knows more Extracts from the list:
  10. Major difference IMO is just the casting. On the later model they covered whole mechanism on the rear side whereas it is visible / easier accessible on the earlier models.
  11. What I can say for sure it is not a Model 18 cause the 18 had a static boat type shuttle (see link in Wiz´s post) I would say Dürkopp 17 (elastic / oscillating shuttle) however Dürkopp also had a Model 16 that they did not continue in 1930 so it could be a 16. Meaning it could be a predecessor of the Model 17. But to be honest I do not know the differences in particular. But the later 17 had a different needle plate and tension unit - not sure if that alone makes yours a model 16.
  12. Wiz, no 29D58 could be correct - because some 29 models were made in Wittenberge, Germany prior 1945. But they are the the exact same as K models made in Killbowie, Scottland. Usually the German made Singers serial numbers (prior 1945) start with a C.
  13. my spool holder has no bearings and is not causing drag issues. It´s an old ADLER all metal made model and the spool core is sitting on a tube that spins around plain round shaft. Never tried something else as it always worked well. College Sewing in the UK has some tape racks: https://www.college-sewing.co.uk/accessories/chair-stands-table-tops/tape-racks Maybe worth checking with them because of binders. Maybe they know a source in the UK for custom made binders or can even offer one that suits your needs (don´t know). https://www.college-sewing.co.uk/folders-attachments
  14. these Co´s are in Germany: https://www.np-z.com/sonderbau https://www.grau-apparatebau.de/produkte.html BTW - Dürkopp Adler is offering attachments / special solutions too: https://www.duerkopp-adler.com/products/specialized-solutions They have a catalogue: https://www.duerkopp-adler.com/fileadmin/dag/Media/Doc/Branches/additional_equipment_catalogue_2021.pdf But I´m sure they offer other special solutions too but they wont be cheap
  15. You need a presser foot set that suits the needle plate (throat plate) and feed dog. Binding with 1mm thick leather is special - leather is causing more friction between the binder and the binding material (leather tape in your case) than f.i. nylon or cotton webbing does. You need a binder that suits your chosen biding material. And that is the main problem. Most (not all) binders you find online are not really meant for using thick leather as biding material but it depends on the binding material thickness (because of the friction). Right angle (90°) raw edge binder are causing more friction than 45° binder or inline binder. When the friction between binder and binding material is too high you will have a stretch effect and that will ruin your project. Maybe its worth considering thinner leather tape like 0.5mm or so. You can try to find cheap binders online (trial and error) or check with attachment companies like Atlanta attachments (or similar Co´s in the UK) and they will make a proper binder that suits your chosen binding material and your machine but that will cost you big $.
  16. I would remove the V-belt on the machine pulley and try again. Still squeaking? If not maybe then its the motor brake or the V-belt. You know how the motor brake works?
  17. Update. Its assembled again. Not entirely happy with the paint but well, it looks better than before. I just striped the paint of hand wheel and added a Singer badge. Presser foot was missing now it has a new one and I replaced the spool pin with a new chromed one. Upper tension unit is replaced too and I added a new thread guide.
  18. yes, stands like this were used by Singer, Adler and so forth. I have one from a Singer 7 but but just the 2 outer parts. This will be my kitchen table one day (kicking this around for 3 years or so) But it would not surprise me if they were used in other plants as well. I shot these pic in 2016 when I visited a Museum in Bielefeld (Home of Dürkopp, Adler, Phoenix and other sewing machine brands)
  19. overstitcher.... you learn something new everyday. That really is interesting. Will check them out... Thanks a lot for that hint.
  20. I think that may be the 45K25 that came with a roller presser. AFAIR the 21 was a plain presser foot. I think you are right - my bad
  21. so you do not get #10 into #13, right? It pretty much is the same on all rotary hooks (vertical and horizontal). I would hold #10 (bobbin case base or basket) by the small center post push it slightly against #13 and either rotate the hand wheel or the bobbin case basket it self until it falls into the race then rotate a bit more and the bobbin case should be in place again. Can be a bit fiddly... The needle hook timing should be mentioned in the manual. You can download it here: https://www.consew.com/Resources/
  22. depends on condition, if motorized, if with stand or just the head, what accessories are included... some pictures may help. The 45K21 came ex factory with a roller foot. If it is included it is worth $80-100 alone.
