Everything posted by garypl
Tom Boyce Medium Messenger Bag
garypl replied to AussieMade's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks Damien - again, really nice work! -
Looks very nice Damien! I have a question about the inlaid handle - how durable do you think the snakeskin inlay will be when constantly being gripped tightly when carrying the case? I have never used snakeskin, but seems it is more often used like you used it on the front flap, where it will not see much wear and tear from handling. I look forward to seeing the completed project and thanks for sharing the step by step photos! -
CB4500 reverse stitch bottom loops
garypl replied to Zandeosaddles's topic in Leather Sewing Machines
Download Irfanview - a free, simple to use photo editing program. Open your pictures in Irfanview, then select Resize in edit menu. 640 x 480 or 1280 x 960 pixels will work. -
Sheridan Styled Photo Album
garypl replied to IngleGunLeather's topic in Books, Journals and Photo Albums
I really like the carving - beautifully executed and in my opinion just the right amount. -
Rifle Scabbard Christmas Present
garypl replied to micktx's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Really nice job and what a great gesture to show land owners that hunters can be good people to be around! -
First knife sheath
garypl replied to alpha2's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks Tony for the link! For $3.50 it's a no-brainer- I just ordered one to try out. -
First knife sheath
I've seen this guide at the local Tandy store - looks like it works well. I may try making one and if that doesn't work I will bite the bullet and buy one! -
First knife sheath
Your stamped letters look good - nice and straight and evenly spaced! What is your technique for stamping the letters so nicely? -
There are several ways to claim "Made in USA. Here is a link that should help explain the various regulations from the FTC: https://www.ftc.gov/tips-advice/business-center/guidance/complying-made-usa-standard Nothing is simple when dealing with government regulations!
Beautiful job! Just curious, how many man hours do you think it took you to complete it?
- 45 replies
- natural
- chromexcel
(and 5 more)
photo HELP!!!!!
garypl replied to stoney327's topic in Gun Holsters, Rifle Slings and Knife Sheathes
You can download Irfanview photo editor - it's free - and it is very easy to resize the photos so you can post them. Just search internet for Irfanview. -
You could probably cut that plane iron in half using an angle grinder equipped with a diamond blade. Wrap the tip in a water soaked rag to keep the temp down and go slow. Might be a problem when you actually have to cut through the edge of the blade - will need to stop often and cool down with water.
That stand is awesome - but I bet the cost is about the same as a sewing machine! Do you know what the stand costs in US dollars? From the looks of the website it does not look like they have a US distributor.
Looks amazing! I appreciate the many hours of work you put into this. For this type project, do you work on it continuously until you complete it? Or do you take breaks and set it aside for a few days at a time to review your design and plan your next steps? I find that when I am working on any complicated project, it helps me to step back and take a break from the project until I am mentally focused on the task at hand. Working on any project when you are distracted can often result in boo boos!
I agree about the Chapman screwdrivers - I have been using a set of Chapman screwdrivers with the ratchet wrench for over 30 years and have never broken or twisted any of the bits - top quality!
Card holder and watch strap
garypl replied to Petewon's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really top notch work! Look forward to seeing more of your projects! -
Beautiful workmanship! What kind of leather did you use? -
Welcome to the forum! I like the Triumph - 45 years ago I bought a 1972 Bonneville, extended the fork 10", new bars, seat, paint - your bike brings back good memories!
When I cut a long straight edge, I used to clamp my straightedge to my table because it always moved when holding it by hand. Today I rigged up the straightedge with 2 thumbscrews and threaded inserts . Drilled a couple of holes in the top edge of my bench and threaded the inserts slightly below the surface of the workbench. Now I simply slide the leather under the straightedge, tighten the 2 thumbscrews, and make the cut. If the leather is longer than my cutting mat, I loosen the thumbscrews and slide the cutting mat further under the leather. This is quicker and easier than fumbling to tighten clamps without moving the straightedge. If I want to work in this area of my bench I unscrew the thumbscrews and remove the straightedge.
- 12 replies
Composition Notebook Cover
garypl replied to Colt W Knight's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice job - I'm certain your friend will be very pleased with it! Did you cut the front and back borders with a swivel knife or did you use a groover? -
I use a headset with several flip down lenses and a built in LED light. Light isn't so good, but it helps with my close up tasks and only cost about $8 on Amazon: SE MH1047L Illuminated Multi-Power LED Head Magnifier
If you have a drill press and tap and die set you can drill and tap a hole in the back side and use a small set screw with a pointed tip to hold the tip in place. Will need a very fine tap and die set.
