Everything posted by MADMAX22
I actually found that with the lower feed dog it helps to maintain back stitches "but" that is in combination with taking the stitch length lever completely to reverse then pulling it back down to give it about a quarter inch of space. If I can nail that distance it will get the backstitch in the same hole. I tried the washer thing and it worked ok for a while, I just find the distance thing a little easier. I was thinking of making a shim for the stitch length plate, if I measured the correct angle on the reverse side corresponding to the stitch length I think it may help.
Ferdco Super Bull / Cobra Class 4 Issue
MADMAX22 replied to tagger609's topic in Leather Sewing Machines
Haha thats not good. I mean Wiz and the guys are great but that dealer should be fixing the machine he/she sold ya. -
Order of Operations
MADMAX22 replied to jrmysell's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
If you mostly doing knife sheaths do you want the long edge to be glued together and uniform? When I do mine it depends on what type I am making but all similar. If I am making separate belt loops that get stitched on then I finish those completely before assembly and finish the sheath with the exception of the final long edge. Put it together and glue the long edge and stitch. Then finish the long edge burnish and all that. This keeps everything uniform since its hard to get a finish coat on anything that has stitch or rivet on loops or anything. -
I cant find any pics of the mounting side of the swing down guide. Looked at the one on the techsew site and it says it will fit theres but possible drill and tap may be required. The only pics are of the arm side not of it mounted to the machine. I have an older neel's version (cowboy) and it has those two tiny tapped holes on the side you sit at and it has a bigger single tapped hole on the other side where I think it would mount.
Back stitching Biothane Beta w/Cowboy 4500
MADMAX22 replied to Parott1's topic in Leather Sewing Machines
Agreed, I either flip it or saddle stitch back by hand. Depends on what I am making and how nice I want it to look. The saddle stitch back stitch looks nicer and I can pull both threads to the back, but it takes way more time then just flipping my work around. I went back to using the standard plate. Seems to work the best out of all of them as long as it meets the sewing needs. -
Good luck with using the slotted plate and back stitching. Even with leather and making as many adjustments as I have scene it still wouldnt work worth anything. Using the feed dog and normal plate with a silly washer installed on the ramp and still pushing up on the lever then pulling it back down about half an inch I can get them to line up correctly with leather. Ofcourse it could just be my machine or one of the many who have started threads on the subject. Pretty sure even Wiz said it doesnt work properly with the slotted plate. reverse stitching is not one of these machines strong suits. -
Dont feel bad, that is one of the hardest stamps to get correct. On that particular one it pays to buy a barry king or other high quality. The tandy ones are very difficult to work with.
Cutting shoulders straight in quicker time
MADMAX22 replied to RockyAussie's topic in How Do I Do That?
Basically what I am thinking of making is a table clamp like this picture but instead of on the side have it on top of the bench running the full length of the bench so you could slide the hide under it and bring out the edge you want to trim. Then make a thin one of this style blade that you could draw down just over the clamp. I think this method would be pretty quick and easy once it is setup. The only issue I could forsee is that the length of the clamp may not hold the middle portion well enough. -
There was a thread a long while back where someone made a basically 2x4 board clamp and had a utility knife that he sliced down the hide. I have been thinking of how I would make one. Was thinking probably the easiest homemade one is a straight board clamp/vise setup on my work table, then make a draw knife (not sure of nomenclature but the straight blade with a handle on each end) with a thin blade. -
Damn those lefties!
MADMAX22 replied to Boriqua's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Great looking holster, that alternating black and brown is a nice touch. -
The best advice I can give ya is look at various peoples work that mimics what you want to do then either ask them what they started with or look at there how to blogs or forum post and see what they actually use. Look on ebay and craigslist for occasional deals. At that price range tandy or springfield leather are really your only options or second hand which is good also.
Those are all the guys who import the machines, they dont make them. Pretty sure the OP is asking about the company who actually makes the machines.
Nicely done. I like that color pattern as well.
Knife Sheath Leather?
MADMAX22 replied to TheShiek2008's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Depends if your doing double layered leather as well. Pretty sure some of the really good sheath makers use a thinner lining leather then a layer or two outer leather depending on the design and style. I found about 30 ways to skin a dead cat but someone else said there were 100. If ya get my drift. -
FIRST TRY AT INLAY
MADMAX22 replied to Buzzard Bait's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Good start, I use the same piece I cut out for the inlay plug that way its always the same size, just trimmed down for thickness of inlayed material. Looks like a beast of a knife. Did you back off on your upper tension for the thinner material? -
And there is probably more then one.
Thanks Wiz Ill look into that or try the drill method. I usually only have one large spool of any one color (gotta get more thread) but regardless the bobbin always pops away from the tab that engages to turn it on my 4500 so I end up sitting there with slight pressure on the bobbin to keep it engaged and turning. Ive tried playing with things but it still does it about 50% of the time.
Congrats and enjoy. Wish the 4500s came with the separate bobbin winder. Makes stitching items a heck of alot less time consuming.
Thanks Wiz. Finally found a few threads with some more info (not much) once I figured out how to search for it, think most of it is stuff you have posted. Kind of surprised these arent up on the various dealer websites over here. I guess the price over the 4500 would subdue the sales.
So saw this on the hightex site, 7205 and its various partners. Just curious how this compares to the 4500. I noticed the head of the unit is arranged differently but the overall casting is similar but some differences there as well. Anyhow can you guys fill me in. Thanks.
Yeah hopefully he got the other sets that usually come with them, Ill admit what did come with his is pretty nice compared to some of the stuff I have on mine. His slotted plate is fine to run with the other parts its just he is using one of these which is catching in the slotted plate groove. -
Your center foot has the thread line bottom thing (forgot what its called), that is catching on your slotted plate hole. Put some leather under it and see what it does. Dont run it "dry" like that if you can help it. -
Same thing with WC, either way if you can swing it order from the tannery. Every place I have scene with the exception of getting rid of old stock (probably low grade hides or returns) your going to pay 30-60 dollars more per hide no matter who it is.
