Sonydaze
Everything posted by Sonydaze
  1. I grind the standard feet down to the width I want and then polish them back to shiney. This lets me get closer to hardware that I'm always sewing around.
  2. I'm too far away for shipping to be practical (and don't make 100 meter coils). . If you are cutting it into short pieces, perhaps hide length pieces could work for you. If so, you may be able to find more local shops to supply you?
  3. How large of quantities are you looking to buy? Also it would help if your location was shown in your profile.
  4. Especially for people that are newer to these machines, you are better to buy from the dealer that you know will give great after sale service. My .02
  5. I looks like either the tension is too light on the bobbin or the machine is not threaded properly, causing drag on the top thread. Also check to see that the thread is coming off the thread cone easily.
  6. Phase converters are available new for less than $400. https://temcoindustrial.com/temco-xr3-rotary-phase-converter-3-kw-5-hp.html Inverters are even less.
  7. Perhaps try heating and stirring it?
  8. You may also want to consider an inverter. There are several other brands as well. https://www.hitachi.com.sg/ice/products/inverters/
  9. I always buy leather when the price is excellent. I often am not sure what it is going to get used for, but it always does get used over time.
  10. Yes it is.
  11. I'm not sure if you are saying that the clicker will not cycle or that the motor on the clicker is not turning. If the clicker won't cycle then the motor is likely running backwards as suggested above. Reversing two leads will change this. If the clicker motor is not turning properly (it will turn slower and make an unhappy noise on single phase), then you have a problem with the phase converter.
  12. It really would be not only polite but proper for you to start your own thread to sell your buckles rather than hijacking my thread as I still have buckles to sell.
  13. You might try cleaning out the bobbin tensioner. After awhile things build up under it.
  14. Thank you for commenting!
  15. I still have some of both brass and nickle buckles. Everyone who has received these buckles have been pleased with the quality. I'll get info to you by PM.
  16. Vancouver Island
  17. I would try 2-3 very light coats of cement, allowing each coat to dry well before the next coat.
  18. Welcome to the forum, it can be a great source of both information and inspiration. Giving more information of what you are sticking together and adding where you are located to your profile helps folks to give you better answers. In Western Canada, I like Duropro Contact Cement. It has a good working time, sticks well and sews okay. Make sure it is well cured before sewing.
  19. That does sound pricey and the wood fill ones don't last as long.. I get all metal dies in that price range. Maybe try Economy Die Makers. They are in Ontario but that means with CAN/US exchange, you get about an extra 20% off the cost.
  20. Flexing veg tan top side to top side creates wrinkles and pebbles. I do this occasionally to add character, especially when antiquing. The harder you roll the fold over back and forth the more pebbling you get. Not all veg tans react equally.
  21. You are welcome. I had to smile, because I'm sure we all learn these things the hard way.
  22. Inexpensive circle cutters can be made with circle saws. Buy the size you need, put it in a drill press and with an angle grinder, grind it down to a knife edge. They work both with a press or just use a mallet to pound it through.
  23. The 22 needle should be more than big enough for 92 thread. Are you using a leather needle? I would try increasing the presser foot pressure. With my harness machine, sewing heavier things that tend to stick to the needle, I rub some beeswax on the needle.
  24. I'm not a corset maker but my partner (who is not on this forum) is. You can make a corset without a busk/zipper/grommets in the front. The downside is that it will be more difficult to put on and take off. You will have to unlace it a lot more. Also you may have to adjust the front centre panels as the pattern likely allows for sewing in a busk.
