dikman
Everything posted by dikman
  1. That's what I thought, in the picture it looks like smudges of something on the leather.
  2. Belt??? I still have to make a couple more holsters first but it's all come to a grinding halt as I can't come up with a design I'm happy with. I've also been thinking about the belt and looking at various designs. My feelings at the moment are no edge tooling, carving only, maybe just flowers and leaves. Scrolls fall into the same category as basketweave for me - while I can appreciate a well executed pattern they don't have a lot of appeal for my projects.
  3. Maybe they raised the feet to give extra clearance for a specific type of job? I did it once on one of my machines, it just meant it didn't work too well on thin stuff.
  4. I didn't realise you are Road Agent Leather, I've been watching a few of your videos, good stuff.
  5. And just looks.......right.
  6. That's a bit different, very elegant. How about including the youtube link in the post?
  7. They look very nice, but I particularly love the handles and bolsters. They should age nicely with use.
  8. You did a great job on that holster, the finish looks very nice.
  9. Pretty much the same as mine, the swivel base is great for adjusting work angles and putting my feet on it keeps it steady. Only difference is I made a lever toggle so I could tighten/release the jaws quickly.
  10. Beeswax is used as a moisture repellant (and lube) for good reason - it works exceptionally well. It is almost impossible to remove completely once applied. Bullet casters use it for lubricating lead bullets, but if they decide they want to try something else after lubing then the only way is to re-melt the bullets as nothing else will stick to them one the wax has been applied. Casters have tried all sorts of solvents to remove the wax but these are not what you would want to apply to leather. Shoe polish should work, but permanency will be the issue as like shoes it will probably have to be constantly re-applied. Toxo's/Tom E's idea is probably the best, if you can find a dye that can withstand the 125* wax bath.
  11. Unlikely to work. The modified plate/feed dog will let a big harness stitcher handle #138 thread, and thinner material, but I doubt if it will suit what the OP wants (plus it would be well outside his budget!). I believe it can go down to #69 thread but getting suitable needles may be an issue. The Singer 4411 is a domestic machine (described by some as a "heavy duty" machine, but this is only because it has a bit of metal framing inside). If you've got one then try it (and good luck) but if you have to buy one then don't waste your money.
  12. https://sunvalleytrading.com.au/ Located in Qld, they ship all over the country. Great people to deal with.
  13. Olde saying "necessity is the mother of invention". Vicious looking attack dog you've got there!
  14. I think that tool is a lifter, used to give a more pronounced 3D effect under parts of the petals.
  15. It's really the first place to start if you're new to industrial sewing machines. It's a complex subject, trying to work out which machine will best suit your needs. A general rule is that there is no "one-machine-will-do-everything". If you want to work with light materials a heavy duty machine won't work, except under specific circumstances, and a light-duty machine won't handle heavy stuff. That's why many on here have more than one machine. Read through that post, preferably several times, and it may help you with working out exactly what questions to ask.
  16. What a beautiful old piece! A nice bit of history there.
  17. I wondered that myself. I found his use of the skiving knife fascinating to watch.
  18. Sounds to me as though you're lucky that ink didn't transfer. if it had I don't think you would have had very sharp lines! Thanks for the explanation of your laser process, when I used it for making PCB's heat transfer was used, an electric iron (as used for ironing clothes) was used to transfer the toner onto the board. Same basic idea as your process. Using an iron might work on leather too, as it won't be hot enough to burn the leather. And yes, the "traditional" way is to copy the pattern using tracing paper and then use a pencil, ball-point pen or stylus to imprint the pattern onto cased leather.
  19. If you've got 30 minutes to spare watch this. A (young) Japanese chap making boots entirely by hand. His skills are remarkable!
  20. Damn, Keith, that is so beautiful it hurts my eyes!!!! Makes my effort seems so........inadequate.
  21. I made one years ago to use with a WD40-type bulk oil. I soldered a stem onto the can, so it was pretty solid and pumped it to around 30 psi, I think, mainly because I had no idea what pressure it would take. It worked, but tended to slowly lose pressure. I've still got the can but I don't use it for anything, I found it easier to re-use plastic trigger-pump bottles.
  22. In my (limited) experience with holsters I've found that the wetting, for wet-molding, tends to harden the leather, and using dyes does like-wise. I believe Medieval leather armour was hardened by soaking in water? The fact that you've worked beeswax into the leather is going to make it difficult to do anything as beeswax helps to keep leather soft (and will be almost impossible to get out). Using carnauba wax, with a polishing buffing wheel, may be about the only thing you can do.
  23. Simple is good. White lithium grease may work, just a light coating to minimise fling-off, the idea of motorcycle chain oil is good but I've got several different types that I've tried on my bike and all but one tend to throw off and make a mess. The one that works best on the bike is Motul brand, minimal fling.
