Everything posted by fredk
Two natural vegetable tanned belts - Quality comparison
fredk replied to Mandarage's topic in Leatherwork Conversation
1.are they along the line you'll be sewing? they'll go awol under saddle stitching 2. you can use a modelling tool to burnish the leather around them to press the surrounding leather in towards the hole to make it less visible. A little bit of water dropped into the hole will help make the hole close up as well
I'll second JB Weld. I used some as a 'temporary' repair on a valve cover and on a water outlet on my 1930 Austin 7, that was 20 years ago and the JB is still holding. The valve cover is under the exhaust so it gets really hot there. The water through the outlet only gets to about 90 degrees.
Water resistant leather?
fredk replied to ScottEnglish's topic in Shoes, Boots, Sandals and Moccassins
When I used to repair medieval type shoes for medieval type re-enactors I used to glue on a modern rubber shoe sole repair patch. It was just big enough to cover just where the ball of the foot made contact with the ground. It was enough to about water proof the sole and add extra grip, especially on wet grass. -
posting that way imo is just spamming No
other sellers pay to advertise and sell
Mink Oil Any Good?
fredk replied to Brigg's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
That may be true in the US but the mink oil I buy is pure mink oil with no additives. -
Mink Oil Any Good?
ethics. In the UK and some parts of Europe mink are not only no longer farmed but it is forbidden to farm them thus its very hard to get mink oil. I get mine from China. Neets foot oil is a by-product of the beef meat industry so it ethically easier to obtain Neets foot oil (NFO), beeswax and some carnauba wax mix is what I use -
make sure the replacement gasket is the same thickness as the original. any difference can throw tolerances out
Two suggestions; 1. get a bit of dowel, drill a small hole in one end, push the square-ish shank of a large size sewing machine needle into the hole. you have one pokey-hole tool. 2 one of these might work for you; and a cork block to push the pokey or needle into as it goes through the leather. you can get one for about a $ or two in a hardware store, as a 'sanding' block. keep to the large size or simply cut it down to a handy size for use
I use pre-waxed polyester thread in different thicknesses and colours, but mainly dark brown, light brown or black. Either pre-waxed or waxing during sewing is a must
Interesting A very different look
A number of years ago I got some python and croc embossed cow hide from Tandy in Manchester, England N.I. has its own animal & plants products import controls. My leather was stopped and checked and I was threatened with prosecution for importing skins of endangered species. It took a number of emails back and forth until them uns did a DNA test on the leather and found it was bovine, but they didn't back down and admit defeat, they left me with a 'warning', like 'we are watching you' A couple of years later I got some more embossed from Tandy, This time I asked Tandy to include a copy of their info sheet saying it was cow hide. The hides went through control and the packaging note was stamped by importation control as leather checked and ok. They missed the snakeskins in the box of hardware in the centre of the roll, There is just one way, possibly, to use really exotic leather. If its at least 100 years old and certified as such. I know of a museum restorer who used the hide of an old 18th century stuffed Bengal tiger to fix an old Zulu shield. The tiger was real mangy and only fit for burning.
No elephant, no tiger, no real croc, no real alligator, no pangolin, no rattlesnake yes for, ostrich, emu, kangaroo Check out the World Wildlife organisation lists for endangered species. If its on their list then avoid https://www.worldwildlife.org/species/directory List not exhaustive https://awionline.org/content/list-endangered-species#reptiles
Generally, in the UK you may not use any product from an endangered species. There is no licence which allows you over come this Despite N.I. being UK we have different laws. viz, I may not use any product, leather; from any snake or reptile or other endangered species. Totally forbidden, If I do and get caught = jail time and a big fine. N.I. has this overall law as some US rattlesnakes are endangered whilst others are not and the officials don't want the bother to segregate them and all ow some as they cannot tell which is which with out DNA testing, same for some crocs, other snakes
The ones found here would not work. The bases are often too rough and there is not enough smooth area on the top, its often moulded in ridges & valleys around the rim Yup, I checked them out whilst searching out the paper weights
I find them hard to see but I suggest they are 'sail eyelets' eg
I have a thick piece of hardened glass for burnishing the surface of leather but its not the best as only an edge can be used. The other day I could not find it and searched out something else to use. Then I thought, maybe I should buy another couple of burnishers. I dropped that thought when I saw the price and size of the few that were available. Then I thinked a thunk. What is needed is a perfectly smooth and hard surface. Something of reasonable size A glass paperweight I went onto ebay, looked up glass paperweights and found tens of thousands going for 99p each. No-one really wants them. The sting in the tail is the postage, or s & h to you US readers Here are some I got; 1. Round, 70mm [2.75 inch] diameter. It has a very, very slightly depressed centre but it works fine. It fits the hand very nicely. Cost was £1.20 + £3.95 postage. I sort of bought this one because of the Celtic design in it, but thats just paper stuck on the base, 2. Better value was this set of 3. Obviously the one on the left is of limited use because its solidly attached to a base. I'll drop that one into a charity shop [thrift shop] But the other two are useful. The round one has a Christian saying in it so I like it. It is the same size as the previous one at 70mm diameter overall. A very, very slight depressed centre top surface but it works well because of that. The rectangular lump is 107mm long [4.25 inches] by 65mm [2.5 inches]. The top is perfectly level and smooth. This lot cost me 99p + £3.20 postage So, for under £10 I have three decent glass leather burnishers. And they can be used as weights. eg. I use some lead weights to hold leather onto my cutting table when the leather hangs over the edge. These will do the same job and look nicer to boot If you go for the same, look for flat disc shaped paper weights. Watch out for clear plastic resin ones being sold as 'glass'. If unsure, ask the seller about the paperweight. Be aware that this may start you off on another hobby. I have two more paperweights on their way to me, bought for their subjects not for burnishing, but they may get impressed into the work force
I use a seeder stamp You could grind down a 2mm or 3mm hole punch till the metal of the walls is thick and blunt. Problem with a a blunt nail or a nail setter is its too easy just to punch a hole right thru
try rubberised horse hair. you can get small amounts, like A4 or A5 size, in model railway supply shops. For large amounts look to upholstery suppliers
Acrylic paint and a small paint brush followed by several coats of acrylic varnish
Transport leatherworking Supplies for Youth Groups
fredk replied to resqman's topic in Leatherwork Conversation
A. do the granite slabs need to be that large? I often use a chunk of marble that is only about 6 inches by 4 inches. Cut the slabs in half to 6 x 6. That'll reduce the weight. b. get an angle grinder with a fine cutting disc on it and use that on the edges and sides. you'll soon have smooth edges c. use a wooden fruit boxes/crates for them d. mechanics tool chests for all the tools. you can probably get ones cheap in 'Harbor Frieght' [ name?] like the top part of this unit I have one set of drawers just for 3D/2D stamps, one for sewing things, one for general purpose leather working tools, and one for spare tools and odd things
