Everything posted by fredk
Actually barrels were not disposable. There was a large return fee on them. No return and the customer was charged far more than what the barrel was worth. But I can see how damaged or end-of-life barrels would have contributed staves to make other items. PS. Up to the 1970s, a place in Belfast re-used end-of-life barrels to make items such as chairs.
Agree with all the above. But now that you have it made; hammer down those stitches, then add lots of bees wax on the insides ones. I mean, a lot of beeswax. Then really rub that wax into the thread and leather. Use a bone folder, tip of an antler or bit of rib bone to get in there. You want to end up with an almost smooth surface, that its hard for your finger to feel the bumps made by the thread.
Essentially there is no difference. I often do small items that way. Usually I use a Glovers needle one way and sometimes change to a Saddlers needle for the return. However - there is a difference in look, in how the threads lay to each other on doing the two-needle Saddle stitching
No. That only removes the top finish, not the oils within the leather. You need dry leather for the paints to soak in.
Paint will not adhere to oiled leather. Is best put on before the leather is re-oiled after tooling Find someone you can work with who will do the tooling but not put any any oil or other finish on it. You can do that after painting it
1. I get all my special stamps made in brass. Actually, that is the only metal my makers use 2. each stamp comes with a threaded hole in the back 3. on veg tan leather I wet the leather and just press the stamp impression in using my lever press. 4. In theory I can fit a shaft into that threaded hole and up into a soldering iron and heat the brass stamp up 5 if I heat the stamp up I should be able to burn the impression into chrome tan leather or even wood. 6. Get your stamp made in brass with a threaded hole on the back, then it can be used the way I use mine.
I sand by hand. 280 or 360 grit wet & dry used dry to even out any bumps not required, then 400 or 600 grade w&d used dry to smooth it all. Its rare that I need to sand. I usually find that if the edge is trimmed with a good sharp blade that sanding is not necessary
That is a good run. Happy Annie when it comes There's a cynical joke in there; the first lasted 3 years, the second lasted 6 years, the third lasted 9 years and the fourth has lasted 12 years
Looks nice. Pre-dyed purple leather, or did you dye it? When I dye it comes out really, really dark
Phone Holster
fredk replied to Rolandranch's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Another nice piece from you One thing that stands out, really only because we are studying a photo; front side, bottom right, looks like your border line cuts through the leaf. Anything you can do to hide that? At last, something I have in common with your work - I too have that horse head stamp! -
Two different threads on this forum threw up a thought in me. Would it be possible or feasible to print a concho type thing over one half of a Chicago screw so that that part is captive inside the 3D plastic? If it could be done, one could makes unique concho type ornaments or heads for the Chicago screws I know I can use resin and rubber to mould something with the Chicago screw or rivet captive. I can also do it in white metal. But as 3D printing is the new way of things I was wondering.
Canted sheath question/ help
fredk replied to DaveP's topic in Gun Holsters, Rifle Slings and Knife Sheathes
To get the sheath to carry at an angle you angle the belt loop part Have looky here; Courtesy of Al Stohlman, How to make Custom Knife Sheaths You can either start again or cut off that loop part and sew a new one on at an angle The illustration above shows carrying on the right. For left side, make forward = backward and backward = forward Test on a bit of thin card first tho -
Whilst thats all Ryans own work you can download a pack of patterns for making chaps from the Tandy Leathercraft Library. once you have these you can adapt them. The patterns include suggestions for the fancy tooling work too https://www.leathercraftlibrary.com/search?searchterm=chaps
I buy a lot of my supplies from China. Before this last January my orders were taking on average 8 to 10 days. After their New Year and with the shipping all awry because of the C-19 some orders have not arrived at all, 2 orders from 16/3 have not arrived yet but one from 4/4 arrived yesterday, one order from 4/4 arrived on the 16th. Contrast, an order from England placed on the 9/4 has not arrived yet. The whole delivery system is up the left. For us in the UK a lot of the Chinese sellers have depots in London, Manchester, Glasgow, Dublin and other places. They send the frequently bought items from one of those depots. I also learnt, and I'm not 100% on this: the Chinese have frequently bought items ready packed on the freight ships and the Silk Train. When I buy something a worker on the ship/train gets an email, prints the address label and it gets posted at the next dock/port/station. I can believe this as a. I've received goods back-stamped by the port of Hamburg and other places, and b. having done some shifts on the Royal Mail Night Train sorting letters and packages I can see how it would work.
Leather damage, i wish someone told me that before..
fredk replied to NMendes's topic in Leatherwork Conversation
Unfortunately a lot of misleading terminology is now used to describe leathers. In the past 'patent' leather was top quality leather dyed, polished and lacquered to a very high shine, It was mainly used for top quality shoes. That was pre-1980s or so. In the more recent past to today, 'patent' leather is any leather sprayed with a resin finish ~ and that is what I believe you have. Something I've said in the past and I'll briefly repeat; under the European rules, Leather is not what we on here expect it to be. Any material which has any amount of animal skin on it can be 'Leather'. Cheap 'leather' couches and chairs have a material with leather dust mixed with resins sprayed on it. We used to call this 'leather cloth'. Now it can be called 'genuine leather', 'real leather' and can be sold and priced as such. -
yup, they're the ones. I don't see a price for them. Can you see a price?
Interesting. I don't go for the voodoo thing. Could the centre portion of the body be replaced with something like cotton duck or canvas to make a regular pin-cushion?
Well that just takes it up another level of most excellent so it does I can hardly follow a drawn pattern never mind trying to do one free-hand
Sorry, no brand name on mine. I got them from a Chinese type seller on ebay. At one time Tandy sold these, but at a very high price, afair £35 per tool eg. https://www.ebay.co.uk/itm/Leather-Stitching-Hole-Punch-Plier-Clamp-Cutter-Hoggard-Diamond-Cut-Punch-L-L4Z2/114160672691?epid=18030599939&hash=item1a94819fb3:g:B3QAAOSwoJ5effY7 Up to about £17 a tool, but I think they are worth that I'll let you into a secret. I bought the 4 tooth and the 2 tooth tools, but the teeth on the 2 weren't hardened and bent going thru 2mm leather! So I bought another 4 tooth tool and ground off the two outer pairs of teeth to make a 2. I could have bought another 2 but I was reckoning if the first one wasn't hardened a second one might be the same.
English stirrup leather buckle - unusual?
fredk replied to Xanthoria's topic in Saddle and Tack Accessory Items
Still closed but answering email enquiries -
30 years ago I was involved with a vehicle restoration company. They specialised in restoring old buses and trucks. One time we had to re-upholster all the seats in a 1934 bus. The customer insisted on leather coverings. As usual we farmed it out to a bus upholstery company. They showed us the 'leather' which had a pattern similar to the OP's. When we got the first seat back, the driver's seat, I noticed that the surface was cracking away, just like the OP's has done. The upholstery company insisted it was top quality leather. I put a ciggie lighter to a piece of their material, to a piece of PVC and to a piece of leather. That proved that their 'leather' was PVC. -
In 30 years of working with leather (only 20 properly) I've only seen this on fabric backed PVC. The material was sold to us as 'real leather' and top ££ paid. A simple burn test proved it was PVC as for a glue, I would use UHU or Bostick
