Everything posted by fredk
Quick n easy bracelets
fredk replied to Stetson912's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thank you for the concise answer. The names are nicely done, especially the middle one, -
'stiffening' soft leather for cutting..
fredk replied to canonitr's topic in Leatherwork Conversation
A straight edge with cork on the back helps to hold the thin leather in place. I use a rotary blade as well, but I only cut a hand-span at a time. -
The apprentice is only as good as the master teaches [old proverb or somat]
Fashionary - Bag Design Book
fredk replied to bermudahwin's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Futhark comes from the formation of the first letters of the Ancient Norse alphabet - in the same way our name 'alphabet' comes from the first two letters; Alpha, Beta There were several Futhark alphabets; Elder, Younger, Danish, Old, New, Saxon et cetera Runes is a generic term for writing using only straight lines; prehistoric man wrote on stones using straight lines, the writing looks like blocks of bar-codes. Thus the Ancient Norse is Viking Runes -
I see nowt much wrong with either piece. As your dottir has learnt, slowing down can lead to better sewing, but at 7 1/2 who wants to slow down?
They look grand What method did you use for the name lettering? -
Nice You don't believe in simple designs for practice then?
Nice So is mine
Brogue inspired wallet
fredk replied to stormcrow's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks nice. A very different decoration -
Gonna call it a Travel Wallet.
fredk replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks nice indeedy Must be quite big -
When I got some cow-hide impressed with python and croc skin patterns I got a print out from Tandy saying it was cow-hide. Years ago I got some buffalo hide. TSO thought buffalo = bison= protected species. I had trouble getting them to understand it was water buffalo = cattle = cow hide N.I. has its own severe regs; anything from endangered or even thought to be endangered or protected species is likely to give anyone a court appearance, and there is a hefty fine with a custodial sentence - not either, but both. Another; A few years back I had trouble with my TSO and some faux Ivory a friend sent me from USA. It took a lot of doing to make them do a simple test on it to prove it was only plastic
I've not used the Tandy ones. I have a stock of boiler maker's aluminium rivets. I used them to hold a boss and arm straps on a Viking shield. 15 years on that shield is still fighting battles, neither rivets nor straps have given out. Whilst aluminium is not as strong as steel or brass, in the way we use them they are strong enough Problem with aluminium rivets is they corrode very fast, not like steel ones, they get a white powder oxidation on them. Also, that oxidation makes blue coloured stains on skin and cloth and leather Anodized aluminium is better but it still eventually stains If you need more and cheaper look for boiler maker rivets for miniature railway builders ~ not the small toy like rail ways, miniature railwayers build engines 1/3 or 1/4 scale
I use angle-poise type light units, one on each side of my bench. Each has a 24W [approx 150W old fashioned] LED daylight colour bulb. I need to fit a fill light centrally though The lamp units cost me £8 each [appox $11] bulbs were about £2 each [approx $2.50] Each lamp can reach to the centre of my work bench.
metal lined holster
fredk replied to akguy59's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Not done a pistol holster but on certain knife sheaths I've used brass sheet. A bit more expensive, as easy to cut and shape as thin steel without the risk of iron staining of the leather -
What you say could be right but I think pre-punched and hand sewn. I think the stitch at the hole goes around the edge Also I agree, leather tube sewn and fitted and cross metal tube fitted in thru a pre-cut hole after leather piece fitted
No, they are not. When I started LW I paid good money for a near top of the range s/k. It put me off using it and doing any work where it was needed. The bearing is rough, when turning it is also jerky and sticks. One just cannot do a smooth long cut with any curves. Recently I bought a cheap one out of China for about £3.50 [approx $5]. It is far superior to the expensive one, the bearing rotates with that slight whisper one gets from a well oiled bearing, the barrel and saddle are more comfortable
I got a simple brass one made from here; https://www.ebay.co.uk/itm/Custom-Made-Design-Your-Logo-Leather-Seal-Wood-Stamp-Branding-Iron-Carving-Mold-/382286790022?var=&hash=item0 time from order to in my letter box = 10 days
All the cheap stamps are much of a muchness - Le Prevo sells the same as the Tandy range - L.P = £7.06 each, ( £5.88 +vat), Tandy UK = £9.23 / £7.91 / £6.92 - depends if you are in their discount schemes I've bought the same basic stamps from China (delivered out of a UK address!)** for £4.99 for 20 (!). They have the same code numbers as Tandy/L.P ones. Side by side they are the same. I've not had a handle bend or head break off example; (£6.49) https://www.ebay.co.uk/itm/Leather-Working-Saddle-Making-Tools-Carving-Leather-Craft-Stamps-Set-20Pcs-/232743967340?hash=item36309f1a6c You really need to go up into big money for the better stamps. But I've bought off this chap in Czech Rep. He does basket-weave stamps and fancy ones like that, not regular bevelers and such. https://www.ebay.co.uk/usr/007designer007?_trksid=p2053788.m1543.l2754 If you want your stamps to give a 'sharper' impression I'd invest in a dremel type drill and grinding wheels {i have such] and just work on the cheap tools to make them a bit better. I bought the 20 pc set at £4.99 for grinding them to other sizes/shapes ** a lot of Chinese ebay sellers now have warehouses in the UK - London and Manchester usually, for swifter delivery of commonly bought items. Instead of a week to six weeks for delivery from China you can have the item within a few days
In the UK it is known as a C spanner
To move on Whenever I needed a strap for a one-off purpose and didn't want to waste good leather on it I used to go to Charity [Thrift in the US] stores and buy cheap belts. I used to get them for about 50p [75c max] The shop was glad for them to go, get money in and also I got some decent buckles on them
Like it
I had a bit like that, I just glued it with PVA glue, after dyeing
One other thing you might try - warning, this may work or it may not ~ soak the ragged edges of the holes with superglue. This will certainly stop them getting any bigger for a while but it may also stiffen the leather
This. In N.I. we still have a very real problem of terrorists attacking and trying to kill LEA, prison guards, civil servants. None of these are allowed to have a facebake account in case their details are gleaned
I had a faceache book thingy for about 2 or 3 years about 4 years ago. I did not use any of my true info for it; false name, false d.o.b., false email addy, false cell phone number. . . . you get the idea. Amazing how many people knew me and had seen me in the coffee shop/computer shop/library/ down at town hall I only had it cos a group I was involved with notified committee members of meetings only by facebook message Thing is; facey spook is a service. Although you do not pay anything you buy into it thus the provider can ask for any info they want as long as its not illegal to do so. Its their play park, you have to play by their rules or don't play. I decided I no longer wanted to play with them.
