Everything posted by fredk
I've found that many conchos have slightly different screw threads but generally they are about M3. I've bought some of these [link below] as spares for conchos. Some they fit and some they don't, even ones from the same batch! https://www.ebay.co.uk/itm/M3-3mm-A2-STAINLESS-STEEL-FLANGED-BUTTON-HEAD-SOCKET-FLANGE-SCREWS-BOLTS-BW/121640777933?var=420632488921 Generally for the ones these screws do not screw into its they are touch too small so I screw them in with some two-part epoxy glue in the concho screw thread hole, or with some gap filling superglue gel. They ain't goin nowheres after that! Next purchase for me is an M3 screw tap Search thru sellers like the one in the link and you'll find quite a range of M3 screw bolts
The angle of the hole; in hand stitching the hole is made with a diamond shaped awl blade or triangular needle. If you align the points of the diamond on each hole, when you pull the thread tight, it will cut thru the leather, thus the holes are made at an angle so the flat faces of the diamond are nearest each other, this gives the leather between stitches greater strength. Then when you sew each thread should go in and wrap around that stronger part.
What makes leather good automotive upholstery leather?
fredk replied to katit's topic in All About Leather
St. Louis, Missouri ? From what I remember BM leather is about 1.25mm thick, quite stiff, some parts are backed with a thin layer of foam stuck on. I'll be down at my son's place either Wednesday late or Thursday and I'll look at his stock of BMW interiors, to see just what that leather is like. Regular upholstery leather will be about the right thickness but too flexible in comparison, perhaps also too stretchy. Motorcycle, lightweight leather, for 'leathers' over suits might be what you need. Although meant for clothing it is much stiffer than clothing cowhide. -
25 plus years ago I was involved with a vintage vehicle restoration company. It was just before I took up leather work. We got the vehicle interiors and seats done by a professional vehicle upholstery company. I learnt from that. There are 'bad' leathers for vehicle interiors. Bad = unsuitable. There are good leathers, good = suitable To find out what is good for your vehicle I'd need to know what type of vehicle it is. The leather used on the seats and door cards of my 1930 Austin 7 is not suitable for the seats of my son's Series 7 BMW, nor is the type of leather we used on a 1935 bus' seats suitable for a 1980s Corvette I'd stay away from Tandy's leathers; from what I have inspected of them none are suitable for any vehicle. For some uses I would choose either high quality upholstery leather, or cowhide meant for making motorcycle racing leathers If you live in an area with a lot of sunlight - eg New Mexico, Arizona, California, you'll be lucky to get 5 years out of a good leather. Even with regular feeding it will dry out and the high UV will affect it. My son exports a great number of leather interiors from his company here to very sunny places because of this -
I would [& have] only remove any prior glue if its loose and ready to come away. If the two bits of leather separate easily then the glue has soaked in and should not cause any problem. You can, if need be, use a scalpel to cut the joint opening longer for a longer length of fresh adhesive to be applied
I would use a thin glue applicator or diamond point modelling tool to prise open that area and then apply some contact adhesive. Clamp up the area nice and tight, allow some adhesive to squeeze out. As the glue sets it becomes rubbery. At that point I'd cut away the excess with a sharp scalpel.
Not wallets; on small bags, up to about 6" across, which I put a thin leather lining in the liner is just glued at the edge, and/or over any fittings [eg rivets] which come thru the outer leather. On larger bags, or any in which I put a stiffener, all the interior surface is glued If the whole piece is glued well it'll be a long time till it separates
Its a fine balance on how hard your surface is. The hard rubber surface, about as hard as the side wall of a tyre, is hard enough to allow the rivet to set, but soft enough for the concho, or in my case the rhinestone, to dig in and be supported At first I tapped lightly, several times, checking each time, now I can set the rhinestone in one - mild - whack. Not as heavy as I would do normally when setting a rivet to join two bits of leather
Similar to a round front concho; I had some fluers-de-lys ornaments to rivet to a belt. I made a block of rubberised polymer clay with a recess in it to take the ornament. I then gently tapped the the rivet head home until it was tight. However I could not get it 100% tight. If I tried I cracked the cast ornament, but this might not happen with a non-cast concho Also; I use a hard rubber mat to set rhinestone rivets without cracking the glass gem. I can get them totally tight. I recommend having a hard rubber mat in your tools armory for these jobs
Some one else found if they emailed the photo to themselves the phone reduced the photo size I never did grain - edge on shoes, only on knife sheaths. I used a thin parallel sided diamond section curved awl to make the holes and a thin curved saddlers needle to sew yes, its far too soft, a little twist of the awl should make the leather bend round, not split
Modifying round punches to make scalloped border?
fredk replied to RunningRoan's topic in Leather Tools
You can buy half-round punches; https://www.ebay.co.uk/itm/New-Leather-Craft-1-2-Half-Round-Cutter-Punch-Strap-Belt-Wallet-End-Tool-5-50MM/323312729277?hash=item4b46f0bcbd:m:mpa_KCPXzrZ6VwzOP8DhEwA:rk:2:pf:0 I bought a selection of small sized ones of these for small strap ends. Now I have another use for them You can also buy V shaped ones https://www.ebay.co.uk/itm/10-45mm-V-Shape-Leather-Craft-Half-Round-Cutter-Punch-Strap-Belt-Wallet-End-Tool/202409016977?hash=item2f20847e91:m:mOPQy0y0sWnXOo6L9vbWe-Q:rk:1:pf:0 I've not bought any of the V ones, just the round U ones. They do need sharpening when you get them Buying a ready made half-round is cheaper and handier than buying a full round and grinding it down -
I'm lucky enuf to have shelf units in my 'work-room' Dyes et cetera are kept in boxes on the shelves. Small bottles, the 4 US oz sized ones are kept in an old card fruit box. I got this as a temporary box many years ago and despi it being card board its lasted well. Taller bottles, eg 500ml of diluted dye, or the tall Eco- ones are kept in a taller plastic box. 32 US oz bottles are just kept on a shelf behind the tins of beeswax polish, mink oil cream, ..... Photos maybe, later, if I can tidy that area enuf to photo it
a. your leather is too soft b. the leather is too thin for your thread and stitches. Thread and hole should be no more that 1/4 thickness of the leather for going via the edge
The cross of St. George is an equal armed cross. The English never carried the cross on the sails, at any time. Both the Spanish and Portuguese carried a cross on the sails. The Spanish used a red equal armed cross pattee outlined in gold, the Portuguese Cross of Christ is a red voided equal and straight armed cross pattee, used post 1313 I think the design is just a fantasy design using stereotypical elements, eg the ships are of a style of late 18th C 3rd rate ships. Too many sails for the actual N, P, S/M but not for a stereotypical drawing of them
Essentially the flesh side is the same as suede. Yes, I have used the inside as the outside on small bags and a few knife sheaths. But the flesh side has to look good, I'll not use any ole rough fibery hairy bit
Mid Dark Edge Dying
fredk replied to superpacker's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I use mine your way. I have two hollow-tube handle ones and a smaller coned solid handled one - would be kinda difficult filling that handle with edge paint -
Cautious is good, but at £6.50 for 20, thats 33p [about 55c ] each! they are worth a punt as we say here
Its life; a lot of people like and want the looks. Some people will pay that extra to have a fancier looking whatever, just to be different, to have different. Take two of the same item; sell one with no packaging, sell the other in fancy packaging at 10 times the price; there are people who believe the higher priced item will be better. Thus there are people who tap into this vanity and mis-belief and sell at the highest price they can get Last year when I bought my new car the dealer tried to sell me an add on of fancy alloy wheels at £1000 more. I didn't buy. A month later I met a chap who had bought his car the same day, he bought the fancy wheels
I really believe they come from the same factory. The packaging for them was almost identical, they had the same bar code and a very similar card insert, only the Chinese ones were written in Chinese. The Tandy card insert says their tool is made in China. I've not had a bar bend yet and I whack with a brass headed mallet
or glue a donut of leather over it; thicker than the screw head. Then the slot would still be available
I do very, very little decorative stamping. For me the Tandy tools are fine BUT shop around for them. I bought a 20 set off ebay for less than the price of 1 from Tandy - they have the same Tandy numbers and I reckon they came from the same factory. [these were bought for grinding to other shapes] Also Le Prevo sells the Tandy stamps for 2/3 the Tandy price I'd say, buy the cheap ones first, do some decorative work and see which ones you use most, then invest in better quality ones of those one first example of a starter set https://www.ebay.co.uk/itm/20Pcs-Leather-Working-Saddle-Making-Tools-Carving-Leather-Craft-Stamps-Set-/282660163755?hash=item41cfdbd0ab
Recent research has turned up several photos from the 1880s/90s of Arizonian Rangers wearing a Buscadero type belt and holster, plus several photos from Arizona/New Mexico from as early as the 1860s of men wearing their holsters low slung; one I can mind has his holsters as low as his knees! I refer you to the latest editions of 'True West' magazine PS. Bonanza is entertainment not a history lecture
Thats a good small minimum order. I usually buy in 500 to 1000 at a time anyways
1. I've no Idea what those spur grommets are. I only use 'sail eyelets' http://www.leprevo.co.uk/photos/sail-eyelets.html They have a ring washer which helps take the strain. Simple eyelets just flare out on the back side. If they are not set 100% and often if they are they can just pull out. With the sail eyelet the tube-ey bit that goes thru the material curves over the ring washer, its much harder to get one of these out. stem length; 1/16 x 3 = 3/16 inch = 4.75mm plus 2mm for crimping over = about 6.75mm or 1/4 inch may just do the job, the leather will squash down a bit. or 6.5 or 7mm stem lengths 2. I would put a strip of of leather on each side of the main piece. 3. I'd use pure brass eyelets. Steel ones rust too fast
2. Unless we are calling different rivets by the same name; the tube is hollow and spreads out inside the head. The setter for the top end is just a mild steel bar with a shallow dome in the end. When you whack it the head drives down and the tube spreads out inside it. If your stem tube is too long there isn't room inside the head so the stem bends to one side - job messed up, pull rivet out and try again. If the stem is too short it just doesn't spread and is no good 1. yes, I'm using brass - I usually only ever use brass, very rarely use any iron/steel hardware. The good sellers will say what their base metal is. I usually buy plated brass, eg 'bronzed', 'gun metal'
