Dwight
Everything posted by Dwight
  1. You'll have to do a better job on the picture. When we click it, . . . it gets even smaller than the little one in the post. Cannot see what you are trying to portray. May God bless, Dwight
  2. Trooper, . . . is the class 4 a walking foot machine, . . . ?? Thanks, may God bless, Dwight
  3. The only one problem I ever had, . . . used a blue gun full size 1911, . . . it was to be for an older Springfield stainless (Loaded???) 1911. The slide was definitely wider on the real gun, . . . messed up the whole thing. BUT, . . . that is THE ONLY problem I've ever had. YMMV May God bless, Dwight
  4. Quite honestly, . . . an hour spent at a Tandy Leather shop should be time well spent. You will have far more questions than you have offered here, . . . and they can answer them as fast as you can ask them. If you should happen to get a dufus salesperson, . . . come back later, . . . or find another store. Even if you have to drove 100 miles, . . . it should be worth it. May God bless, Dwight
  5. Yes, . . .you can, . . . if you handle it while it is still in case (damp). Let it fully, . . . FULLY, . . . dry, . . . my rule is a full 24 hours minimum, . . . before I handle anything serious that I have stamped. And then even, . . . I might drag my feet a bit. Like I said upstairs, . . . I'm not a really good leather stamper, . . . tooler, . . . whatever, . . . so I do my best not to mess up something that I've spent some serious time fixing. May God bless, Dwight
  6. You can mold before or after dyeing, . . . OR, . . . you can use the dye to wet the leather for molding, . . . effectively turning two separate operations into one, . . . and saving time. I dip dye everything I do for the most part, . . . and even if I have already molded it, . . . I'll touch up the molding when I dye it. May God bless, Dwight
  7. Biglew, . . . if you have not already seen this, . . . take a look, . . . this pancake is a bit different from the ones I make, . . . but look to be quite sturdy and useful. This is also an easy to make holster. http://leatherworker.net/forum/index.php?showtopic=68882&hl= May God bless, Dwight
  8. For that price, . . . I would be in the library, . . . borrowing the book. Sometimes if you bug the local librarian a couple or three times about a book, . . . they'll go get it for you. May God bless, Dwight
  9. I always tool first, . . . (almost always anyway), . . . because if I'm gonna mess up anyplace seriously, . . . it'll be there. If I do, . . . I just toss it and start over, don't have a bunch of other labor involved...............yet. May God bless, Dwight
  10. I got an order for a belt from a niece, . . . need a stamp as she would like to have "butterflies" on her belt. I am not good at carving something that intricate. Hoping somebody has a 1 inch butterfly stamp the'd part with for a reasonable fee, . . . It needs to look something like the picture. Thanks, may God bless, Dwight
  11. Like ^^^^^^^^ he said ^^^^^^^^^^^^ pictures just don't show up............ May God bless, Dwight
  12. Biglew, . . . I don't use clips, . . . I use a strap that is basically just a 3/4 inch wide piece of leather, . . . and it snaps onto the tip of the holster sides. May God bless, Dwight
  13. I've never done a really large piece like those purses and bags, . . . the small stuff I've done, . . . Weldwood contact cement has done me well. May God bless, Dwight
  14. Did you get the PM? May God bless, Dwight
  15. I take a ball point pen and outline my piece, . . . then take a razor knife (that has been previously stropped SHARPPPPP), . . . and cut away at the pattern. Since almost everything I do will have the edges sanded anyway, . . . I can get away with a less than perfect cut, . . . and the beveling always removes any extraneous ball point pen ink, . . . it works for me. I used to use a pencil, . . . gave it up, . . . sometimes I would follow a shadow, crease, or something, . . . got out the ball point, . . . works every time. The only real exception to the above is when I grab the old strap cutter and start in with it. May God bless, Dwight
  16. When I took mine in to Ben, . . . before he took the back off, . . . he tried it "as is" and just shook his head. He looked at the bobbin, . . . the needle, . . . you know, . . . gave it the $ .25 onceover. When he couldn't find anything else wrong, . . . he flipped it around and took off the back. He actually had the guy working next to him come over and look , . . . asked if he had ever seen one slip like mine did, . . . it was like 2 1/2 or 3 inches to the right of where it should have been. He told me that the distance was just short of critical, . . . and while I couldn't remember what it was, . . . I went out and measured it, . . . from the inside edge of the casting, . . . to the nearest edge of the collar, . . . is 5/8 of an inch, . . . and he marked it for me. The marks you see to the right of the collar most likely are knurlings on the shaft, . . . mine has them too. It's pretty difficult to tell in the picture, . . . but like I said, . . . mine is 5/8 of an inch, . . . and works flawlessly if I do my part. Best wishes, my friend. May God bless, Dwight
  17. Once you have the piece cut out for the front and the back, . . . lay it down and trace the back, . . . round cut the top of it like in the first picture you posted, . . . then punch and cut the slots just like in that same picture. OR: What I'll do sometimes, . . . is to play with my computer, . . . take a picture and make it 10% bigger (or smaller, depending on what I need) until I get it exactly the size I need so I can lay it down on a piece of dampened leather, . . . trace the outline and details with a ball stylus, . . . remove the paper, . . . go to cutting leather. I've used up a dozen sheets of paper from time to time, . . . but it has none the less been well worth it to get EXACTLY what I needed. May God bless, Dwight
  18. Mike probably gave you the answer, . . . BUT, . . . if that didn't do it: Refill the bobbin that did work, . . . and try it. If it works, . . . take a ball peen hammer to the one that did not work. Then you can toss it. Double check the needle, . . . they can be ever so slightly bent, . . . and NOT WORK AT ALL HARDLY, . . . UGH !! Last, . . . take the back off your machine, . . . make sure everything looks like this picture. Especially the upper left corner. That collar slipped on mine one time, . . . I wound up not seeing what was wrong, . . . took a day off from production, . . . drove 200 miles to the Tippmann factory, . . . Ben fixed it for me, . . . free gratis. May God bless, Dwight
  19. I agree, . . . TinkerTailor has it nailed, . . . at least that is what I would do. May God bless, Dwight
  20. I like it, . . . but it makes my fingers hurt, . . . all that hand stitching........... Good job, . . . good perseverance. May God bless, Dwight
  21. My apologies, indidana, . . . I guess I missed the part about returning for his money back. Got any idea what he paid for it?? May God bless, Dwight
  22. I don't understand the problem: cut the stitches, . . . remove the screw / rivet / stuff. Voila, . . . you have a pattern. It's actually looks like a takeoff of a Thad Ribka holster, . . . called a Rhodesian, . . . which are all considered to be great from what I've ever seen. I make a similar holster for small automatics, . . . it works really well for M&P Shields and smaller pistols. May God bless, Dwight
  23. If you have the gun, . . . use the search function here, . . . make yourself a pancake, . . . a simple two piece holster, . . . with the gun in the middle. Add a couple of metal clips, . . . one on each end, . . . voila, . . . IWB holster that will work. This will then give you the personal information as to what you DO like about it and what you DO NOT like about it, . . . so then you can make one that suits you, . . . your way. If you look on my website, . . . my "Cactus" holster evolved in a similar fashion, . . . and is super comfortable, . . . even all day in the heat of the summer, . . . with an all steel 1911 commander in the saddle. Good luck, may God bless, Dwight
  24. Thanks, Art, . . . appreciate the effort my friend, . . . but Bruce uses a washer with his split rivets, . . . and they seemed to be flat headed. The rivets I have are solid brass (or bronze??), . . . have a domed head, . . . and when they were set, . . . the tips of the legs were driven down into the leather so the legs, . . . if you looked at a side view, . . . would resemble a rounded "M". That would prevent the tips from snagging on anything. My opinion is they were put on with some kind of special setting tool, . . . as they were all way too uniform to have been done by hand. It's really no big deal, . . . I was just wondering if anyone knew of using them, . . . as it would maybe give me a date for the ax and when it was used. Got a suspicion it's an old timer. Joet, . . . are those the type of rivets you have??? May God bless, Dwight
  25. Leonguaranipy, . . . just passing on what was given to me. I had the same problem with my first painted holster, . . . made for a special friend of mine, . . . did not know how to get it done. Manager of local Tandy store told me, . . . the rest is history. May God bless, Dwight
