Everything posted by Dwight
Actually . . . I simply went up to the top of my punch . . . took a triangle file . . . and scribed a line that shows the direction the long part is. Then I put the back of it on the dot I made for the back of the hole . . . line up the line on the top of my punch with the direction the belt is laying . . . tap it enough for an impression . . . lift and look . . . if all looks well . . . put it back down . . . slam bam thank you maam . . . there's a hole there . . . and it looks right. That's just the way I do it . . . but that little line up on the top of my punch is truly THE secret of it for me. May God bless, Dwight
Made a belt for my boy
Dwight replied to DustinSmith's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Let me also say great job . . . far above my skill level. May God bless, Dwight -
Second Christmas Order
Dwight replied to Treed's topic in Gun Holsters, Rifle Slings and Knife Sheathes
A fellow from down Africa way made famous that style of holster . . . it is called a Rhodesian. I've sold a number of them similar . . . and everyone I've sold found a happy customer. May God bless, Dwight -
Yeah . . . I had to blow the picture up right real big . . . but if you look right real close . . . it is stitched. AND . . . if it was me that put it in there . . . it would be first held in place with contact cement. I even contact cement in beads when I do them for a customer. May God bless, Dwight
Take a look at this: it tells you in a picture what would take me two solid pages to write. This is how the belt is made. May God bless, Dwight
As PastorBob said . . . Mop n Glo or Resolene . . . either one cut 50/50 with water . . . works great. I use a small . . . cheap . . . bristle brush that I buy in box quantities from Harbor Freight . . . they're about an inch wide . . . I brush on the Resolene/water mixture . . . swirling it on the leather object . . . making a foamy looking mess to start with . . . then I brush out those foam bubbles . . . left to right . . . right to left . . . top to bottom . . . bottom to top . . . until it is smooth and "shiny" . . . I then let it dry . . . no heated forced drying . . . just hung up to dry . . . about 2 or 3 hours later I'll come in if it is a belt or billfold . . . or some holsters . . . I'll grab the item . . . and flex it a bit . . . as would be done in using . . . Have never had one customer complain about cracking. May God bless, Dwight PS: I'm thinking the Lord likes you . . . that's two pastors in a row sent to give you information.
The first thing I noticed about it is the corrugated presser foot is up on top . . . denting and scratching the top surface of the item you are sewing. So unless you want to sew everything upside down (bottom stitches never look as good as top stitches) . . . you are just buying a a project scratcher. Wouldn't buy one if it was $10. May God bless, Dwight
From what we can see . . . looks good from here. Can you post a picture of the finished product? May God bless, Dwight
There is another option . . . called a jointer . . . a carpenter's tool. You can rubber cement the hair side of the leather to a very flat board . . . typically a 1 inch thick . . . the same width as the jointer . . . Set the jointer so it is not taking off more than 1/64 of an inch at a time . . . and in successive passes . . . you can get it down to what you want. Then "generally speaking" you can pull the leather off the board . . . and thumb off the rubber cement . . . and go make boots. If the leather is too wide for a jointer . . . the same can probably be done with a planer which is a bunch wider . . . but I've never tried that one. May God bless, Dwight
In order to make it work you have to then make all your handles 8 to 12 inches long or you'll be hitting your thumb and forefinger every time you use the dumb thing. I'll keep my mallet . . . thanks. May God bless, Dwight
One thing you are doing wrong to start with . . . don't cut off the strip to use for the knives. Just fold over the length you need. Then you can make two stitches . . . one about half way up . . . one at the top . . . that'll hold them. The fold at the bottom won't have to be stitched either. May God bless, Dwight
Suspenders
Dwight replied to Stewart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
So then you can make a pair of caligae . . . the Roman sandals worn by the Roman soldiers around the time of Jesus. They are not hard to make . . . I have the pattern if you want . . . it is three pieces of leather . . . the bottom sole . . . an inner sole that your feet rest on . . . and a one piece cutting that makes the sides of the sandals. They actually are pretty comfortable . . . I have a pair I made to go with my Centurion uniform I wear at church when I am impersonating a Centurion or soldier in a play or something. The picture is not the ones I made . . . but they are very similar. May God bless, Dwight -
With my Weldwood and my heat gun . . . I coat the pieces . . . get em "dry to the touch" with the heat gun . . . put em together . . . sand the edges . . . bevel the edges . . . and I'd guess within 15 minutes of the first dab of contact cement . . . I can be at my sewing machine putting stitches in that belt. It may be 20 minutes . . . I've never actually timed it . . . but I can guarantee you I can start with a chunk of leather laying on my table . . . and if I need to . . . in an hour or an hour and 10 minutes . . . that chunk of leather can be hanging up in my shop waiting for the dye to dry on that belt I just made. And presently I'm sewing all of them with a Tippmann Boss manual sewing machine. May God bless, Dwight
I use Weldwood contact cement . . . and I am seriously conscious of ALL THE EDGES of my project. I make sure the cement goes out to the edge on ALL OF IT. I then take the project to my belt sander and just even up the edges . . . VERY SELDOM can anyone find where the two or three pieces join . . . and if it is found . . . it is 90% of the time a flaw in the leather that I did not see. May God bless, Dwight
Suspenders
No . . . but I think she was in the gulf the last time I was there. I just always thought that name was cool . . . "Intrepid" . . . it means fearless . . . Only bird farm I was ever on was the Coral Sea . . . docked in San Diego . . . got my butt chewed out by some pinko BM1 because he didn't like my DD blue chambray shirt sleeves rolled up. Hadn't been on the thing for 10 minutes . . . needed to see their EM's to get a battery or something . . . forget why I went there. Couldn't get off fast enough to suit me. May God bless, Dwight -
Suspenders
So . . . can you not make a matching pair of flip flops to go with the suspenders?? May God bless, Dwight -
Suspenders
Good job . . . Were you on the Intrepid?? May God bless, Dwight -
What brand of machine do you have?? May God bless, Dwight
THAT experience is exactly why I do not use patterns from books . . . magazines . . . etc . . . except for the general pattern of the object. I ALWAYS cut my holsters a 1/4 inch of so bigger on that outside edge until I am absolutely certain of the fit . . . then I trim it back. My trimming pile never has stampings . . . etchings . . . painting . . . etc . . . And so far . . . knock on wood . . . I haven't had to toss a holster such as the OP's . Mom always did that with her patterns for the clothing she made us as kids . . . and I just picked up the habit from her. May God bless, Dwight
Slicking inside of holster
Dwight replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I always finish my holsters with at least one good coat of Resolene . . . cut 50/50 with water. And unless there is some special reason not to do so . . . I coat the inside of the holsters as well. It will take down some of the aggressive ness . . . AND . . . it will not allow as much oil to penetrate the holster from the gun . . . which in turn allows dust to accumulate on the oil inside . . . which becomes an abrasive . . . working on the gun's finish. May God bless, Dwight -
I buy small disposable brushes . . . from Harbor freight . . . they have a metal handle . . . small bristle brush . . . I think they are called acid brushes. https://www.harborfreight.com/12-in-horsehair-bristle-acid-shop-brushes-36-pc-61880.html At a dime apiece . . . they will last a couple to 5 days . . . then get tossed . . . used mainly for belts, holsters, and knife sheaths. Just won't mess with anything else . . . this works that good. May God bless, Dwight
I made one a few years back for a cousin . . . for his rolling block 45-70 . . . I would have used deer skin . . . but couldn't find any long enough . . . so I used suede. Stitched down the side . . . with a toe plug . . . fringe . . . and I did the USMC beading for it . . . The bottom closes with a small zipper that can be tied closed. May God bless, Dwight
That tool from Hobby Lobby will also cure this problem. I carry one length of snaps . . . have very little trouble with this tool. May God bless, Dwight
