Dwight
Everything posted by Dwight
  1. It takes all of about 30 seconds for the initial molding to take place. The first time I did it, . . . I was thinking of like 15 minutes maybe, . . . 10 at least. Turned that dude on, . . . Voila, . . . it's happening. I'll play around with a bit of molding as well while I'm there, . . . In my setup, . . . no the bag does not hold the vacuum, as mine is not totally air tight, . . . just air tight enough to work. May God bless, Dwight
  2. Just remember when you are forming, . . . put something flat under the whole holster. I bought a $6 or $8 little white cutting board about 10 x 12 or so. I put the weapon in the wetted holster, . . . lay it on the cutting board, . . . inside the bag she goes, . . . turn on the vacuum and watch the magic. If you had been here the first time I used mine you would have thought "That boy is touched for sure, . . . " I laughed till I cried, . . . seeing how easy the vacuum pump did the work. I had used a press before, . . . and always wondered if this would be the gun I'd mess up with too much pressure or something like that. With vacuum forming I don't think we could hurt one, . . . even the plastic fantastic ones. You can also do some of the boning right through the bag if you are careful, . . . Have fun, . . . may God bless, Dwight
  3. OK, . . . (260) 441-9603 is the number, . . . ask for Jamie (if I remember correctly). Dude knows his machine, . . . I live 3 hours away, . . . twice I've taken my machine up there, . . . both time fixed "el quicko" and both times it was no cost other than the supplies I bought. **** Had to come back, . . . thought of something, . . . when you drop your bobbin full of thread in, . . . is the thread coming off clockwise or counter-clockwise. It only works the right way, . . . going off counter clockwise. May God bless, Dwight
  4. '50/50' or curved, I form them both, then stitch them, . . . funny thing is, . . . both ways work.
  5. I'll watch this, . . . as I have nothing to trade, . . . but I'm just north of Columbus, Ohio, . . . about 5 hours away. Keep us updated. May God bless, Dwight
  6. Good job, Mike, . . . I made one similar a few years back, . . . your's is a lot prettier than mine was, . . . but the old boy smiled and was happy with it. Guess that is what counts. Also glad to see you back up and running, . . . take good care of yourself, now, . . .y'hear???? May God bless, Dwight
  7. That's neat, . . . I like reproducing "antique" stuff, . . . you did a good job on yours, . . . May God bless, Dwight
  8. I might be interested dsteffen, . . . where are you located? May God bless, Dwight
  9. I don't know the needle you spoke of, . . . But try this, . . . take a similar needle and your 415 thread, . . . put the thread in the needle on a piece stretched tightly between your hands about 30 inches long. Now lift one hand up about 15 inches above the other one. The needle should easily slide down the string, . . . if it does not, . . . the needle hole is too small, . . . which will not allow the string to get picked up like it is supposed to. Or at least that is what I've seemed to find with my Boss. Another thing you might want to try, . . . drop down to 346 thread, . . . the one sold at Tandy's. I use it almost exclusively, . . . it is very strong, . . . looks really good, . . . and of all the thread I've used in the last 10 years or so, . . . it has been the one that gave me the least headaches. May God bless, Dwight
  10. There will be some "fussing" you will have to do to get the cant to turn out right, . . . and if you have never done it, . . . it can be a bit tricky. But then again, . . . if you really eyeball the El Dorado movie, . . . you will see there is a slight forward cant to the holster. I've made several of them. But other than that, . . . it should be a piece of cake, . . . on a scale of difficulty 1 to 10, 10 being the most difficult, . . . I'd rate an El Dorado at about a 3 at the worst. Make your pattern from manila file folders, . . . and you can cut and tape to your heart's content, . . . getting the piece over the belt in the right attitude so the cant works out. PM me with a email address, . . . I'll help you with the pattern if you need it. May God bless, Dwight
  11. OK, . . . thanks, Madmax, . . . I had visions of my hands holding this thing, . . . slipping, . . . crying, . . . bleeding, . . . you know the drill. Now I see it can be done rather safely, . . . may just up and get me one of them there toys. May God bless, Dwight
  12. OK, . . . not meaning to sound funny, . . . but how do you strop the blade out of a splitter? I'm thinking there should be some way other than pulling that blade out and handling it with my hands that can cut and bleed profusely should I make a mistake with a razor sharp splitter blade. I bleed easy and profusely, . . . May God bless, Dwight
  13. I was told that polishing a cutting blade will make it MUCH better as a cutter, . . . What is the process for polishing a blade? Thanks, may God bless, Dwight
  14. Hey, my friend, . . . glad to see you back up and participating, . . . cool looking rig. I made one similar once, . . . never did regret it, . . . never did go out and try to create more customers for that though. May God bless, Dwight
  15. You'd be surprised at how many people you will pass with your concealed carry holster who will never see it and get to comment on the bad stitches, bad leather, bad dye job, extra holes, . . . or whatever. Ugly, . . . like beautiful, . . . is only in the eye of the beholder. AND in the case of CCW, . . . what they cannot see, . . . they cannot critique. May God bless, Dwight
  16. The one thing for sure you want to do with pop rivets also, . . . drill the proper sized hole. You want a hole that the rivet will go in, . . . but nothing extra. And there are short, small diameter pop rivets that will do your job nicely. Like CaptQuirk said though, . . . the cheap guns really are that, . . . cheap, and don't last long. Consider investing in a good one, . . . if you anticipate surviving another 20 or so years, . . . you will find many, many times where you said, . . . "Man am I glad I have this tool". I cannot tell you how many rivets I've gone through, . . . but I now own two rivet guns, . . . the old one I bought back in the 70's is all but worn out. May God bless, Dwight
  17. Just make sure you post it so we can see the fruit of your labors.........lol May God bless, Dwight
  18. Very good looking, . . . I had it in the back of my mind that I'm the only one getting those kind of orders. Mine order was a Buckmark with a scope, . . . basically the same as you did, . . . altogether the welts and the holster were 3/4 of an inch thick. Had to make the stitching holes with my Boss, . . . then hand stitch the thing. BTW, . . . I DO like the color, . . . May God bless, Dwight
  19. The tool you want to use is a pop rivet gun. It will go thru the leather, . . . then thru one side of the cartridge, . . . when you pull the handle on the pop rivet, . . . it will put the two together and it WILL be a pain to separate them later. You can also use 2 rivets, . . . one at the top and one at the bottom so that the bullets don't cock on you. Should be an easy project. Lowes, Home Depot, or Menards carry them, . . . May God bless, Dwight
  20. Ammo is getting too expensive for warning shots, . . . Our "big" noise problem is these nutcase kids who have a $300 vehicle, . . . but have 5 grand in the sound system, . . . just so they can crank up the base and shake the little birds out of their nests as they drive by. And don't think I haven't toyed with the idea of "target" shooting up next to the road when one goes by. About 100 grains of triple 7 in my old muzzle stuffer can make all the newly buried sit up and take notice, . . . But, . . . back to music, . . . guess I'm just from the generation that started out having to have it as a part of their lives, . . . so I enjoy it. May God bless, Dwight
  21. Good job there Mr. Smith............. You all need to get into vacuum forming, . . . it's so easy to do, . . . But then again, . . . I'm just plain ol' lazy, . . . May God bless, Dwight
  22. Thank you Mr. Bruce (don't squat with your spurs on) Gibson, . . . CD blarin' CCR's greatest hits, . . . works for everything except dyeing. Gotta have silence for dye jobs, . . . or everything gets the same color..........lol............ Just wish I had more CCR than I got, . . . would make life better maybe. When they get done, . . . Johnny Cash comes on the scene. I'm never in the shop long enough to wear out all the music I got of both of them though. And speakin of age, . . . if I feel especially melancholy, . . . I can always pick up my favorite four stack of Jimmy Swaggart, . . . flip on the 33 1/3 machine, . . . flip em over after they played the "A" side. Yeah, . . . it still works. May God bless, Dwight
  23. Best picture I have available to show my last pair I did. May God bless, Dwight
  24. Once you have stitched the belt pieces together on the edges (my stitches are between 1/8 and 3/16 of an inch from the edge, . . . any other stitching is to me only decorative, . . . would not add significantly to the strength, . . . and depending on how it is done, . . . actually could weaken the product. If you are talking about a double wave like, . . . up and down, . . . all the way around, . . . I would only do that on the top layer, . . . then bond it to the bottom layer, . . . it would make the inside smoother and less prone to abrasion, . . . plus it would be whole lot easier to maneuver a single layer than it is to do a double layer. Just my thoughts, . . . and I am not really thoroughly experienced in it, . . . as most of my customers simply like a plain belt. Of all I've done this year, . . . only one will be for sure in the decorated / stamped category, . . . and no one asked for the decorative stitches. But I did do one last year, . . . it was all purple flowers, . . . but then again, . . . THAT was different. May God bless, Dwight
  25. When you look (as in dissect) at a piece of leather, . . . you go from the outside or the hair side, . . . to the inside or the flesh side. If you sliced it off in say in 1/100th of an inch slices, . . . the strongest slice would be the very outside piece, . . . where the hair grew on the animal. The weakest piece would be the slice that was inside, . . . closest to the animal. Each individual slice would get progressively weaker as you move in toward the flesh side of the leather. By lining a belt in such a manner as having two 2mm pieces, . . . bonded together at the flesh sides, . . . you create a NEW leather item that has equal strength in the face and in the lining as well. Together, the two faces make a product that has a much greater resistance to bending, twisting, curling, . . . etc. THAT makes for a better belt, especially for soldiers, policemen, firemen, etc. who have to carry heavy loads on their belts. The best analogy would be a piece of plywood that had Oak on the top and bottom layers, . . . and pine for all the inside layers. AND, . . . I might add, . . . a layered belt will hold up to a lot more rough handling, abuse, etc, . . . simply because it is a tougher product. May God bless, Dwight
