Everything posted by RockyAussie
Another red handbag
RockyAussie replied to olenawills's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks for the time you went to in your answer. I checked out Peter Nitz and am truly humbled. I wish I had competition close to that here in Australia. So very inspiring. -
Is Wet Form Molding This Skull Shape Possible?
RockyAussie replied to jimmy eng's topic in How Do I Do That?
To me Vacuum forming would be quite easy and therefor the way to go but I think your idea could work depending on the thickness of leather and detail you wish to achieve. If you would need to repeat the casting often I would try putting it face down into some really spongy soft leather of the desired thickness into a render mix of sorts. (maybe sand loam + cement about 5 to 1) Once set seal the render mix and then you have a M+F mold so to speak. -
Hi Dusk, Just found your post and would like to say welcome to this forum. If you get over the East side sometime up about Rocky give me a call. I would enjoy swapping notes on the 3d printing and how it has been so useful in my current leather working buis.
Another red handbag
To picture the solution is probably the only way I guess. I am at the end not good with words. I hunted around until I found this old prototype. As you see when you pull the handle out it puts a lot of tension on the thread and handle. By putting a leather cover over it it makes it a lot harder to pull away from the bag. In the yellow cardboard pattern the red line shows the finished size about of the reinforcing piece. Once put on it makes it also a lot easier to attach and sew to bag. As you can see by the other 2 pics of some croc bags, they sell for many thousands of dollars and it takes a lot of time to fix if you don't do it well, let alone your reputation. Hope that help in answering your question. Nearly forgot, The pink piece is a plastic piece which I cut out of the covers like the black one underneath it. It is a folder for holding A4 sheets in plastic sleeves from office supplies. Inserted between the lid layers it allows the lid to spring back into shape without any creases and wrinkles. It works brilliantly in these type of flip open and shut lids. -
Thanks Alex I have tried similar to what you say here, but I do notice that when humidity is high and then temperature is cool it seems to work better (Longer to dry). Trouble here in Central Queensland Oz the weather is quite the opposite. The best I have found to date is OMAC LUX semi matt black OM 357556. But this seems to be only in the black. I think the other Omac semi dense edge paints are just rebranded Giardini. The Omac Lux black I think is a rebranded Kenda Faben Orly SL opaco and as I said behaves way better. I would like to be able to buy max of 5 liters at a time of other colours but have had no luck so far in Australia. As you see by the pics I need a wide variety of colours. Thank you again for your answer and I hope to be able to reciprocate some help in time.
- 10 replies
- cardholder
- wallet
(and 5 more)
Hi again Alex, I have not tried the black but my trials with other colours showed a tendency to split line up the middle. I usually like to finish with a final application of the colour. Normal procedure I use is fine rounded sanding 80 Rubberized grindstone where possible followed by 1 or more coats,light sand if needed then ironed in followed by finish paint. Splitting at this point is ####T. At this stage I still resort to mixing all my colours myself but the pigment I use to mix with was in 1 liter bottles and now I have to buy 20 liters at a time. They mostly supply tanneries. I've tried light sanding and scotch brite grey and it still splits.Have you found this problem and have any solutions? Checked your instagram and thought you may find this prototype bag I did a while back interesting. The black croc one is the one now in production and the fitting I designed and had made in Japan.
- 10 replies
- cardholder
- wallet
(and 5 more)
Hi Alex, Love the turtle but is it not amazing how just 4 stitches almost completely changed the look on the Birkin clutch? Not bad on the edging either. May I ask what brand edging? Regards Brian
- 10 replies
- cardholder
- wallet
(and 5 more)
Accounting for fold in the spine of book/notebook covers - help
RockyAussie replied to RoperDKC's topic in How Do I Do That?
Get a piece of leather the same thickness/substance about 1" wide and bring it over about 1/4" or more if the cover board is very thick, at the front and over the spine and mark it about 1/4" past on the back side. This gives you a leather ruller which just remember not to pull to tightly when going around. Alow similiar on the top and bottom and stitch in about 2.5 to 3mm in. Thats the best way I've found. -
Another red handbag
Very very nice for a first serious work. One thing I learnt to do and I'm not sure in the end you didn't, is where the handles attach to the bag to put a leather piece right to the edges over the inside part covering the cord area. When the handles in time drape downward they start to open up and pull the stitching open. With the leather cover piece the pressure is highly more resistant to folding back. Arn"t they fun to stitch? Hope that you find this useful. -
Lot more tricky. I will try to explain. The main barrel part of bag is about 12mm longer before folding. This is skived from 12 or 13 down to near 0. I built up some 100 drain pipe with some 3mm leather to get the internal dimension I wanted. This barrel mold is about 10 or so each end (20 in total) shorter than the finished bag length. Cut out some 2 or 3mm mm veg about same as the pipe diameter and then cut out the lining leather about 24mm diameter larger. Glue the veg into the middle of that. Sink this into end and glue in place. Then fold the outer bag ends over and in. You should then have a hole about 10mm deep. This gives room to get over the sewing machine end assuming you have a cylinder machine.Sew this around and then.... I found the prototype and here some pics may be better. That is an 8 or 10 mm eva rubber with design over top and glued in. Hope this helps. Regards Brian
Hi Gigi No special attachment. The lid is done with a french edge. The best way I find is get a long strip of supple leather and skive the start off 1/2" or so and free hand hold it against the guide both the lid and the binding and stitch it around. Finish stitching 1 or 2 inches short take out and trim of level with the first skive and then skive that piece similar to the first skive. Contact glue these 2 pieces together and proceed to finish the stitch line. Put some contact only over the stitch line and and when tacked off pull the leather out and over the edge and tap into shape a bit in corners if needed. Another line of contact in about 4mm or so from under edge, stick down when tacked off and then proceed to do the next stitch line tight against the edge of the binder. The thread is a polyamide multifilament thread called strongbond size 20. The lining is an upholstery type made for car seats I source from New South Wales Leather Co here in Australia. We use it a bit for soft tote bags and like. Hope that this helps and just ask if you need more. Regards Brian
Have you had luck on this yet? I may be able to help if not.
Fortuna 121 Band Knife Splitting Machine Manual And Part List.
RockyAussie replied to Trox's topic in Leather Machinery
Hi Trox, I only have a comoga and an old albeko so maybe not much help. I like my albeko as the waste comes out the front and therefore makes it easier to dispose of. I tried finding on line some info on the Fortuna 121 and came up dry. Would you post a pic or 2 of it sometime? I have done many modifications to mine over time and would be happy to swap notes anytime. Brian -
Not sure if this will help but this was my solution for something similar. You could replace the catches with a M+F magnet fitting and that may do. This tool bag I designed for a friend who is a Barrister and the design on the end is my idea of the scales of justice and the handlebars with the long road ahead. Really it was for his sunglasses etc like a glove box. Best of luck and look forward to seeing the rest of your nice work. Regards Brian
Good quality subtle leather for seats
RockyAussie replied to MADMAX22's topic in Motorcycles and Biker Gear
You said cafe racer seats. You will find high quality weatherproof leather out there that is not a problem. The problem is that a vinyl seat in my experience offers way better grip and wear. I did it once and first fast pull up I thought I was a gonna be a unich. I have refused to do them ever after. If you hate someone armor all his bike seat. -
The technique I worked out goes like so. Rough sandpaper followed by Light sandpaper and so on until fairly smooth. Luckily I have some pretty good and fast sanding machines.Then with a 6" rag wheel in a good size bench grinder I polish with Tripoli wax until I am happy. When I make leather or croc hairbars I usually use a tapered cow horn stick about 1/4 round about5" long. Hope this helps Regards Brian
Before going into leather goods manufacturing I was in the buis of shoe repairs.On our finisher machines (sands and polishes) they came with an attachment for burnishing in the edges of soles.They are made from steel and worked pretty well. As i have a lathe I made up one in Brass the sizes I was chasing and at first it was no good. I went back and looked at the big old steel ones and saw that there needs to be some small flats filed in to the circle to make it hammer a bit or hold the resin or polish. It then worked fine.The brass I used is about 1+1/4" dia and the 4 flats are about 2mm deep evenly opposite of course. I think most decent shoe repair shops would have one to check out If you need pics let me know. Regards Brian
Machine/foot for padded belts and other tricky edges
RockyAussie replied to HVLW's topic in Leather Sewing Machines
Hi HVLW, I don,t know if I can be much help here but for what it is worth I will try. It would help if you could show a picture of the reversible belts you are trying to stitch.I make a lot of 30mm dress belts. Unfortunately i mostly work in mm but my reckoning says that 2oz is less than 1mm and thus your combined edge thickness is less than 2mm. When you say a lining size (I would call filler) is 18mm at about 2 to 2.5mm thick I would say you are going to have a very thin edge with a quite thick filler. My fillers would be 22mm by 1.5mm thick normally. I would think you would have to have an edge thickness no less than 2.5mm to take thread around 20 (138). At any rate mostly I use machines that have a roller on the left preferably a feeding or live roller. Trouble is getting a machine that has a bobbin big enough for using that thickness thread as I only get 6 to 8 belts per bobbin on a 40thread with my Adler 268VG post or Pfaff 331-33 cylinder (not a walking foot)but similar to the 335. I make a lot of wallets also and and for the refined work I have more luck with the Pfaff331-33 than I do with the 335. Mostly the advantage with the lazy foot dragging foot or whatever you want to call it, I can grind the feet thinner on the right side to get the guide closer to the needle or grind upward etc if i want on offset rise lift etc. Although I have gone to the trouble to make my own feet from scratch many a time I have found buying a few of the common feet and just grinding away at them works most of the time. (Finish them off with the metal polish and rag wheel when done) By the way I do all my edging before stitching and thus have no movement problems. I am hoping that some others with good experience like Wizcrafts or Gottaknow can be of better hel[p than I. Best of luck Regards Brian- 10 replies
- recommendation
- uneven leather
(and 2 more)
Hi LumpenDoodle2
Glad to see someone else is exploring 3d printing world as well. I cant wait to see some guns and knives and other useful jigs and molds on thingiverse. I have attached a link to it in case you don,t know of it.Like your site to by the way.http://www.thingiverse.com/
- Show previous comments 2 more
Ahh... Don't worry, it will be me pressing the wrong button or something.
I'm pretty new at this 3D game, and got myself a CTC Chinese knock off of a Makerbot, and love it. I also love Thingiverse, and printed out the Colt Walker. Very impressed. What machine are you using?
Well, better get myself away and working.
Maureen
I picked up a second hand prusa i3 on ebay for $400 about 6months ago.
I have been using Auto Cad for years to do my patterns for the knife makers, so it was just a bit of learning how to think and draw in 3d. Until I got it I had no idea how many applications it would come in useful for. You have done well picking up something like the Makerbot. Time allowing I am planning on making myself my own variation of the Makerbot. Testing for jewellery designs size etc has been so much easier now. See my first bracelet design now going well in the shops here and a few others. -
Very nice, I'm impressed.
And I remember when prusa mendels were fairly new technology, and the most exciting things being printed were clothes pegs, and coat hooks.
Things have really moved on in the last 5 years.
Uwe's and dikman's advise is great but just a thought sometimes the best of us has put a needle in back to front and this in my experience this will show the same problem at least in hitting the hook,but please follow dikman's advise and As Uwe said, best thing is to have someone who knows what they're doing look at it. That is a big needle in there. Regards Brian
Here as promised are some of 3d molds I said I would take today. If you look carefully you will see a recess hole to accommodate the small internal zip slide and the older mold done in layered Masonite. Near to impossible to make without a 3d printer as you see the newer model comes with extra support legs to aid in keeping the whole purse supported when attaching the outer zip to the internal. For the little crown zip purse you see the advantage of printing molds that be uncliped and even with finger recess to make removal easier. To the left at the top you should see a outer piece for pressing in all the edges at once on the zip when pushed downward. The crown is what we call the center piece on the back of the crocodiles neck/head. I guess a lot of my fun is developing machinery and tools that make the making easier and more profitable. Just found this link which is also interesting. http://leatherworker.net/forum/topic/66260-3d-printing-and-leather/#comment-430777
Have you looked at the fiberglass tent poles? You get 4 in a pack for about $12.00au. Rays camping and heaps of others online local. Best of luck Brian F
Same as Ferg said Great work. Brian F
