shoepatcher
Everything posted by shoepatcher
  1. cheap price. buy it. It can be rebuilt. parts are available. Big bobbin long arm most desired of shoe patchers. glenn
  2. They stripped it for parts. Do not Junk! It can be rebuilt because you can get the parts. The Seiko model was the STH-8BLD-3, Consew would be 206RB-1,or 2. Seiko made these machines. You need to find a parts book and operations manual. This may be a clone but can Consew or Seiko parts will work. glenn
  3. Max. stitch length 6mm max ft. lift 7mm needle system 134 sizes 80-140 depending on which one you have. glenn
  4. Uwe was correct. It is either a 268-262 or 268-263. Only difference is the size of the needle it takes. 62 takes 80-110, 63 uses 110-140. glenn
  5. Call Reliable in Canada. should be able to help you. glenn
  6. Send more pics of the feet and needle area. I like Uwe have Adler brochures but I have more of them. Looks like bottom needle feed machine. glenn
  7. Patrick what parts you making for the 205 Adler? glenn
  8. Video of it sewing please. glenn
  9. You will not have any trouble selling the 669. The demand is high for that machine especially used. Glenn
  10. Eric, Good to have you back!! Where were you all these years? We both need and missed you!! glenn
  11. damn!!!!!!! glenn
  12. contact me. I will tell you how i set them up. Different than Uwe. glenn
  13. Unusual for Hirose to be off! Make very good aftermarket hooks. glenn
  14. The 205-64 used the needle system 328 or 214x1. It would sew 1/2" leather all day long but not very good for climbing over splies or seams. I have a 205-370 with toys. No comparison. The 441 came out before the 205. Both great machines. If sewing one thickness be in multiple layers, the 205-64 was great. You get into uneven layers, no. The Singer 97-10 or Ferdco Bull were jump feet and great machines. Leather sewing machines is dictated by what you are sewing. glenn.
  15. Get rid of those blanket feet. Other feed are better and available. I have no idea why Nakajima and then Jukie made these blanket feet. Only good for certain items and they are so damn big. Kwok Hing makes generic binder feet for the 205. glenn
  16. $2500.00 at least glenn
  17. similar to the skivers of today which are copies of the Fortuna. Belt shpould be close to those in length
  18. contact Collier Equipment in Alabama. They might have what you are looking for. The 91K5 Singer. They get good money for those.
  19. if you install a needle positioner, you will need to order a plug from DA to mount the synchronizer on. I have the part # if you need it. glenn
  20. Pic of the machine please so we can see what it is a clone of. glenn
  21. Why replace the wheel? You want to slow the machine down? A servo motor will do that. I have a 669 with a servo motor and a 45mm pulley on the motor. You could add a speed reducer to slow it down more. However, with the speed reducer, you cannot add a synchronizer to the balance wheel because it screw up the sensors in the needle positioner part of the synchronizer. My runs as slow as I want it to. I also got a 669 from weaver. it is an Eco model. I added air foot lift to it. glenn
  22. I have original Adler springs and clamps. Not cheap. Spring only $95.00. You can buy a new the leaf spring , clamp and screw from Adler as an assembly only. Last I checked $126.00 and change. glenn
  23. I have tension springs for the bobbin case. Also, does your machine have a tension spring in the needle bar? Check it. glenn
